The Car Care Nut uncovers an exhaust pre-heater leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Georgina Rudkus, Jan 15, 2024.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,148
    2,202
    Taylors, SC
  2. sylvaing
    sylvaing Active Member
    1,027
    424
    Good news and bad news here. Good news is if he hasn't seen one since they were released six years ago, it's really not common. Bad news is, it's still happening on a six year old car. I was hoping that since mine was never changed, that I was probably in the clear after six years, guess not :(
  3. BiomedO1
    BiomedO1 Senior Member
    1,440
    787
    SacTown, Ca
    We get a 15 year 150K mile warranty, in a CARB state. Standard Federal emissions is 8 years 80K miles here in the states.
    You may want to check Canadian laws with regards to emissions system warranty related to PZEV - it may be covered
    Hope this helps...
    49,371
    The car care nut should spend more time on Prius chat
  5. sylvaing
    1,027
    424
    I sent a message to Toyota Canada about the warranty period of the exhaust heat exchanger Saturday. I'm waiting for their reply.
  6. sylvaing
    1,027
    424
    Or maybe I shouldn't so I wouldn't be worrying as much lol. My front neighbor has a 2018 Prius. When I asked her about her experience before buying my Prime, she didn't say a word about this, only greath things. I bet she has no ideas.
  7. BiomedO1
    1,440
    787
    SacTown, Ca
    We're just hearing about the 2016 & 2017 issues for the past year. Hopefully a 3nd party exhaust system manufacturer will create a universal exhaust gas heat exchanger replacement, in the near future. That would avoid the need to replace the CAT - a very costly fix. The other option is to bypass the exhaust gas heat exchanger. Not sure if that's going to be illegal, depends on your local EPA laws
  8. sylvaing
    1,027
    424
    Are you sure? From what I've read, they fixed it in 2020 because of issues happening earlier and with vehicles still under their base warranty.
    Doug McC likes this.
  9. BiomedO1
    1,440
    787
    SacTown, Ca
    I only know of what's reported on this site and most mechanics was misdiagnosing it as a gen3 head gasket issue - even dealerships. The NHTSA doesn't break this down in their reports. Toyota has a TSB out on this, surprised the "car care nut" didn't know this.
  10. ChapmanF
    15,433
    Funny, he mentions having seen the issue before in Gen 3 but not remembering it right away.
    I've really never seen much on PriusChat about Gen 3 EHRS exchangers leaking. Gen 3 did have them, but they just never seemed to spring leaks much. Makes me wonder what was different about the Gen 4 ones.
  11. BiomedO1
    1,440
    787
    SacTown, Ca
    Probably, cheaper, thinner, lighter metal more prone to rust and degradation.
    Toyota is on the hook for 15 years or 150K miles in CARB states; just feel sorry for the out of warranty people. They'll have to sell the car out of state or bypass the system and hope the smog guy doesn't catch it.
  12. bisco
    49,371
    ignorance is bliss?
    i feel the same way over on the bolt forums. you read about issues and start to worry.
    of course, i read about gen 3 head gaskets for years, and then mine blew
    sylvaing likes this.
  13. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    Ccn should do an autopsy on the heat exchanger to see why it failed. Maybe even compare it to the new version to try and see what they improved.
  14. Georgina Rudkus
    3,148
    2,202
    Taylors, SC
    From my experience, it is likely that the failure of the heat exchanger resulted from the design where a stress point occurred at a particular stress point created in the pessing of the sheet metal or a weld. The point is likely flexed and relaxed as the result of repeated heating and cooling cycles to the point that the bonds of the crystalline matrix separated and cracked.
  15. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Monument, Colorado USA
    Yes very interesting video....so many signs of a bad head gasket.
    That heat exchanger in my wife's 2017 Prius gets looked at every 6-months when I change her oil. So far, so good....not a drop of coolant is being consumed anywhere.
  16. ColoradoBoo
    952
    626
    I asked him to post the repair video so we DIY'ers can get some tips in case we ever need to to the job. I priced out the part and looks to be around $800-950 but didn't check overseas where things are sometimes cheaper for OEM.
  17. bisco
    49,371
    the worst part of these problems is that toyota doesn't do a thorough investigation until a crisis point is reached.
    then, when they do figure it out, they don't tell the dealers, or the dealers can't read. probably the latter
    Mendel Leisk and sylvaing like this.
  18. Doug McC
    Doug McC Active Member
    997
    374
    Midwest
    2022 Prius
    T-SB-0135-19 The whole time I’m watching the first part of the video I kept thinking “is this an old video? And realizing it’s in his new shop I was a little disappointed! This is NOT a new problem. T-SB-0135-19 and a redesigned heat exchanger was introduced. Now, never changing your coolant won’t prevent it from happening to the new design, but otherwise later ones shouldn’t be seeing it.
  19. Doug McC
    997
    374
    Midwest
    2022 Prius
    I would be shocked if you were to ever see a problem with it considering your very conscience preventive maintenance.
  20. Doug McC
    997
    374
    Midwest
    2022 Prius
    T-SB-0135-19
