The next PHEV will be a MR2?
Discussion in 'Toyota Hybrids and EVs' started by drash, Mar 24, 2023.
Tags:
  1. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    This is for you @Tideland Prius . Car-moby.jp website has scooped that the Toyota MR2 will be revived. And get this, it'll have a 3.0L V6 PHEV with 400PS!!! :eek: And for about ¥6,000,000, about $45,889 or €42,562. :rolleyes: Sure.
    トヨタ MR2が四半世紀ぶりに復活?400PS・MR・PHEVで600万円以下か | MOBY [モビー]
    Partial translation:
    "Toyota MR2 revived for the first time in a quarter of a century? 400PS/MR/PHEV for less than 6 million yen
    Revival of the car name after a quarter of a century?
    Toyota MR2 (AW11)
    In 1984, the first generation AW11 model was released in 1984 as the first mid-engined car produced by Toyota, the MR2. In 1989, the baton was passed to the second generation SW20, and sales ended in 1999. MR-S became the successor.
    In Japan, the car name of MR2 has disappeared, but there are rumors that the car name of MR2 will be revived in 2024, 25 years after its disappearance.
    Get styling like a supersport
    Expected CG of Toyota MR2 successor model
    A predicted CG of the model that is supposed to take over the MR2 car name has been created.
    It has a low and wide styling that is typical of super sports, and the front design gives a sharp impression with triple LED headlights.
    The Supra had a design that was reminiscent of past models, but the new MR2 is a mid-ship sports car with a completely new impression.
    Despite being a 3-liter V6-equipped PHEV with 400PS, it costs less than 6 million yen
    toyota supra
    The powertrain installed in the new MR2 is a plug-in hybrid that combines an electric motor with a 3-liter class V6 engine , achieving a maximum output of 350 to 400 horsepower and high output performance that surpasses the Supra. It is said
    While having such high performance, it is expected that the price will be less than 6 million yen by realizing cost reduction through joint development with other manufacturers.
    Compared to the past MR2, the price is likely to be more than several times higher, but it seems to be a very affordable car among modern pure sports cars that adopt a mid-ship layout. Look forward to seeing you."
    I'm sure they'll produce enough to not see a markup. :LOL: If it is a PHEV it'll probably have the 2023 Prius Prime battery (13.6 kWh) and not the RAV4 Prime battery (18.1 kWh), but there's no rear seat to stick it under. Man would that be neat runaround car. :cool:
    Tideland Prius likes this.
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    If they already have a thicc V6 on board, why bother with a big hybrid battery? I'd expect them to do an extra-small one for weight savings and better handling. Also lets them stretch fewer batteries over more VINs, a strategy they've been broadly backing for a while.
  3. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    How do you make everybody forget about BEVs? Make a really, really, really desirable PHEV. The original MR2 had a 1.6L supercharged 4 banger, where are they going to put a 6? I'd really have expected to put the Hybrid Max over the rear axle and call it a day. The last time they had a 3.0L V6 was in my T100 and it wasn't small. The original MR2 was tiny (3,950mm or 155.5 inches) and light (1,131 kg or 2,493 lbs). They'll have to stretch it a bit which to me would be counter productive to the original idea.
  4. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    I don't disagree with your overall statement, but I think we've got real differences in what adds up to a desirable PHEV. That's still going to be subservient to what makes up a desirable car, and if this is to be a 2-seat sports car? I think that means a tiny battery.
    I long admired but never owned an MR2, never had the cash when they were en vogue. But looking at it today? Wow, I could have a lot of fun with that! If it handled like the original MR2 and had maybe 10 miles of electric range and charged fast on a level 1 plug I'd be over the moon! Much more range than that and I'd forever be chasing performance shops to make a smaller/lighter battery for better handling.
    drash likes this.
  5. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    BMW tried something like that called the i8. Had a 1.5L 3 cylinder turbo driving the rear wheels and a 129 hp (96 kW) motor driving the front wheels with an 11.6 kWh battery. The whole car was carbon fiber so it was light comparatively speaking but it was huge compared to the MR2, 29.1 inches (739 mm) longer and 901 lbs (408 kg) heavier. Hoping that's not what Toyota is thinking.
  6. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Well if they've gone from a 1.6L to a 3.0L then it's all but guaranteed that the size and weight will go up. But maybe not so terribly much.
