The dealer didn’t find what’s wrong with my prius
Discussion in 'Gen 3 Prius Main Forum' started by Mohammedzayi, Jun 26, 2018.
  1. Mohammedzayi
    Mohammedzayi Junior Member
    45
    Los angeles
    hello everybody
    I have a problem with my 2012 prius gen 3
    170,000 miles
    Like one month ago i got the message “check hybrid system “
    Same day i got “ P lock malfunction when park “ with a non stop beep
    One week after i got the abs light on and a circled sign and a slip light too
    And the last week t GOT THE STEERING WHEEL LIGHT ON TOO
    SO NOW ITS HARD TO MOVE THE WHEEL
    i take it to different places no one knows what’s wrong with my car
    I take to the dealership to do the diagnostic and they say that they do know i pay 140$
    And they say that i have to pay 470$ for another diagnostic , the say its may
    I find a problem with the water pump and i changed
    And I thought its the engine ECU
    I changed and programmed but its not that the problem
    One of the mechanics told me its maybe one of the ecu
    Can you guys guide me please
    What i have to do chack now
    I have all the codes all the diagnostics
    Thank you
  2. Mohammedzayi
    45
    Los angeles
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    How’s your 12 volt battery health?
    Did they do any investigation into to the hv battery?
    Orange safety plug seated properly?
  4. Mohammedzayi
    45
    Los angeles
    I used my friend 12 v battery ( same toyota prius )
    I got the same thing
    The hv battery some one tested and he say that the battery is good
    And the orange safety plug is seated properly
  5. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    What was the voltage and did the Prius get to “ready”?
    P3014 was displayed. What was that blocks voltage (or the individual modules) compared to the others?
    m.wynn and Grit like this.
  6. Mohammedzayi
    45
    Los angeles
    Yes the prius get to ready
  7. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Any accident history or rodents around the area you park?
    What was the 12 volt battery showing at rest overnight?
  8. Mohammedzayi
    45
    Los angeles
    I hit a pot hole with my back tire and in the same moment all the lights went on
    Raytheeagle likes this.
  9. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    If according to what you say is that this problem occurred while in that pothole, tgr codes in my view were triggered by that impact.
    Clear the codes, and see if it comes back again. If it does not come back, then it was a result of the impact. Maybe ecu on the battery pack area, has lost communication with dome of the sensors on that car.
    Mendel Leisk, Mohammedzayi and bisco like this.
  10. Mohammedzayi
    45
    Los angeles
    I cleared the code its come back right the way
  11. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    Same codes or some?
  12. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    The battery block #4 should not cause the loss of CAN between the other sensors as shown on your scan.
    Do you have a tech stream to see if you could access the steering sensor side and calibrate it?
  13. Mohammedzayi
    45
    Los angeles
    No I don’t have tech stream
  14. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    Ah the root cause:).
    More questions:
    • Did the tire go flat?
    • Have you checked the wiring to ensure it is all there and no damage?
    • Have you had it on a lift and checked for damage?
    • What package level is your Prius?
    If you don’t have access to Techstream, I’d look up another shop as you will need professional software (like Techstream) to clear the codes once you finish your investigation and fix the problem.
    2 members who have shops near you that could help are @Avi's Advanced Automotive and @sfv41901 from Hybrid Pit;).
    Good luck and keep us posted (y).
    m.wynn and malmon like this.
  15. Mohammedzayi
    45
    Los angeles
    Yes the tire go flat i got the sign (light on )
    What wiring should i check ?
    I checked the wiring hybrid, and everything seems ok
    Its a prius 2012 pack 3
  16. Mohammedzayi
    45
    Los angeles
  17. bisco
    48,989
    are there speed sensors on the rear wheels?
  18. Mohammedzayi
    45
    Los angeles
    I am not sure I got a prius 2012 pack 3
    How can I check if there is a speed sensor and if there is a speed sensor could it be the problem to all the lights on the dashboard
  19. bisco
    48,989
    if you subscribe to toyota tech info .com, you have access to the service manual, 2 days for $15.
    this along with tech stream will allow you to diy anything on your car.
  20. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    There are speed sensors and if they are misaligned or the electronics are bad, you’ll have issues;).
    You’ll need to put the rear up and investigate. From your comments above, this might be above your skill set, so I’d look to contact the members mentioned above.
    m.wynn and Dxta like this.
