The Guess Gage
Discussion in 'Gen 2 Prius Fuel Economy' started by icharry, Jan 7, 2007.
  1. icharry
    icharry Junior Member
    27
    Los Angeles
    Ok, I know this has been talked about alot... I just filled up for the 2nd time... the 1st time I only got like 8.2 gal in, but I added gas within a mile of the gauge going down to 1 pip... today I waited till I had gone about 30 miles after it dropped to 1 pip ( I wanted to wait till it flashed, but I had a long drive ahead and did not want to stop)... and only got 8.6 gal in!!!!
    That is crazy! That means there was over 3 gal in the tank - 25% left thats an extra 100 miles.... is there any aftermarket thing that can make this a bit or WAY more accurate?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    CAN-View will give you a "tank %" full level if it's that important to you. I suggest just adapting to the system as it is. You'll get used to it. Even with only 8-9 gallons you should be able to go 450-600 miles per tank once you get your mpgs up...and that will come.
    I've, personally, never gotten more than 9.4 gallons in and that was driving 50+ miles after the last pip started blinking. I rarely fill before the last pip starts blinking and still rarely get more than about 8.3 gallons in. But I'm used to it and still only fill up 2-3 times per month on average. I think the guage has been improved in the past couple model years. If you live/drive in an area that has gas stations readily available you can push until the last pip starts blinking, that should allow you at least one more gallon and around 50 miles more driving.
  3. jmccord
    jmccord New Member
    199
    San Diego, CA, Earth
    The fuel tank/gage/bladder seems a common source of consternation among Prius owners.
    I usually rely on a combination of mileage and the gage. I am also guilty of typically refueling at 1-2 pips just to be safe (never blinking).
    I was a victim of the fuel tank bladder this weekend however. I drove to the mountains from sea level and refueled at about 5,000 feet elevation. I filled the tank as usual, removed the nozzle, and watched helplessly as about 8-12 ounces of fuel gurgled back out of the tank onto the ground. :eek:
    Definitely not good for the environment - or my ego!
    Oh well, lesson learned. <_<
  4. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    a good rule of thumb is to start thinking about heading for a gas station when you're down to one pip.
  5. icharry
    27
    Los Angeles
    Reply #1: I know I'll get better and go further, and I do live where there are gas stations all over, but part of the reason I got the Prius is to NOT waste my time at a gas station.... Funny thing though, is htta now even that I go less often I spend more time... checking the tires, oil and writing down my miles and average... I know I'll probably stop (or do it lesss) doing this after the car has a few thousand miles... after the honeymoon.
    To reply #1: Are you saying the pressure change from sea to +5000 caused the tank to spit? Would not the pressure equalize when you opened the gas cap?
  6. berylrb
    berylrb Member
    308
    san francisco?
    <div class='quotetop'>QUOTE(icharry @ Jan 7 2007, 10:33 PM) [snapback]372312[/snapback]</div>
    OK, now I understand, at first I was thinking, "what difference does it make?" Knowing your goal to be less trips I see your consternation. But I'm sure you understand with regards to MPG it doesn't matter. ;)
    Oh I don't know, I think you'll become hooked on how sweet it is to be doing so much better than your other car(s), having stories to tell to your co-workers, etc. I have record keeping down to a science now and found that my tires stay at 42/40 rather easily.
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(efusco @ Jan 7 2007, 06:55 PM) [snapback]372305[/snapback]</div>
    Yep. The CAN-View does give more precision, but I doubt that it takes care of the variable tank capacity problem. I'm only guessing (will have to ask Norm), but I'm at 92% now, and I assume that means I've used 8% of what was presumably a full tank of 11.9 gallons. If it's the case that a full tank is only 10.5 gallons (the most I've ever put in), I would run out quite a bit before it reads 0%.
    Dave M.
  8. efusco
    19,891
    1,192
    Nixa, MO
    <div class='quotetop'>QUOTE(dmckinstry @ Jan 7 2007, 11:52 PM) [snapback]372366[/snapback]</div>
    I agree, I don't completely trust the tank level from CAN-View either and tend to fill up at about 10%...the last bar starts flashing at 12% level I think.
  9. Syclone
    Syclone Member
    540
    People, GET OVER IT! It's a fuel bladder, not a fuel tank. Its capacity varies, depending on ambient temperature. Neither you nor the on-board ECU can predict how much fuel it can hold at any particular time.
    When you get down to 2 pips start looking for a gas station. If you get down to one, look harder.
    This whole topic has degraded from interesting to amusing to annoying.
    I had a feeling where this subject was going when I posted a response on a fuel bladder thread several months ago suggesting modifiying the gas cap with a Shrader valve to pressurize and expand the bladder before refueling and found that I was being taken seriously.
    I find it difficult to understand how a group of people who seem to be above average intelligence get fixated on this sort of mental masturbation!
  10. berylrb
    berylrb Member
    308
    san francisco?
    So syclone what exactly are you trying to say, 'Get Over It', 'Move On', ...? :blink:
    Just kidding, point well stated, gotcha, right-on! ;)
  11. icharry
    27
    Los Angeles
    <div class='quotetop'>QUOTE(syclone @ Jan 8 2007, 07:11 AM) [snapback]372447[/snapback]</div>
    Sorry for causing you such pain.... maybe not replying would ease your pain, also it would not bump the thread.
    As far as the reason that people get fixated on it (at least for me) is that this is a new machine for me... a new thing that represents a MAJOR cost, as well as a desire to be a good steward to the earth. I wish to learn as much as possible about it... in fact thats why this site exists to help people learn about & share ideas.
    Sorry for any typos, I'm clearly typing with 1 hand ;)
  12. bomber991
    bomber991 New Member
    24
    I don't have a prius myself, but I know in my car the low-gas light comes on when I have 2.2 gallons left. So yeah, I know for a fact in my regular car I can go, in a worst case scenario, another 40 miles. My car's only rated at 20mpg in the city and 27 on the highway, but I usually average around 27 anyway. Hehe, on a long trip once, I went something like 450 miles on one tank, and when I got there I put in 15.0 gallons in a 15.9 gallon tank. Averaged 30mpg.
    I guess the prius uses some fuel bladder thingy, but for regular cars, the gas tank is in a V shape, and this is why the gas needle drops so much faster once you get past the first half of the tank.
    So yeah, like other people here, just as a general rule of thumb, I usually go by the trip-odometer more than I go by the gas gauge.
  13. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    <div class='quotetop'>QUOTE(berylrb @ Jan 8 2007, 11:28 AM) [snapback]372472[/snapback]</div>
    Considering the terrain where you are, your mpg isn't too bad. All those hills must make it a real challenge.
  14. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(icharry @ Jan 7 2007, 06:37 PM) [snapback]372301[/snapback]</div>
    Well, after my last fillup, CAN-View showed that tank as 92% full. I did lose the first pip fairly quickly.
    Dave M.
  15. hill
    8,188
    <div class='quotetop'>QUOTE(jmccord @ Jan 7 2007, 11:22 PM) [snapback]372308[/snapback]</div>
    Aint that a trip? Gas Vomit. I think the pump shutoff really has to be screwed up for this to happen. When it happened to me, the thing I did was to re-insert the pump handle back into the tank ... forming an air-tight fit until the bladder aclimated to the larger size ... 2 or 3 minutes later i was on my way. All in all though, the bladder thing never really bugged me ... like Evan says, you'll get used to it.
