The Geopolitics of lithium batteries
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Doc Willie, Aug 17, 2009.
  1. Doc Willie
    1,717
    144
    Out there, somewhere
    [​IMG] Global Economy: The Geopolitics of Car Batteries
    August 17, 2009 | 1157 GMT
    TOSHIFUMI KITAMURA/AFP/Getty Images
    A cutting model of a Toyota Prius hybrid vehicle’s battery module on June 5
    Summary
    As hybrid vehicles become more popular, vehicle manufacturers will seek more sources of lithium to produce car batteries. Lithium is the most efficient raw material for battery production, but there are only a few lithium deposits in the world — mostly in South America. As demand for the mineral grows, those countries with large lithium deposits, such as Chile, will play a larger role in the global economy.
    Analysis
    As global concerns about energy security and carbon emissions skyrocket, hybrid vehicles, which combine electric and gasoline power sources, are capturing greater market share and global attention. Incorporating a source of electricity into a car requires a battery — something for which several different raw materials can be used. Lithium is the most efficient raw material used in batteries, but the number of lithium deposits in the world is limited; most are found in South America. As the market for lithium grows, countries with large lithium deposits will become more important to the global economy. Countries with the technology to process lithium and manufacture batteries will also become more significant.
    The current standard material for high-powered rechargeable batteries for hybrid vehicles is nickel metal hydride (NiMH). Australia has the world’s largest proven reserves of nickel, but Russia, Canada and Indonesia are the largest producers. With such wide distribution of easily accessed nickel deposits, an interruption in the supply or manufacturing of NiMH for batteries is relatively unlikely. NiMH batteries are quite expensive, but presently they are more cost-effective than the lithium-ion batteries being developed to replace them. For now, NiMH batteries will remain the standard (even the new 2010 Toyota Prius relies on NiMH batteries).
    However, lithium-ion batteries will become the standard in the near future. Underpinning this shift is the simple fact that NiMH batteries are heavy and their energy per unit of mass is approximately half that of a lithium-ion battery. Though lithium batteries are effective, the industry has yet to develop a way to mass-produce them at the scale the automobile industry requires. As soon as the manufacturing technology becomes available, every car company in the world will be able to use lithium batteries. Carmakers are ready to shift to the lighter lithium batteries because they would boost vehicle performance.
    The Making of a Lithium Battery
    Lithium can be obtained in small quantities in the form of lithium chloride (LiCl) from just about anywhere in the world, but concentrated deposits — called salares — are found only in a few places. Salares result when pools of salt water, which contain LiCl, accumulate in basins that lack drainage outlets, allowing the water to gradually evaporate and leave dense layers of salt behind. Underneath the dried salt layer is a layer of brine — groundwater with a high concentration of LiCl in solution. It is this brine that is highly prized as a source of lithium.
    For a lithium deposit to be commercially viable, it must have a large amount of lithium that is not contaminated with too much magnesium, and it must be in a location where natural evaporation will concentrate the watery solution where LiCl is normally found. Factors that contribute to increased evaporation include low air pressure found at high altitudes, low precipitation, frequent winds, high temperatures and exposure to solar radiation. Thus, commercial lithium deposits are found along volcanic belts in the earth’s desert regions.
    The process of harvesting LiCl exploits the same natural process that initially created the salt flat — evaporation. Brine is pumped from beneath the crust into shallow pools on the surface of the salt flat, where it is left to bake in the sun for about a year. During this period, the LiCl becomes more concentrated as the brine is reduced by solar radiation, heat and wind.
    To be used in a lithium battery, however, the LiCl must first react with soda ash to precipitate lithium carbonate (Li2CO3), which can then be processed into metallic lithium for use in making a battery’s cathode. This usually takes place at off-site chemical processing plants, making it necessary to transport the lithium by tanker — something that becomes economically viable only after the lithium solution is sufficiently concentrated. Thus, the rate at which the water evaporates is quite important for economical harvesting of lithium, and it also influences the size (and therefore the environmental footprint) of the solar ponds required to achieve economic concentrations.