    I mean, even when Porsche did the 914/6GT they knew the 2.3L flat 6 was already too much... the still-bigger ones would have just been silly.
  7. Tideland Prius
    16,155
    The design looks great! $50-$55k CAD eh? So it'll slot between the 86 and Supra? Man, that's expensive but I guess given it's a PHEV, it's not that far off from a Gen 5 Prius Prime (and the same as a RAV4 Prime).
  8. Trollbait
    11,560
    A power hybrid uses a bigger battery to provide extended periods of performance boost. Packaged right, the battery also improves the weight balance and center of gravity.
    The BMW 330e has a 12kWh battery, and less range than the gen4 Prius Prime. The Panamera e-Hybrid battery is almost as big as the Rav4 Prime's, and it just missed 20 miles of EV range. Power PHEVs are about getting the most power out of the engine and motor at the same time, and battery capacity limits what the motor can do at those times.
  9. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Aren't both of those cars grossly larger than the original MR2?
    Seen in that light? I guess what didn't really come through in the original article is that they are re-using the MR2 name but abandoning the original concept to do a wide, heavy, powerful car instead.
  10. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    More than likely a miniature version of the LC 500h with a plug-in capability. That's what the drawing looks like to me. I think I figured out why it would have a 3.0L V6 NA engine instead of a Toyota or Lexus 2.4L turbo which have more power and way more torque - sound. Sounds like Akio-san still has his fingers in the design recipes for the sports car department and he loves the sound of gas cars. Somebody should probably tell him it still isn't going to sound like the LC 500 with the 5.0L V8 which is arguably the best sounding Toyota/Lexus car made, quite possible anything from Japan based on reviewer comments.
  11. Trollbait
    11,560
    They are, but I don't think a PHEV being a small two seater limits it to a tiny battery. If this rumor car stays true to the MR2, it will have a rear-mid mounted engine, which puts the exhaust and emission controls at the rear. This leaves the 'belly' open to mount a battery configured like a BEV's. The 13kWh pack of the new Prime fits under its rear seat. A battery that goes under the MR2's front seat and belly could match it in capacity. If they use something smaller, cost is more likely the factor.
    They are already working on something closer to the past MR2.
    Suzuki & Toyota planning 1000kg, 1.0-litre turbo sports coupe – report - PerformanceDrive
    Toyota, Daihatsu, and Suzuki Joint Development on 1L Sports Car | PriusChat
    Now, if you are looking for a fun little car for weekend drives, there are plenty of Miatas out there. Its weight distribution may not be as much fun as a MR2's, it is harder to get into trouble with.:D
  12. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Thanks, I missed that thread. That looks way more fun to me!
    The 86/BRZ was always appealing to me in stock form, you could drift it at 20mph. So even if you were bad at it nobody died.
  13. Tideland Prius
    16,155
    Yeah but could you put out a cigarette from the driver’s seat without getting out? (That was the “trivia” from the original 86/FR-S).
    Question for the engineers of those group - would it be more beneficial for an underbody battery or a front-mounted battery?
    Initially, I’d thought underbody for low centre of gravity and weight balance. But then, if this is a MR, then one could mount the battery up front (even front midship) to play with weight balance and to offset the twitchiness of a MR setup under hard braking. Basically the battery acts as a ballast.
    drash likes this.
  14. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    2004 MR2 Spyder
    Now that I look at it, yeah they could put a V6 back there and slide the battery under the front seat or front trunk (frunk) as @Tideland Prius suggested. It'll be a little better balanced than the original which as one reviewer said, "When pushed, the MR2 tends to pivot more around its mid-point; when the back comes around to the left, the front is moving to the right at the same time, as if a big push pin were stuck right through the floor." Mazda Miata Vs. Toyota MR2 Spyder - Motor Trend Magazine
    Yeah I'd agree with you that it might grow a little but not too much. After all it ain't about the ground clearance or massage seats in this car. As long as you can throw your backpack in the passenger seat before you go to work who cares if it can't haul a couple of flats of plants or mulch. Now they have to compete with Toyota's own French designed Aygo-X and the GR Yaris in Europe. It'll have to be a PHEV if they are gonna sell it in Europe or anywhere that has banned gas engine only.
  15. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    Put the battery up front (or in a center tunnel) and let the driver's eye-height stay that 2" lower, it'll make the car feel faster to drive.
    drash, Trollbait and Tideland Prius like this.
