the electric battery or traction battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mindi renee, Nov 23, 2013.
  1. mindi renee
    mindi renee New Member
    West Odessa, Texas
    We were driving down the road and the car lost power we first thought we ran out of gas kind of funny I know but it has happened.. anyways in the display screen it flashed a warning about the traction battery .. I tried to start it and nothing exsept all the warning lights came on but wouldn't start still won't start and I'm pretty sure its the electric battery and of course just like most things it says take it to your Toyota dealer is there any way to charge or fix it without having to take it in ...also I read the the electric battery has a warranty of 8 years or 80,000 miles and mines only three years old .. my car sadly to say isn't under warranty but the battery still should be does.anyone know if they honor that at the Toyota dealers...
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Your car has 3 Batteries:
    A NiMH High Voltage battery, often called the Traction Battery. It has a 100,000 mile/ 8 year warranty in your state.
    A Lead Acid 12 volt battery sometimes called the accessory battery. I doubt it has any warranty left. It is the most likely at fault, below are some places to buy one.
    There is a CR1632 in the Fob, it has no warranty. (but I doubt it is at fault in your scenario)
    Optima DS46B24R Optima battery direct fit replacement for Prius 2004 + , Prius V & Plug-in Prius with Instructions
    Exide AGM Car Battery (Group S46B24R)
  3. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Fob battery is CR1632, agree though that this battery is unlikely to cause symptoms encountered by OP.
    SCH-I535
  4. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    It sounds like it could be an inverter failure which I believe is covered by a 8 year 100,000 mile warranty
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    You need to take it to your dealer and have them look at the Diagnostic Trouble Codes (DTC) and troubleshoot the problem. Depending on the fault codes they will be able to tell you what the problem is and whether the failed component is covered under warranty or not. If it is covered under warranty they should be able to repair it at no cost to you.
    If it is not covered under warranty they will give you the cost to repair. In this case you will probably want to post the DTC's here and find out what your options may be to help save some money.
  6. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I had my inverter fail on me. The engine wouldn't start but the car would crawl on ev, well until the battery ran low - no engine to charge it back up.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Make sure you get a copy of complete list of all the codes it has thrown. They will look like PXXXX-XXX.
    The check engine lights will store these codes telling the dealer exactly what the car was unhappy about. This may prove very helpful TO YOU if it turns ugly like dealer blaming you that you ran out of gas for instance and caused traction battery to fail (OOW) and you did not. The codes will tell us and you what really happened.
    Seen many stories here about what started as simple IW repairs gone stupid by incompetent dealer techs. The usual being they can't figure it out and start throwing very expensive parts at it on your dime.
  8. jani chat
    jani chat New Member
    New York
    I have a 2005 Prius (love it) and I'm getting ready to replace it with a new one. My concern is that I travel for extended periods and I'm worried about the battery going dead while I'm away. Considering getting a different vehicle unless I can figure out how to prevent the battery from going dead.
  9. Mendel Leisk
    40,584
    Assuming you'll be parked somewhere secure with electrical outlets, get a lowish wattage smart charger, something you can leave hooked up indefinitely. There's nothing all that different about the Prius, any vehicle can get a run down 12 volt battery, if it sits too long. OTOH, the capacity of the Prius 12 volt battery isn't that good.
  10. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    Is it the large high-voltage traction battery you're worried about, or the 12-volt battery? The former will probably be OK, unless it's already on its last legs, or your absence is very long. As for the 12-volt, do what Mendel suggests, or disconnect it.
  11. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    To the OP, DO NOT mess with the traction battery! It IS on warranty unless you mess with it!
    Yes, you will have to get the car towed to a dealer. No, the traction battery can not be charged by you. It's a 200V battery and can be very dangerous if you don't have the proper equipment and training.
    If you ran the car out of fuel you will have to pay for at least some portion of the repair. If you didn't it will probably be covered.
    To Jani, you can purchase a "Battery Tender". It is designed to be left on a 12V lead acid battery for long periods of time, such as over winter (motorcycle and ATV use). It WILL NOT damage the battery. You will need to plug it in to 115V AC. You can connect it to either the battery or to the "boost terminal" under the hood. I use one every winter on Pearl S.
    Most modern cars will have problems with the 12V battery if left for periods longer than about 1-2 months. They all have lots of "parasitic loads" that will drain the battery. While the Prius has a rather "small" 12V battery, there are other cars that do as well.
    Your second option is to install a battery switch. Put it in the line on the negative terminal. You can then disconnect the battery. The downside to this is you will loose all programming in the car. Things like radio stations, the state of the cars backup beeper, the auto window rolldown settings. Most are easy to set, particularly if you have the GPS screen. You will also loose any codes that the car detected. This can be good or bad. ;)
