The one thing I'd like to see improved with MY '11
Discussion in 'Gen 3 Prius Main Forum' started by Carnutt, Jul 26, 2010.
  1. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
    Overall, I love this car and am enjoying its many attributes including its technology and gas mileage.
    But, as pointed out on numerous posts and threads, are the car's numerous creaks and rattles. Not being an engineer, I'm not sure if this would amount to better sound-proofing or sound-deadening materials or a partial re-design of certain components.
  2. Thai
    Thai Prius Neophyte
    1,197
    89
    What build date is your Prius? Mine is 4/10...no rattles yet. :)
  3. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Re creaks and rattles... first this is NOT to be 'in your face' to those owners that have issues in this regard.
    Mine was built in May '09 - delivered last July. Serial number under #2000. Now has 10,000 virtually trouble-free miles. Only time in the dealer was one trip for the brake recall/fix, oil change, and a repair to the driver's lumbar area (a creak).
    Other than that mine has no creaks or rattles - and I am very picky in that regard. Now, if I press or squeeze around the console area I can make noises. But normally -phew- it's all quiet. It's probably a matter of time though. With all the seemingly creaky plastic joints inside the car....
    If I could change one thing in my Prius it would be the plasticky interior, especially the console area. And the dash top has been a dust/lint catcher since mile 10. But this all said, that's about it. It's a very nice vehicle and I'm completely satisfied that I switched to a Hybrid - and that it's a '10 Prius.
    And glad there seemingly will not be many changes, especially cosmetic, to the 2011 model. We all would prefer our investment to be fresh.
  4. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    No problems with creaks and rattles, it is the rotten displays that need fixing.
  5. Carnutt
    Carnutt Member
    232
    23
    SW USA
    2018 Prius
    Mine was built in 7/09. The squeaks and rattles are intermittent, didn't develop till over 3000 mi., and seem to be related to the outside temperature. I thought I was fortunate before they developed, so for those going forward who don't have the problem, count yourself lucky.
  6. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
    build date 06/10. I hear nothing. they must've worked out the kinks by now this late in the production stage.
  7. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
  8. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    It's not as bad as I thought it would be! reading all the posts on Priuschat
    after the GenIII came out.
    Not any worse than any other car I have owned they all had creaks and rattles
  9. bisco
    51,155
    are the 11's out already?:)
  10. phoenixgreg
    phoenixgreg Senior member
    1,157
    291
    66
    Phoenix
    Summarizing the million posts here on rattles, here are the most prevalent:
    1) Lower glove box
    Fix: put plumbers grease on internal plastic latches, hinges, and on the black plastic damper pivot points (right side).
    2) Intersection between sky-bridge console and storage console
    Fix: cut a 2 foot length of twine and thread under the intersection. With fingers, put some plumbers grease on twine and "floss" it into intersection carefully so as to not get any on the cloth. Wipe off excess.
    3) When keeping rear seats folded down, do not fold down the headrests, they rattle.
    4) Rear license plate.
    Fix: using velcro or double-stick pads, secure lower plate to car body.
    4 people like this.
  11. Tideland Prius
    16,445
    My tonneau cover rattles in the same place (with the same noise) as our 2005...
  12. tedjohnson
    tedjohnson Member
    347
    72
    Greenfield MA
    Build date 3/10, the only rattles are the brake calipers, and only over sharp bumps.
  13. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
  14. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Thanks! I cut & pasted this into a sheet in my gas mileage/maintenance spreadsheet so I can find it when I need it.
  15. phoenixgreg
    1,157
    291
    66
    Phoenix
    You're welcome. I did the floss thing all the way around the console intersection as there's a hidden round hub in there you can't see. Again, plumbers grease is silicon so it is compatible with plastic, but it will stain the cloth so be careful using it.
