The Case of the Overfilled Crankcase
Discussion in 'Gen 3 Prius Main Forum' started by Rebound, Apr 11, 2013.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I just had my oil changed by the dealer. When I checked the oil level, it is high by nearly 1/4". It's obviously not grossly overfilled, but it is clearly above the top mark. Should I have them remove the excess oil?
    49,511
    it never bothered my gen II, but i haven't had my pip changed yet. not sure if it's a problem or not. might be worth asking the service manager's opinion. is there anything in the manual?
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    Call Toyota service dept. And tell them what you've told us.
  4. jdk2
    jdk2 Active Member
    751
    219
    Raleigh, NC
    2013 Prius Plug-in
    Many here never fill with more than 4 qts instead of the recommended 4.4, which supposedly provides a small increase in fuel economy. It it were mine, I have some of that excees removed and then some.
  5. ETC(SS)
    6,558
    Not everybody can work on their own cars.
    However (comma!) like the Prius itself....more can do it than do do it.
    If it were me?
    I wouldn't let them touch my car ever again AND I would pop a large angry red flare over the dealership, their owners, Toyota of Norte Americano, etc...
    But that's just me.
    Not everybody is as easy going and understanding as I am.
    This is a problem that I hear about over and over and over and over again, especially with M/C's and Toyotas.
    You probably need to let these clowns know about it, and you probably need to also acknowledge the fact that the few ounces of extra oil won't really hurt anything---in this case.
    BUT....the next maintenance/repair item that they attempt to do might.
    Would you trust them to work on your brakes?
    Your airbags?
    Do any small children ride in the car?
    An oil change is a super-easy thing to get wrong, but it's also super easy to detect and fix it when you do fumble the snap!
    All you have to do is LOOK!
    THATs the part that I would have a hard time with.
    THATs the reason that I wouldn't let them touch my car again.
    YMMV! :)
    Rebound likes this.
  6. hlunde
    hlunde Member
    419
    74
    I've never seen an owner's manual that fails to warn about overfilling your crankcase. If substantially overfilled (not 1/4"), connecting rods will strike the oil in the sump and create a froth that doesn't lubricate well and doesn't pump well because the froth is compressible and oil pumps are positive displacement pumps. An experienced tech would never overfill.
  7. kbeck
    kbeck Active Member
    420
    275
    Metuchen, NJ
    Not to mention that with a substantial enough overfill (I also don't think 1/4" will do it) it's possible to get an overpressure in the oil system that will blow out things like crankcase seals. At least, that's the warnings I saw on VW beetles, back in the day when I was overhauling same for a hobby.
    KBeck
  8. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If you have the time I would ask them to drain some. Otherwise I don't think it's a big deal.
    Just make sure to specify not to overfill while they are writing the order form. My dealer is very good about doing whatever I ask of them within reason.
  9. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    No, every time the dealer changes the oil in my 2010 liftback, the oil level is 1/4 inch over full. When I have it changed 10,000 miles later, it is still 1/4 inch over full, just slightly darker color. 1 inch overfull would bother me, but not 1/4.
