The ECO mode gives me more precision
Discussion in 'Gen 3 Prius Main Forum' started by Troy Heagy, Jun 10, 2014.
  1. Troy Heagy
    Troy Heagy Member
    1,218
    I find I like running the Eco Mode best in my Prius, as it gives me more fine-tuning on the throttle pedal. That of course helps keep the engine at its lowest power setting, and boost MPGs. It's a bit tricky but worthwhile.
    I think there's zero need to switch to power mode for acceleration.
  2. Mendel Leisk
    38,727
    I'll jump in, with the other side of the debate:
    I found the pedal travel excessive, really a work out, like a long throw gear shift.
  3. Troy Heagy
    Troy Heagy Member
    1,218
    Actually it feels like my 3-cylinder insight. I have to really push the pedal to the floor to get acceleration & the Prius in Eco mode is the same. (Which is why I like it..... saves gas.)
  4. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    I feel guilty when I accelerate the gas pedal
  5. Troy Heagy
    Troy Heagy Member
    1,218
    I feel guilty when I press the brake. (Wastes momentum & energy.) :D
  6. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    Always in the ECO mode for over a year. I did feel guilty twice hitting the accelerator too hard and starting the ICE on a short trip.
  7. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    Agreed. I rarely use eco mode, interestingly enough, I find that I can take the car just to the threshold of ICE kicking in more accurately in Power mode. Not to mention its better if you pulse & glide, get up to speed with less effort and lay off the gas.
    I drive in normal mode most of the time, Power on highways. My wife drives in power mode 100% of the time. Might not get the absolute best mileage, but we drive it like a car. Could care less about squeezing an extra couple miles out of the tank by babying it.
  8. alexcue
    alexcue Active Member
    346
    311
    So Cal
    My only problem with the Eco Mode is that pedal travel, but that's because i switch from a Toyota Tundra V8, a couple of times a week. The throttle response is so different, and the launch characteristics off the line are so different. It takes me a few minutes to get used to it again.
    I do agree, it does make you feel guilty when you mash down the accelerator.
  9. engerysaver
    engerysaver Real Senior Member
    426
    130
    Tyler, Texas ; USA
    I don't feel guilty;); passing up those gas stations!!:cool:
    Eco Mode is the BEST for better MPG.(y)
  10. zhenya
    zhenya Active Member
    649
    209
    Ithaca, NY
    2013 Prius Plug-in
    I drive in Eco mode all of the time as well. I also appreciate having a lot of pedal travel as opposed to most new cars in which you have to control 80% of the acceleration with the first 20% of pedal travel.
  11. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I feel guilty about not feeling guilty about anything.:)
  12. budrow56
    budrow56 Junior Member
    45
    I just purchased a used 2012 prius v with 44k and I have driven 850 miles last week. The Eco mode is it's default mode. Unless I change it.
    iPhone ?
  13. CaliforniaBear
    1,179
    289
    Northern California
    Its not a default mode. When you start the car it will remember the mode from the previous trip. Turn it off, it will stay off. However, many consider it to be the best mode for accelerator control and mileage.
  14. El Dobro
    El Dobro A Member
    6,979
    3,214
    Unless it's in Power mode when you shut down.
  15. CaliforniaBear
    1,179
    289
    Northern California
    Oh... that's interesting. I've never used the PWR mode.
  16. Prius-Paul
    Prius-Paul New Member
    16
    Ecomode feels to mushy on the pedal.
  17. CaliforniaBear
    1,179
    289
    Northern California
    Its working correctly :)
    fuzzy1 likes this.