    After the lithium is extracted, it must be processed for use in batteries, and only a few producers have the required capital and capacity to manufacture lithium batteries. Currently, most companies that can supply lithium-ion batteries for vehicles are joint ventures between auto manufacturers and technology firms. Of these, seven are based in Japan, two are in the United States, two are in Korea and one is in China. These few producers rely on even fewer suppliers for the components — primarily the anodes, cathodes, separator and electrolytic salt — of lithium-ion batteries. The most specialized step in the process is the production of the electrolytic salt used in lithium-ion batteries. That salt (lithium hexafluorophosphate) is produced only in Japan at two complexes, one in Okayama prefecture and the other in Osaka prefecture.
    Lithium’s Geopolitical Power
    An estimated 70 percent of the world’s LiCl deposits are found in South America. Chile is the world’s largest producer of LiCl — not only because Chile already has highly developed mining, transport and processing infrastructure, but because its climate and geography are favorable for the evaporation that is central to producing lithium.
    The Salar de Atacama is located in the Atacama Desert, which receives almost no rainfall and has high winds, low humidity and relatively high average temperatures. Together, these features make the Salar de Atacama the second-driest place on earth, after Antarctica.
    Argentina has the world’s third-largest estimated lithium reserves. Argentina’s Salar de Hombre Muerto’s average elevation is nearly twice that of Salar de Atacama, but what it gains in altitude it sacrifices in net evaporation. Though its evaporation rate is only about 72 percent of Atacama’s, Salar de Hombre Muerto is still commercially successful because costs are low and are further offset by the sale of recoverable byproducts like boric acid.
    Bolivia produces no lithium, though it is sometimes called “the Saudi Arabia of lithium” because its still-untapped salares are thought to contain nearly 50 percent of the world’s estimated lithium reserves, most of which is found within the brines of the vaunted Salar de Uyuni. Attention to Bolivia’s reserves has increased strongly in recent years, with South Korea, Japan and France showing particularly strong interest (China is rumored to be interested as well). However, having a resource does not mean it can be brought to market at a reasonable cost.
    Uyuni’s higher rainfall and cooler climate means that its evaporation rate is not even half that of Atacama’s. Achieving the necessary concentrations is further complicated because the lithium in the Uyuni brine is not very concentrated, and the deposits are spread across a vast area. Uyuni also has a high ratio of magnesium to lithium within the brine, which means the magnesium must be removed through an expensive chemical process. This is something Chile has handled with relative ease, but Uyuni’s deposits have three times the magnesium concentrations of Atacama’s, making investment in Bolivia’s deposits much less economical.
    Bolivia also lacks established infrastructure, and any serious investments in Uyuni would require extensive spending upfront on infrastructure development. Combined with the highly unwelcoming investment climate in Bolivia, there is no guarantee that the country will be able to attract the massive investment necessary to develop its reserves, despite the rise of global interest in lithium. It will be difficult for the Bolivian government to achieve its goal of becoming a center of lithium processing. This is not to say that Bolivia could never be a major lithium producer, but in the short- to medium-term, Chile will continue to dominate global lithium markets.
    Growing Market Share, Growing Importance
    Because of the high level of specialization currently required in the lithium battery market and the limited number of sources for the materials, the growth and stability of the market depends heavily on a few manufacturers. In part, this is a result of the high levels of capital investment needed to develop and supply the batteries at scale. However, as car manufacturers begin to ramp up production of hybrid vehicles, the demand for lithium batteries will increase. Higher production will likely help reduce the cost of each individual battery, and opportunities for prospective manufacturers will increase.
    The shift toward lithium-ion batteries will not be immediate, but lithium batteries will become more affordable as car manufacturers seek to increase vehicle performance while reducing gasoline consumption. This means that Japan’s technology centers and Chile’s lithium mines will become increasingly important to the global economy.
    Tell STRATFOR What You Think
    For Publication in Letters to STRATFOR
    Not For Publication
    Terms of Use | Privacy Policy | Contact Us
    © Copyright 2009 Stratfor. All rights reserved.
    6 people like this.
  2. Rybold
    Rybold globally warmed member
    2,760
    322
    Southern California
    Nice post!
    I think we should invade Bolivia, Chile, and Argentina right now. :D
    I'm going to make a prediction for the distant future: Expensive luxury cars will have lithium batteries. Mid-priced cars will have NiMH. And "econo" cars will have to make due with lead-acid or (a future new technology that replaces lead-acid). Countries will keep a very close control over used-car exports out of the country. If you want to sell your used car down in Mexico, Uncle Sam is going to charge you a penalty.
