The P button
Discussion in 'Gen 2 Prius Main Forum' started by ededed11221, Apr 26, 2005.
  1. ededed11221
    ededed11221 New Member
    Just wondering if anyone knows what happens if you mistakingly press the P button while driving at 60 on the highway.
    Just got a seaside Pearl BC after an 11-month wait here in Boston. A dream of a car and PriusChat is a wonderful service.
    Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Nothing but a beep will occur.
  3. ededed11221
    Thanks. I had visions of springs and gears flying. On first impressions, the gear shift implementation seemed like a klug, but I'm beginning to appreciate its simplicity and elegance. The Toyota engineers should be proud!
  4. KMO
    KMO Senior Member
    1,503
    383
    Finland
    2023 Prius Prime
    I believe actually shifts into neutral (and beeps). Not tried it though.
  5. efusco
    19,891
    1,192
    Nixa, MO
    I think KMO is right...thought of that as I was walking away from the computer to feed the kids. Goes into Neutral and beeps.
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Yeah. it beeps and goes into neutral.. same thing for Reverse.. beep and neutral. park.. beek and neutral. Start button doesn't do anything unless held for about 5 seconds.. then it's an emergency power off.
    anything that's considered harmful in a normal car gets you a beep and a N.
  7. xevious
    xevious New Member
    187
    Oregon
    I think Toyota should have included a real "idiot" light to complement all of the smarter-than-the-user programming they put into the Prius. That way, when I accidentally hit the "Park" button while reaching for the environmental controls (they were there in a previous car!), instead of beeping, the system could illuminate a single indicator on the dash:
    "IDIOT!"
    :D
  8. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    Haha! Just what I need, my car telling me I'm an idiot. I already feel bad enough when my experiments don't work in the lab. :)
  9. olends
    olends New Member
    214
    Clifton Park, NY (near Albany)
    yea the code it would throw is ID 10 T
  10. Tideland Prius
    16,123
    haha. But think about it. Doing the above will send it into Neutral. Do that in a regular car and kiss your transmission good bye
  11. lgeisz
    lgeisz Junior Member
    83
    Sun City AZ
    The Prius will immediately go into auto pilot mode, pull over to the side of the road and then start screaming "are you crazy or what" o wait that’s from KITT of Knight Rider :)
  12. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    How about just "Operator Malfunction"
  13. TechGuy
    TechGuy New Member
    Northern Chicagoland, IL
    While we're down this line of questions, what happens if my car is on & I just walk away with the key? Or what if my passanger walks away with it while I'm trying to drive off?
  14. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    Assuming you mean with SES, the car keeps running normally. (I think it beeps) If you shut it off the key has to be present to restart, but it keeps going until you hit power.
    Without SES, you'd have to yank really hard and probably broke something. At that point you're on your own :)
  15. TechGuy
    TechGuy New Member
    Yes, I was assuming SES... So you could play a pretty mean trick on someone by taking their key as they drive off? They'd get a beep, but based on what I've read, the car tends to beep quite a bit as it is, so it may go somewhat unnoticed? They get to where they were going, only to find out they're stranded when they shut off the car. Hmmm...
  16. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    You'd better be my g/f or better yet, wife if you are going to reach over and try to get my fob while I am driving!
  17. TechGuy
    TechGuy New Member
    I guess I probably just hang out with the wrong people... That, or my sense of humor may need some adjustment.
