The Prius c has no engine temperature gauge, why is that?
Discussion in 'Prius c Main Forum' started by tgpii, Nov 15, 2013.
  1. tgpii
    tgpii Member
    382
    63
    Tapier Lake/Orland Park, Ilinois
    The Prius C has to engine temperate gage why is that?
  2. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  3. jonb505
    jonb505 Member
    317
    77
    Vancouver, BC
    Modern automobiles are pretty darn reliable, an engine(coolant) temperature gauge would just add clutter. My old(2008) Honda Fit just had a blue light under the fuel gauge that came on at startup for a minute or so, indicating a cold engine so take it easy, and according to the manual, a red light would come on indicating an overheating engine(never ever saw that one, right up to 198,000km when i sold it). This is the trend and it seems most cars in the past few years go for the minimalist instrument panel approach, which is just fine by me.
    The only place i see water temp, oil temp, oil pressure gauges, etc, these days is in trucks or other machines designed for towing, severe service, race cars and the like.
  4. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I have the coolant temp on the ScanGuage only because of the car's changing behaviour during the warmup stages (and it's only really useful with a digital display). Once it gets up to full operating temperature it rarely moves except in cold conditions, in which case it may drop when the ICE is not operating. Any other car I've driven sees the temp guage climb to operating temperature and stay there. It would only move if something has gone wrong, in which case the relevant indicator light would come on anyway.
  5. Mike500
    Mike500 Senior Member
    2,593
    764
    In the Winter, the really nice thing about a temperature gauge is that you don't need to turn on the fan on your heater too soon as to have it blow cold air on you.
    Consider yourself lucky.
    tgpii likes this.
  6. Mendel Leisk
    38,726
    Does the Prius C have a coolant temperature gauge? Good idea: Coolant temperature is useful info, one of the gauges I miss on our (regular) Prius.
    tgpii likes this.
  7. Rob.au
    960
    441
    Sydney, Australia
    i-Tech
    No. A ScanGauge II (or other OBD reader) can read this information via the OBD II port however.
  8. ETC(SS)
    6,555
    Why is that?
    Money.
    The same reason why the G3 doesn't "need" extended visors...sound deadening material in the doors...a proper seat....etc. :)
    You're PAYING for the drive-train and for a platform that gets 50-something miles to the gallon.
  9. tgpii
    tgpii Member
    382
    63
    I just miss the temp gauge just so I know in the winter when to turn the heat on.
  10. tgpii
    tgpii Member
    382
    63
  11. fuzzy1
    10,170
    Does the 'temperature gauge' in my old Subaru qualify as a real temperature gauge, when the entire temperature span from 150F to 210F is condensed to a single needle position?
    The external OBDII reader (I use ScanGauge-II) is much more informative even for that old car.
  12. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    If you set the temp on auto, the fan will not go on until the water temp is warm enough. At least that is what mine does
    fourenty likes this.
  13. fourenty
    fourenty Junior Member
    46
    25
    Endwell, NY (near Binghamton)
    Yep, just like Vernon said
  14. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    The engine oil temperature is more relevant if you need something to monitor.
    Based on the warm up patterns of our other cars, I drive lightly for about 5 kms before I give it the beans
