The Ethanol Effect -- Any solution?
Discussion in 'Gen 2 Prius Fuel Economy' started by Reinventor, Feb 6, 2011.
  1. Reinventor
    Reinventor New Member
    I recently moved from AZ to CO and my MPG went from 50 mpg on city streets to 30-35 mpg on city streets and easing up on the pedal does not seem to have any effect as it previously had. I've been told, and believe, this is because of the effect of the Ethanol additive in the gas here. Is there any solution to bring my mileage up closer to what I'd been getting? Would higher octane help? A particular brand? Some counter-additive I could add?
    Thank you for any suggestions.
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Winter is far more likely the cause than ethanol.
    I easily get 50 MPG in the Summer using E10. But not in the Winter.
    But when Winter arrives, the colder temperatures, the lower humidity, and the formula change of the fuel all cause an efficiency drop. Combine that with the natural loss of PSI in your tires and demands of the heater, you've got a recipe for much lower MPG.
    Check your tires. Block your grille. Pray for an early Spring.
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can only blame ethanol for a 3% drop in MPG (10% ethanol with 30% lower energy content). As usual, John is correct. You can compensate a bit for the colder weather by:
    1. Make sure that your tire pressure hasn't dropped. It always does in cold weather unless you pump more air into the tires.
    2. Install a higher temperature thermostat to maintain the engine temperature in cold weather.
    3. Install and use an Engine Block Heater. There are provisions for one in a Prius and they are common in Canada.
    4. Read up about "Grill Blocking". Just make sure that you instrument your Prius to track Engine and Inverter temperature if you do limit air flow in cold weather.
    JeffD
  4. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Ditto the previous posts. Tire air pressure at 42/40. Grill blocking improved my mileage almost 10 mpg.
    However, I was in a Home Depot a few weeks ago advertising an additive to counter-act ethanol for small engines like lawnmowers, but I didn't check it out. When I went back, the display was gone. Anyone know about this?
  5. richard schumacher
    7,664
    1,043
    United States
    If you can stand the cold, not using the cabin heater can noticeably increase MPGs. Of course always use the defroster as needed for safety.
  6. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    I just bought my '04 in Decmber and was only getting 42 MPG. Grill blocking, 44/42psi tires and careful driving has got me over 50 MPG now in mild winter temps.(45F)
  7. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  8. fuzzy1
    10,335
    As already pointed out, ethanol can't have that much impact.
    Please answer the questions at Fuel economy complaints/queries? and post them here. That will give us many more clues.
    If your typical new driving conditions are colder and for shorter distances, mpg will get clobbered.
  9. richsc
    richsc New Member
    59
    Washington DC
    What altitude in Arizona and what in Colorado? I have no idea if that is a factor though.
  10. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    I have used a product in my small gas engines called Star Tron by Starbrite. It claims to combat the effects of ethanol in fuel, I have not used it in my car yet. We have E10 fuel here and I am averaging in the mid 50's so far but I do not have the cold or winter blend fuel to contend with either.
    Star Tron Enzyme Fuel Treatment - Star Tron Story
    There are a few ethanol fuel threads/posts already try searching those, others have reported using Star Tron.
  11. rpeeples
    rpeeples Experienced Toyota Owner
    109
    America's own third-world country
    Ethanol-tainted fuel has caused me a lot of problems, gas mileage being the least. I have a '91 Toyota Truck that has been pretty much ruined by ethanol-tainted fuel. I am trying to figure out how to convert it to EV at a reasonable price at the moment. Then the whole idea of ethanol-tainted fuel will have back-fired on those that have pushed it on all of us just so they could make a few more dollars.
    If there is a lawsuit against the fuel industry, or whoever is pushing this crap, please let me know. I would be very happy to have my name on the list of plaintiffs!!! :mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad::mad:
  12. fuzzy1
    10,335
    Altitude, by itself, actually helps mpg slightly, though less on Toyota and Honda hybrids than on traditional cars.
    Hills and mountains are a separate issue, and the results are highly dependent on the particulars of the situation.
    The defendants will be congresscritters, legislators, and government administrators who have immunity as part of their job function.
  13. rpeeples
    109
    The ultimate oxymoron, government intelligence....
  14. richard schumacher
    7,664
    1,043
    United States
    Toyota designed the Prius to work with E10. There's no point in getting bent out of shape because of a story about a car from 20 years ago.
  15. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    E10 = water magnet with gas. Also E10 is driving up food prices due to increased corn consumption to make E10 (check out todays' USA Today for more info).
    I use eithe Star Tron or Seafoam for moisture issues with E10. Using either of these products hasn't led to an increase in mpgs.
    DBCassidy
  16. richard schumacher
    7,664
    1,043
    United States
    If the OP doesn't have any water problems then additives would be a wasted expense. His MPG drop is almost certainly entirely caused by the colder weather.
    If it helps, think of E10 as getting a continuous dose of injector cleaner.
  17. eleme
    eleme New Member
    CO
    I live in CO and my average dropped quite a bit this winter. 43 down to 38 (really cold + snow tires, not to mention there's a large [taxi] light on top that adds to the drag). CO is also quite mountainous, if you live in/near the front range at all.
    Fuel additives don't help because it's so dry here anyways. I would recommend, however, that if you're using a higher octane fuel to come down to 85. There's no added benefit to using the higher octane at higher altitudes.
    Haven't tried air blocking to keep the engine compartment warm, and I'm not sure about the tire pressure measurements of the snow tires, but I'll be sure to check it out. I could REALLY use any extra MPG i can get!
  18. wrxsubiemod
    wrxsubiemod port and polishing Specialist
    36
    name where u like it
    wow all this talk about ethanol makes me want to chime in a little. Most gas stations state up to e10. During different seasons gas company's change how much actual ethanol they add to. colder seasons its very low because of hard start/drive ability issues associated with alcohol.
    I am a 8 year EV tech. I build and help design EV vehicles for the government and I can tell u that Batteries do not like cold weather. We have seen 50% decrease in electric vehicles millage just due to cold weather! I know Prius is a hybrid and it will compensate for this by keeping the engine on a little more. to combat most cold weather situations most people actually use a battery blanket to keep the batteries warm and keep their charge up and batteries happy. E10 is really not an issue because Toyota did design the prius to run that type of fuel, where most gas says up to E10.
    I hope this helps
