The Prius is killing me!
Discussion in 'Gen 2 Prius Main Forum' started by ryprius, Aug 26, 2009.
  1. ryprius
    ryprius New Member
    25
    St. Louis
    So I have had my Prius for a full week and like I have said I love my car and all the neat thing it does for me and the enviroment!
    MY ISSUE IS MY BODY...seriously the car kills my lower back and thighs. I hurt withing 20 minutes of driving and it bugs me all day. Im 6'4 and weigh about 180lbs. NO IM not small but Im shocked by how uncomfortable it is. I dont have the most room for my legs but plenty of space so Im not sure whats up???
    Any suggestions, I dont want to sell it!:(
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This topic has been discussed many times. Search is a really useful tool. I did one for you:
    Google
    Happy reading,
    Tom
  3. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
  4. richard schumacher
    7,664
    1,043
    United States
    Try a small cushion for the lower back. Don't wear your wallet in a back pocket.
  5. danl
    danl New Member
    231
    Boston, MA
    Most suggestions mainly involve getting some seat cushions, maybe ones with lumbar support. One good one, tho obvious, is to take out everything from your pockets, i.e. keys, wallet, phone, etc, if you're going in for a long drive.
  6. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    I know this may not sound like much but have you checked into any surgical supply stores to see if they have some sort of support cushion for your lower back that you could buy that would give you some added support in that area since you don't have a power lumbar in your particular vehicle???? That may be a good idea to check and see as I am sure many people who have had therapy or back surgeries, that this would be a good avenue for something to try......
    I owned a 2003 Prius and I have to tell you that was one of the only complaints to that year for me, was the comfort of the seat or angle, never sure what it was from...but I fealt it in my lower back area..fatigue I guess is the best way to describe it and stiffness.
    I just took delivery of my 2010 Model V with leather and power lumbar and have to say, 90% improvement and have not had that discomfort in this model at all. I have not taken it on a long trip yet but I suspect the early results are very encouraging. Toyota IMO made some great strides with this in this years introduction.
    Best of luck but do check out a surgical supply place to see if they have some sort of lumbar cushion or support that may save your back and fatigue..
  7. ryprius
    ryprius New Member
    25
    St. Louis
    Thanks everyone who has made commment worth reading, I appreciate the tips. I will probably look for some kind of support. My only concern is soemthing being to thick and pushing me forward to much. Im also not sure what it is that making my back this way...Dont know if its the actual bottom or back? I guess I will just try a few things and see.
    thanks again
  8. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Believe me when I say, my "bottom side" would go numb in the 2003 and I was quite frustrated, but if you go to a Medical Supply place tell them you don't want THICK and you want something for added support to the lower back area. Also try adjusting the recline of the seatback trying different angles may help as well.
    Best of luck...
  9. Bica2go
    Bica2go New Member
    321
    57
    Boston, MA
    There's a thread here about putting adding washers to the front seat bolts. This raised the front of the seat pan and provided better thigh support. I think the poster was a tall guy too. I'm on a poor internet connection at the moment otherwise I'd try to search and find the link for you. Good luck.
  10. jefwoe
    jefwoe New Member
    Redmond, Wa
    Do you have the leather? I'm having no issues and I'm about the same height and weight. Maybe it's because I have the leather with lumbar support.
  11. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    I love my pri seats, and i have a very bad back :)
  12. ryprius
    ryprius New Member
    25
    St. Louis
    I have leather but with the 2009's and below there is no way to adjust the seats except back and forth...No height adjustments or lumbar adjustments.
  13. Wizeguy
    Wizeguy Junior Member
    25
    I suppose the OP and subsequent posters demonstrate how difficult it can be for ergo designers to hit the mark. The Camry we had b4 the Prius was absolute murder on my thighs even after 15-20 min or so (not so much my lower back, due to the lumbar support), but to the contrary the Prius' seating position is extremely comfortable regardless of how long I'm behind the wheel.
  14. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
    Unfortunately, no seat fits everyone. Here are some suggestions:
    1. As has been said before, an external back support cushion might work, as might one of the seat bottom cushions.
    2. Power lumbar support can be added to the seat back. Search on power lumbar support. Several have done this.
    3. If you want to give up the side air bag, you can replace the entire seat with an aftermarket seat from Corbeau or Recaro. This is not cheap, however.
    4. Interestingly, after changing my seats from cloth to leather I find them to be much better - leather seems to be more comfortable, probably because it is more supportive (doesn't give like the streatchy fabric).
    5. The suggestion about putting washers under the front bolts is a good one. I've done this to numerous cars, but didn't feel the need in my Prius.
  15. djasonw
    djasonw Active Member
    960
    121
    Coconut Creek, FL
    My solution is Vicodin HP. It definitely works.
  16. blacktouring
    blacktouring Junior Member
    45
    Rolling Hills Estates
    Perhaps you should consider a Recaro seat. They are expensive, but if you are spending lots of time in your car, IMO it's a worth while investment in your physical wellness. I've heard of people with orthopedic conditions having their doctor prescribe these seats - so perhaps insurance might cover some of the expense. You might want to see an orthopedist for a recommendation. Perhaps there's a more serious issue that's being exacerbated by the stock Prius seats.
    .: RECARO :.
  17. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Ryprius,
    Are you long legged, or long in the torso? If your long in the Torso you may need to go with the different seat route. I had a guy who was built like that in my car, and he had to stoop to have a horizontal line of sight out the front window. Such stooping, is going to set the back up for all sorts of bad shock loads during driving. He drove a VW Golf - no problem. Its because the Prius seat is very thick in the base, which makes it good for people with average length dimensions, but husky (like me). The VW seat was close to being a plastic shell. So, even in the taller Prius, he could not fit.
    If your long in the legs, you may have your knees way high, which is also not good. Some people have added length to the seat rails to solve this issue. It works, if your also long in the arms, too.
  18. PriusLewis
    1,002
    84
    Denver Metro
    My only complaint is $2800 for an Ortho Recaro is a WEE bit pricy!
  19. ryprius
    ryprius New Member
    25
    St. Louis
    Thanks for all the suggestions and those of you who LOVE your seats Im very happy for YOU, infrotunatley they arent so great for ME!
  20. richard schumacher
    7,664
    1,043
    United States
    A cheap simple test is to fold up a t-shirt or hand towel into a small dense pillow and try that for the lower back. All of the commercial lower back support devices that I tried were either too large or too squishy.
