The left Map light does not turn off
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by vicky, Dec 2, 2013.
  1. vicky
    vicky Junior Member
    The interior lights turned on when I open the door and then the left map light never turned off.
    I tried every tricks. Turned on turned off the switch, opened & closed doors. The right map light does work correct. I don't want the 12V battery to drain so I just pulled out the light.
    You guys know how can I fix this?
  2. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Make sure you try pushing on the map light itself.
    Turn off signatures in Tapatalk Tapatalk
  3. Grren4ever
    Grren4ever Active Member
    347
    166
    Yes! push the lens and you should hear a click...then it should shut off. If not, get out of the car and run or else it will self destruct!
  4. vicky
    vicky Junior Member
    Thanks you guys. It was dark so I could not see all the buttons up there. All I can see was the SOS and switch.
    In the morning I can see them.
