The fun begins!! Swap time.
Discussion in 'Gen 3 Prius Main Forum' started by FnRedPrius, Mar 9, 2019.
  1. FnRedPrius
    FnRedPrius Active Member
    100
    121
    Pilot, NC
    Okie Dokie, here we go. Jumped in while I can. Between work, dealing with county permitting, spec'ing a new rental doublewide, and life in general I gotta just jump.
    My shop isn't big enough for the entire car to fit, so I had to use furniture pads to close off the opening, and as far as pulling it, only thing wrong was I should have jacked it up farther to get a better view, but having grown up in a Ford dealership 40 some years ago I learned to work by feel. The hardest part was getting some of the connectors off but the good part was having the OEM harness to look at the connectors. l little less than 5 hours to pull after I got started with it.
    The surprise was how much the oil reside had accelerated on the front of the engine. The oil pan was totally covered in oil, and I just changed the oil three weeks ago and have only ever just had to wipe off the oil plugs chin, but never any oil in 5K changes.
    I'll have to take the intake and clean it later today when we run errands. I'm pretty shocked by the amount of crud that has already accumulated since I cleaned it. Next is cleaning up the engine compartment and wiring harnesses.
    RMB, The Critic, Montgomery and 2 others like this.
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    You just blew my mind with your space saving design of the garage blanket... I'm literally sitting here kicking myself for not thinking of that sooner...
  3. iceman13
    iceman13 Member
    134
    102
    US
    2014 Prius c
    What was wrong with the old engine?
  4. FnRedPrius
    100
    121
    Pilot, NC
    I mis-posted this on here rather than the Gen III forum where it belonged, but it had been a long day.
    Ours started with the severe misfires and shaking while in heavy traffic. After cleaning the totally clogged EGR and intake system, the symptoms reduced to random misfires, bad stumble at start, loss of coolant, the smell of coolant steam and steam from the exhaust. The coolant loss amounts have varied, but what was strange was the week that we were in Florida ( 3rd week of Jan) we towed it down and back) but it went through almost a gallon of coolant while there, and hasn't had to be refilled since we got back. We still lots of crud getting into the intake, but the exhaust port on cylinder #2 is much cleaner. Evidently it a head gasket failure contemporaneous to the EGR clogging which seems to the extremely common on the Gen III engines. I wanted to hold off on the swap until it turned over 250K miles, but 248K will just have to do. The replacement is a Gen IV with 5800 miles.
    #4 FnRedPrius, Mar 11, 2019
    RMB, Mendel Leisk and iceman13 like this.
  5. Mendel Leisk
    41,457
    Gen IV? ;)
    Yeah it seems like clogged EGR makes for higher engine temperature, which is stressing the head gaskets.
  6. FnRedPrius
    100
    121
    Pilot, NC
    Thanks for catching that. I'm going to rebrand it as a Gen III.V
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Any update on the swap?
    SFO, RMB, Montgomery and 4 others like this.
  8. Mendel Leisk
    41,457
    Thank god somebody remembers. (y)
    Montgomery and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    @The Critic is like an elephant: he never forgets(y).
    The Critic and Mendel Leisk like this.
  10. spiralhelix
    spiralhelix Active Member
    255
    217
    Illinois
    you are a genius with the blankets. Thankfully my current garage has plenty of room, but this would have been baller for me at my last place.
    ztanos likes this.
  11. FnRedPrius
    100
    121
    Pilot, NC
    The swap went well. Took longer than it should, but me being me, I re-wrapped the wiring harnesses since the OEM wrap wasn't too fond of brake kleen. Plus I had to deal with life for a few days. It's been great and is almost due for the first oil change. The next one I'll send in a oil sample.
