The Dreaded First Oil Change
Discussion in 'Gen 2 Prius Main Forum' started by daveleeprius, Apr 24, 2007.
  1. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    Hello,
    Our 2007 just turned over 4,000 miles and I am beginning to wonder if I should have the oil changed. They say "5,000 miles or 6 mos." whichever comes first. We bought in October last year so it's been six months.
    And I'm worried about over filling. I don't want this car damaged. I can communicate this to the service advisor, to only put in 3.8 quarts of oil, not 4, but who is to say if the grease monkey who gets their hands on the car will give a crap? Probably won't. And I don't want to do it myself, I've no garage to work on the car and frankly, I don't want to work on cars if I don't have to. I make enough money now to afford to pay a mechanic and that's what I do. Our dealer is Toyota of Bellevue which is closest to our home.
    The other thing is lately we've noticed the brakes are making a light squeaking sound when we apply them, reversing out of our carport, and also making a stop when moving slowly. Is this something to worry about or should I just ignore it for now? The brakes are wonderful and I am not concerned. Just the noise.
    Thanks all!
    Dave in Seattle
  2. jamarimutt
    jamarimutt New Member
    985
    I change the oil every 5,000 miles. I tell the mechanic to pour in 3.5 quarts of 5W-30 and take home the remaining half quart. For the next oil change I bring in my half quart and pay for three quarts.
    Oil changes are really not a big deal, there's really not much to worry about. If the engine holds normally 3.9 quarts, even pouring in a full 4 quarts is not going to damage anything. The Prius is not such a delicate car.
  3. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Hey Dave...
    ... don't get too uptight. Just make sure your dealer or independent mechanic understand your instructions and install NO MORE than 3½ quarts. Even 3 quarts would bring the level to about halfway between "full" and "add" and be safe for your ICE. I warned my dealer that if they overfilled, I would have them remove the excess... they have never overfilled BECAUSE I take them 3½ quarts of Mobil-1 5W30 and they use my oil.
  4. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    well, this could go in a number of directions, but let's say there are literally tens of thousands of prius out there with the spec 3.9 quarts in the crankcase, owners completely unaware it's over the fill line, that still run without a problem. so don't worry about that too much.
    and if you can afford to pay the grease monkey, maybe you could afford a little respect for him too. how about you let him give you a reason for the denigrating descriptor before using it? some deserve it but let's not generalize, hm?
  5. priussoris
    priussoris New Member
    1,005
    Another thing is to CHECK IT BEFORE YOU LEAVE THE DEALERSHIP
    and tell your salesman also about not wanting it over filled, because he makes his money from you and your referrals.
    and next talk with the service dept. and get a feel of how they operate.
    If it is overfilled when YOU check it have the service dept pull it back in and drain to proper level
    I too will be doing all of this soon myself now have 3900 miles
    good luck should be no problem
  6. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(DaveLeePrius @ Apr 24 2007, 02:49 PM) [snapback]429209[/snapback]</div>
    I like how you imply that the "service advisor" cares about your car. Maybe it's just me, but I'd trust a mechanic over most people who work "up front" at a dealership any day of the week.
  7. Earthling
    Earthling New Member
    441
    Somewhere, NY
    <div class='quotetop'>QUOTE(galaxee @ Apr 24 2007, 05:07 PM) [snapback]429282[/snapback]</div>
    Fair enough, but it sounds like you've never had to have an oil pan worked on to fix a leaky drain plug caused by a careless mechanic. I've had to have threads recut and use an oversized drain bolt. I've also had the corners of a drain bolt rounded off.
    The problem is, you can never tell who is the conscientous, careful mechanic, and who is the grease monkey until it's too late.
    That's why I change my own oil.
    Harry
  8. galaxee
    9,810
    466
    MD
    <div class='quotetop'>QUOTE(Earthling @ Apr 24 2007, 05:33 PM) [snapback]429303[/snapback]</div>
    the rounded off drain plugs must've been in GM cars, this happens about never with toyotas.
    DH makes a substantial part of his living cleaning up after idiots. how's 45 hours rewiring someone's camry thanks to the brainiacs at meineke sound? i'm not saying everyone's perfect, given the above-mentioned occurrence along with many more that keep him working late all the time. but to call someone a grease monkey based solely on what they choose to do for a living strikes me as a snotty a-hole thing to say.
  9. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(galaxee @ Apr 24 2007, 07:56 PM) [snapback]429498[/snapback]</div>
    What did they do? Take a torch to the wiring harness?
    Dave M.
  10. zeeman
    zeeman Member
    211
    that is a nasty thing, to call a mechanic a "grease monkey"!
    there seems to be only 2 options for you;
    A: if you do not trust mechanic/shop, why not do it yourself?
    B: if you do trust a mechanic/shop then pay them to do what you are either unwilling or incapable of doing yourself
    brakes on prius do that occasionally, but fix is very simple.
    search the archives here as how to fix this problem