    "An estimated 70 percent of the world’s LiCl deposits are found in South America."
    In the near future, I see a political battle between the United States versus China to buy lithium from South America. We need to hurry up and sign contracts with Chile and Argentina for future deliveries. And, we need to convince them that it costs less to transport and sell their lithium in North America than it does for them to ship it all the way over to China. But wait, what about India? Exactly. This is why we need to get moving ASAP!
    There is one VERY IMPORTANT item missing from this article: If all of the "proven" and "estimated" lithium was converted into car batteries (today's technology), how many car batteries could we make? (assume the average battery for a PHEV) Five million? Ten million? Thirty million?
    And let us all not forget: Lithium is not the only battery technology. We can still use NiMH to fill in the gap. All of a sudden, mass transit seems to make much more sense. One EV train, one track, millions of people using it every day. Think: London.
  3. martinw
    martinw New Member
    49
    North Hollywood, CA
    One thing that is glossed over in the purely economic analysis in the article is that the Lithium in Bolivia is in a place called Salar de Uyuni which is a spectacularly beautiful region:
    Salar de Uyuni - Google Images
    It would be a pity if large scale commercialization destroyed parts of it.
  4. jestoy7
    jestoy7 New Member
    238
    25
    Jacksonville, FL
    I agree with you. My family is half Venezuelan and half Bolivian and it would be a waste if that region of the country gets destroyed. I hope that the current governments get ousted (Chavez and Evo) and that compentent people headway those projects to ensure that the region, communities and environment are well taken care of as they extract the lithium.
  5. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    As a Management Scientist I believe we will see an increase of management methodologies applied to global resource and environmental issues. This goes beyond the current exploitation of resources by large corporations moving into third world countries or EPA-type attempts to manage the ecology. Papers like this one show that there are geopolitical ramifications of practically everything we do, including our choice of car.
    I predict that to make the extraction of lithium more viable some form of mechanical extraction will be applied to the brine (to replace simple evaporation pits). This would lead to industrialization at the site of the deposit, requiring all of the usual infrastructure/energy that this would imply, and requiring ecological control/management of the resulting processes. This is not new technology - it is currently used to extract minerals from sea water, among other applications.
    Eventually new forms of energy storage will replace lithium cells. Eventually the physical limitations at the nuclear level will become the limit of energy density in electrical storage (I read a great article on this - a battery increases in size as electrons are placed into it, and at the mollecular level there is a limit where the substrate begins to break down as the atoms "swell" with the added mass of electrons). That limit isn't that many orders of magnitude away from what we have now.
    The eventual solution might be broadcast power, or some quantum form of energy storage that does not use electrons added to molecules (at least not in this universe). So all geopolitics relating to materials is limited to the lifetime of the technology that needs the resource. This is as true of oil as it is of lithium. These changes in global demand and supply continue to move money and power from region to region as technology advances. Such movements have been accelerating since the beginning of the Industrial Age, and will continue to accelerate, meaning market demand will shift faster and faster, moving capital around the globe into previously poor areas at an accelerating rate. Such demand acceleration makes management of resources and the ecology harder and harder.
  6. bluetwo
    bluetwo Relevance is irrelevant
    186
    Augusta, GA
    A considerable economic shift and growth in South America? I say good because at least those guys having been trying to cut each others heads off for the last 2,000 year and maybe the migrant workers will go south to find jobs instead of north, illegally. I know that's a simplification but I wanted to see who would debate it.
    This seems like a surge in a different direction that has probably come as a surprise to a lot of people. I mean surely the needed processes will be sorted out and the manufacturing facilities will be open up; it's just a matter of time, right?
    Reading that article led me to think about all kinds of underhanded political moves and maybe even militarily related incidents.
  7. UsedToLoveCars
    UsedToLoveCars Active Member
    448
    102
    The lithium in batteries can be recycled.
    Any comparisons to oil completely miss this point, since of course gasoline does not get recycled.
  8. Trollbait
    12,351
    What is the recycablity rate of the lithium in batteries? I've heard it isn't 100%, meaning some of the lithium is lost during the recycling process. It be as low as 20%.
    We also need lithium for things besides batteries.
