the Paint Pen
Discussion in 'Gen 2 Prius Main Forum' started by macreative, Jan 21, 2005.
  1. macreative
    macreative New Member
    151
    Los Angeles, California
    Does Toyota make the touch up paint pen or is it a generic manufacturer?
    When I stopped by the Dealer today, they told me that toyota only makes the paint bottle t ype (like nail polish) with no clearcoat thing.
    I want the paint pen but I can't seem to find it anywhere.
    Is it actually Toyota branded? I don't trust southbay toyota.....
    Any suggestions?
  2. techogurl
    techogurl New Member
    226
    Fayetteville, AR
    I saw a post a long time ago that people in Canada got paint pens. I was only able to purchase a brush style here in US.
  3. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    I suffered a ding and was trying to remember - and then find - a thread from some time back. If I remember correctly, this touch-up paint system required that you apply the paint and then rub the application in order to make sure it's smooth to the surrounding paint. The individual explaining the process was quite pleased with the results.
    Does anyone remember this? Who's the manufacturer? What's the paint application name? Where can I get some?
  4. wildplaces
    wildplaces Junior Member
    37
    You can try www.Paintscratch.com Someone else here recommended it and I ordered a touch up paint pen kit, but haven't used it yet.
    wildplaces
  5. betshsu
    betshsu Member
    302
    Washington, DC
    I got a paint pen from my local Toyota dealer, but it wasn't Toyota branded. It also wasn't like the ones that they get in Canada. It was more like one of those markers that you have to shake up and then depress to get the paint to come out.
    Tony, are you perhaps talking about the PlastiKote paint touch up kit? I think in the thread, they bought it online, but I found it at my local Pep Boys for cheaper than the place online. The kit includes clearcoat, polishing compound, and fine sandpaper and a block. After you apply the touch up paint, you use the polishing compound and sandpaper to remove the excess paint. If it's just a clearcoat scratch, the this will also supposedly take out the scratch without any touch up paint. It wasn't perfect when I tried it, but I think it is more the fault of the touch up pen (the color is a bit darker than Tideland, but it was the same color code) than the kit. The kit did take out excess paint that I got all over when I was trying to fill in really light scratches without affecting the actual paint of the car.
  6. downeast
    downeast Junior Member
    TonyPSchaefer
    I believe you are talking about is called langka . It does work well, requires a little patience, you really have to time when the paint you put on is close to dry and then use this product. Requires several applications of paint and smoothing.
    http://www.langka.com/
  7. Tideland Prius
    16,123
    The paintpen we have for the Camry is red/white with a paint applicator on one end and a clearcoat one on the other end (Think double-sided markers). The brush/bottle ones are for pre-2000 or 2001 models here in Canada.
  8. wildplaces
    37
    the www.paintscratch.com uses the VIN# to match the batch color...
  9. Eisenson
    Eisenson New Member
    142
    I bought a very nice product from the Toyota dealer - called ChipMender (Livermore, CA). It's a slightly flexible tube shaped like a pen, with a metal tip. Squeeze and push the tip against the chip and paint comes out, and it flows just enough to fill the chip as it dries. Works great, hardens and disappears. Patent numbers and patent claims all over it. About $7, I think, and worth it.
  10. TonyPSchaefer
    14,816
    2,497
    66
    Cool. Thanks all. Though now I have several glowing recommendations rather than just the one I had hoped would remove options. :)
    I'll reasearch the ones you all mention and get something once the weather warms up.
    My ding, but the way, goes all the way through the paint to the body. Someone smacked it hard.
    I also seem to have suffered a blow on the very edge of the front passenger door. It literally curves around the metal. I seriously think the mechanic did it, but it's been so long now that I would have a hard time proving it. Since I drive the car alone and only get in and out of the driver's side, it took almost a month to see it. If, that is, the mechanic really did do it.
