The end of fuel
Discussion in 'Toyota Hybrids and EVs' started by drpiskorz, Mar 22, 2016.
  1. drpiskorz
    drpiskorz New Member
    PL
    Hi. What is the risk of lack of fuel in Hybrid Auris? service alert? thx
  2. Mendel Leisk
    38,728
    I totally thought this would be a deep discussion on our dependency on oil, what the future holds, lol.
    Kramah313, fotomoto, fuzzy1 and 2 others like this.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    All fuel injected vehicles hate running out of fuel, they expect to be metering a liquid and produce incorrect mixtures when metering air.
    So far as I know, all electric fuel pumps in the gas tank use the gasoline as a coolant, and may overheat if you run low on petrol.
    If you run out of gasoline in a Gen 2 Prius, you need to add 3 gallons before the computers admit you have added any. (even if you don't run out, putting under 3 gallons may not show as adding any)
    If you try to start your Prius with no gas more than 3 time you will set a computer code that needs to be reset, at the dealer, after a tow.
    When you run out of gas, the computers quit being able to make the best choice between gas and electric and can run the High Voltage electric battery below the state of charge needed to start the engine. If this happen it needs a 201 Volt battery charger neither you nor the dealer own. The y will need to borrow one from Toyota regional after they tow your car to the dealer.
    If your spouse or worse your in laws are in the car when you run out of gas, expect 50 years of ridicule.
    Other that that, not much.
    #3 JimboPalmer, Mar 22, 2016
    fuzzy1 and Mendel Leisk like this.
  4. drpiskorz
    PL
    Haha. Ok 50 yrs is too many. I will not risk! Thank You
  5. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    If it's an older car, expect that as it sucks up the last of the fuel in the tank that it will also pick up sediment of various sorts.
    It was a pre-fuel injected car, but it cost me 3 fuel filters and a carby clean-out before the fuel lines came clean again.
  6. drpiskorz
    PL
    Its new one. 3kkm
    alanclarkeau likes this.
  7. Trollbait
    11,561
    I know the gen2 Prius gave a non ignorable warning when the tank went empty with instructions to pull over. It was possible to continue driving at low speeds on the battery pack alone, but this risked drawing the charge down too low and damaging it.
    drpiskorz likes this.
