The dreaded braking/acceleration click
Discussion in 'Gen 4 Prius Main Forum' started by acarapella, Nov 11, 2022.
  1. acarapella
    acarapella Junior Member
    82
    Rochester NY
    Hello,
    I've read quite a bit about a clicking (repeated) just before a complete stop ligth braking and at light acceleration from a dead stop in 2016+. Seems like in all the cases I read, it was the driver's/left side CV axel. I will be able to isolate where its coming from with special microphones I have, but it might not be clear weather or not its the axel or the Power Split Device (Transmission) that it's inserted into!
    Has ANYONE found this clicking to be the transmission and not the axel? I need some more info to see how to proceed
    Thanks
    Drew
  2. Jburner
    Jburner Member
    68
    43
    Wisconsin
    Found lots of threads discussing this. Seems like swapping out CV axle doesn’t fix it and the solution is to put up the window and turn up the music because it doesn’t affect anything except a noise at low speeds. That’s paraphrasing Toyota removing the TSB on it.
    #2 Jburner, Nov 12, 2022
    Pulse07 likes this.
  3. acarapella
    82
    Rochester NY
  4. Michael Wood
    Michael Wood Active Member
    181
    118
    Boston, MA
    2020 Prius Prime
    That pretty much the truth. Gen 3's do it too. If you reach under the car, you can reproduce the sound by turning the axle - there's about 1/16" of play. One theory is that it has to do with the physics of axle movement vs regenerative braking. Doesn't appear to cause other problems. You can read up on it by searching "clicking noise".
    Burner is right, turn up the radio. The good news is, it's not the transmission.
  5. acarapella
    82
    Rochester NY
    Lol yea that’s good news. A new Axel
    Will
    Help?
  6. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    It's a weird issue. My car only does it when I'm slowing to a stop and turning right at the same time. And only on one particular exit ramp where the conditions are just right. Replacing an axle might provide some relief, but the problem has reemerged for some who did that, so it's not a guaranteed fix. After all the research I did, I decided to do nothing.
  7. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    I'm working on the same issue myself in a 2011. But I do believe it's the transmission. Final differential I believe it is. I will be putting new drive shafts in. The rest of the suspension is new because I didn't think it was the transmission. Everything else is replaced with no change so it has to be. I kinda think it's this pin that has some play in it that it shouldn't have. I'm currently waiting on a ride to get yard transmission and will see if there is play in that one. IMG_20221114_100941.jpeg
  8. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    That's interesting. What are the specifics of your car's symptoms. Has there been any change in the clicking noise since you first noticed it?
    Check out this video at the 1:06 mark
    And this one at 1:15
  9. Raphael Muscarelle
    661
    222
  10. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    No....that's a completely different issue. It sounds like this......
  11. Raphael Muscarelle
    661
    222
    Yeah that's different.
  12. Michael Wood
    181
    118
    Boston, MA
    2020 Prius Prime
    The car in the video I posted last is an extreme example. For most people it's barely audible...you can only hear it with the radio off, and it's frequently not fixed by axle or suspension part replacements. And it usually only happens at slow speeds when stopping while turning left or right.
  13. Raphael Muscarelle
    661
    222
    Funny I changed my transmission and drive shaves. Now I have this noise.
  14. Raphael Muscarelle
    661
    222
    Well that's not good because now I have that problem with new axels inner is shaped differently tho. I was thinking it is hitting transmission housing. I'm gonna see if that's the case tomorrow.
  15. Raphael Muscarelle
    661
    222
    You ever try to put spacer on lugnuts. Maybe the tire isn't being clamped on tight enough.
    I just had that noise cus I forgot to tighten the lugnuts.
