The miracles of Traction control
Discussion in 'Prius v Main Forum' started by Stevevee, Dec 12, 2013.
  1. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    My last Camry, thank goodness, had a button to turn this feature off for awhile. Sadly, the v does not.
    One can feel rather silly on an incline that's 100% sheer ice. Good mileage though;)
  2. Hankth
    Hankth Junior Member
    2018 Prius Prime
    Please explain. I thought that tc would help in situations like that.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    It does. Many people react negatively to the TCS, but I find its very effective in most situations. I suspect that some folks don't understand what its doing or why, and how it helps.
  4. Stevevee
    821
    224
    Vermont
    I understand what it's doing, and why it's there. My 2011 Camry SE had it, and the first winter I got to test it with the TC on and off, because it had a button to turn it off. Many times it's helpful, sometimes it's not, and sometimes it's debilitating. When you get on a slight incline that's icy, most times you're not moving.
  5. Flying White Dutchman
    4,374
    313
    yes indeed
    in the hybrid system this can not be turnedoff because it also protects the hybride drive system.
    and yes sometime the car will no longer move where when you can turn it off ( if thats possible ) or a car t hat does not have it at all are capable to still get moving
  6. Stevevee
    821
    224
    Vermont
    I could always push it, that would be good for gas mileage ;)
  7. Flying White Dutchman
    4,374
    313
    total energy cost would not the less
    you burn more energy and need to eat more ;-)
    AllenZ and Stevevee like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The car is more intelligent than any one who thinks they should drive on a 100% iced over surface, that's why it stops you doing so. If it's sheet ice, then TCS or not you ain't goin' anywhere.
  9. Flying White Dutchman
    4,374
    313
    i disagree
    the example i have is a model you dont get in the us
    but the peogeot 2008 crossover is a front wheel drive only
    but optionel your get a special ofroad pack where you can tell the traction control on what type of road your driving
    one part of it is that it will allow for spinning.
    its called grip control
    a normal 2008 with traction control will just with any car with traction control get stuck.
  10. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    It is also called the Snow mode.
  11. ursle
    ursle Gas miser
    1,049
    192
    NH
    4 studded wheels and you're good to go, and stop, I really, really want the stopping ability.
    But, just because the car can go doesn't mean you should, I want the choice to be mine;)
  12. Stevevee
    821
    224
    Vermont
    I remember when Toyota came out with a 4Runner that had TCS and no button. When they did the annual off road tests, the 4Runner continually had to be towed out.
    FYI, in my case I was coming out of a parking lot where the exit had become iced over. Unfortunately for the TCS, the roadway didn't leave a special bare spot for the TCS to gain traction. So I actually blocked traffic momentarily as my little car sat there and did nothing. Since it was only a slight incline, I stuck it in reverse and tried not to be too embarrassed.
    I've been driving long distances in ice and snow in all kinds of inclement weather for some fourty years, so I'm not a newbie at this.
  13. schinia
    schinia Member
    162
    25
    cape carteret,nc
    having DRL'S does not use energy. if you think so, thats your problem.
  14. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
  15. fuzzy1
    10,170
    So I can put some PV modules in front of some DRLs to make a perpertual motion machine?
    jhinsc likes this.
  16. Stevevee
    821
    224
    Vermont
    DRL's use free energy from the Energy Fairy. I've heard some PIHV's do as well :ROFLMAO:
    jhinsc likes this.
  17. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Unless you have dedicated snow tires with studs and drive carefully (IE: no jack rabbit starts or sudden stops).
    Whats' is the most important issue: common sense when driving on ice.
    DBCassidy
  18. Stevevee
    821
    224
    Vermont
    I have dedicated snow tires which are brand new. I haven't used studs since the early 70's. I fully understand the necessity for using extreme caution on ice. I've driven on long trips involving hundreds of miles, through snow, sleet and worse, Freezing Rain. I know when to slow down, and when to pull off.
    This is a different issue, one involving the simple issue of Traction. I will note that Toyota apparently made some tweaks in early Prius cars due to overly aggressive TCS software. In my Camry, as well as various other cars, there is an OFF button. When needed, it's priceless.
    Cars run by software need to have a way to program common sense into the equation. Extremely hard to do, but they try. In the meantime, an off button would be nice.
  19. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    You can't compare TCS systems on regular cars to the system on a hybrid. 2 very different systems. But one can still resort to the old tried and true method of using both brake and throttle at the same time, which works on a Prius too.
  20. Stevevee
    821
    224
    Vermont
    Love that old method. Didn't get me far this time around, but maybe later on. We'll be getting a lot more snow today and tomorrow than originally expected. Looking forward to some gold old-fashioned snow testing ;)
