The Official Prius SSC50P Campaign Doc
Discussion in 'Gen 2 Prius Main Forum' started by naterprius, Oct 14, 2005.
  1. naterprius
    naterprius Senior Member
    1,843
    Here's the real deal, straight from Toyota. It's 3.3 Megs.
    Vin range is as follows:
    VIN Range Model Year VDS Range
    2004
    KB20U
    0001009 – 0116870
    KB22U
    0001142 – 0116845
    2005
    KB20U
    0116874 – 0133248
    3000000 – 3029798
    7003414 – 7006860
    KB22U
    7004342 – 7006863
    0116872 – 0133240
    3000008 – 3029797
    The doc (3.3 Megs) is attached.
    EDIT:
    Here is the link to check your VIN
    http://50preflash.imagespm.info
  2. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    Ya beat me to it... thanks Nate :)
  3. lgeisz
    lgeisz Junior Member
    83
    Sun City AZ
    wooo whoo didn't make the list.
    thanks Nate
  4. jeromep
    jeromep Member
    827
    Eastern Washington State
    I've skimmed the PDF, however just to let everyone know, look for the blue PDF links. They work and take you to a public web site where you can put in your VIN number and get a list of services that are necessary. Very helpful and very cool!
    It is not so cool that some of us have to have our cars serviced for this, however I'm glad that Toyota is taking care of this up front.
  5. BitShifter01
    BitShifter01 New Member
    91
    Does anyone know if this recall will affect the MPG? I have heard of people getting their ECU flashed and they lost about 3 to 4 MPG because of it.
  6. rick57
    rick57 Member
    572
    Circleville, Ohio
    Thanks for the link,nate, :) . I left early today and hadn't found it yet to browse over. I am on vacation next week,so I hope the dealer can make it without me. I seem to be the one everybody comes to with problems,especially if it concerns Prius questions ( there are 3 other Prius techs,but they don't have the experience/time I have had with them ).
  7. GeoffM
    GeoffM Junior Member
    Long Island, NY
    Strange... My VIN doesn't appear in the list, but when I put it in on the web site I get this:
    VIN JTDKB20U350XXXXXX requires the following repair(s).
    Engine ECM reflash
    HV ECM reflash
    Install connector grease
    Geoff
  8. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Well planned! :D
  9. rick57
    rick57 Member
    572
    Circleville, Ohio
    Yes,Bill, what timing, :lol: . Couldn't have planned it any better if I tried.
  10. deh2k
    deh2k New Member
    241
    New Hampshire
    The doc says that not all VINs in those ranges are affected by this SSC. My VIN is not in the ranges listed but the web site says the SSC applies. Seems like that list of VINs isn't worth much.
  11. heavenleigh
    heavenleigh New Member
    52
    Just wanted to say I really appreciate everyone who is posting all this information! I'm glad I have info to take into the dealership to make sure they did everything required. THANKS!
    Hillary
  12. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if your from Canada don't bother entering your VIN on the site as it say's it's not a valid VIN. That's not unusual and Toyota Customer Service won't be able to tell you either. Once again we'll have to wait for about 3 months to have this work thru Toyota Canada's system.
  13. brandon
    brandon Member
    771
    Manhattan, KS
    Same here. My VIN does not fall within the stated ranges, yet the website says the SSC applies. I called the Toyota customer service 800 number earlier today and a helpful gentleman named Mike said it was not part of the voluntary recall.
  14. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    When I put my VIN in , it says "Not a valid VIN" which I assume means it does not apply???
  15. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Okay, I'm an idiot, I should read the SSC first... it's the M5
    connector, on the front of the transaxle. But why not treat all
    the other connectors into the transaxle at the same time, since
    they're similar and would like present the same water-intrusion
    problem?? Why, for that matter, does the transaxle design have
    little connectors stuck all over it in random places like this,
    rather than, say, one or two big ones up near the top [more out of
    harm's way on wet days] with the resolver and temp-sensor wiring
    run around *inside* a more sealed housing?
    Given the weather in the northeast for the past week, it's making me
    more paranoid about hitting puddles...
    _H*
  16. BitShifter01
    91
    Bueller? Bueller?....Anyone? Anyone??
    I realize having a car the performs as expect is more important than losing MPG, but I'm curious. Any hear about a decrease in MPG when flashing the ECU?
  17. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    That's what mine says too. It's a valid VIN, as I am copying directly from my paperwork!
    I'm not in the listed ranges, but I'm not convinced that means anything. Time to call my dealer I guess....
  18. engunneer
    engunneer Member
    307
    Medford, MA
    2020 Prius Prime
    I think it's too soon to know if this particular re-flash has an effect. Past reflashes seem to have had effects, but I don't have firssthand experience with that.
  19. Bill60546
    Bill60546 Member
    388
    Chicago
    Thanks Nate. Looks like I'm on "the list".
    Made an appointment with my local dealer who advised the fix process will take 3.5 to 4.0 hours.
  20. brosnan
    brosnan Member
    159
    Silicon Valley
    How come my VIN has 9 digits after the 20U but the pdf document list of VINs shows 7 digit numbers? Should I ignore the first 2 or last 2 digits?
