The Prius's biggest defect: crappy plastic flaps underneath
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by metamatic, Aug 20, 2006.
  1. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    I have a problem with the design of the Prius.
    On the front underside are two large plastic moldings. Each has a dip molded into it, the two together run across the width of the car. These recesses are about 20-30cm in from the front of the car.
    Now, the recesses start out covered by two pieces of thin, flexible plastic. I will henceforth refer to these as the crapflaps--not because they protect the car from crap, but because their construction is crappy in the extreme.
    As far as I can tell, the crapflaps serve no real purpose other than to ensure that the underside is as flat and aerodynamic as possible. And as far as I can tell, they're designed so that they rip off at the slightest opportunity, and are impossible to repair.
    Here's the problem: around here, there are lots of parking lots with major dips between them and the road. As you go down into the dip and up the other side, the front underside of the car scrapes the street. If a crapflap gets scraped, one or more of the plastic studs holding it in place will pull out of the plastic holes it's attached to.
    The studs are designed to be impossible to reuse. Not only that, you can't buy a crapflap from Toyota; the only way to replace one is to replace that entire underside piece, which costs hundreds of dollars.
    I did that once. By the time my next service came around, I'd lost one, and the other was hanging on by 2 plastic studs.
    So... does anyone have any suggestions? Since these things seem so useless, right now I'm inclined to rip off the dangling one and be done with it. It also strikes me that there's a business opportunity here; if you could actually buy a pair of crapflaps and some push-in plastic studs, it would be trivial to replace them without even needing to jack up the car. If only I owned a plastic molding factory...
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Hmmm, must be some nasty terrain 'round 'bout your neck of the woods.
    (side note: please complete your car and location information in your profile so we know a little more about you).
    almost 3 years now and I've experienced no such trouble and routinely drive on bad rural roads, gravel roads, terrible parking lots, etc.
    As you've discerned, the flat bottom is for aerodynamics. If they're causing that much trouble I would just rip them off and be done with them.
    Or, replace and send the bill to one of the parking lots that's so bad!
  3. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    are you talking about the skidplates? i've knocked one of those off before on a bad parking lot-to-street transition.
    you can buy the plastic clips provided the plate is reusable.
  4. metamatic
    metamatic Member
    114
    16
    Austin, TX
    2020 Prius
    <div class='quotetop'>QUOTE(efusco @ Aug 20 2006, 11:14 AM) [snapback]306253[/snapback]</div>
    What, the user icon isn't enough of a giveaway? :)
  5. clodius
    clodius New Member
    I have the same problem. I have lost two pieces from underneath, but am not replacing anything.
  6. usnavystgc
    3,159
    989
    Tucson, AZ
    Well, as I alway say, there is a way around everything. Here are my suggestions
    Can you drill a hole thru the "crapflaps" and the plastic molding and use a good plastic screw to reattach it?
    Can you buy some threaded metal clips from Lowes or Home Depot that would help (I know they sell them, I just don't know if they would work).
    A picture of what you're talking about could help me come up with more ideas but just remember, ingenuity can solve any problem (see pics).
    roflwaffle likes this.
  7. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Keep in mind the fact that these pans also protect the engine and transaxle from being splashed with mud and/or water. Sure, these components are likely water-tight, but it'd be an expensive mistake to find out otherwise. Especially if an electrical contact got mucked up... electrical problems can be amongst the hardest to diagnose.
  8. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Ran into the same problem a while back going down the freeway here in Houston. Car in front threw up a piece of rubber that was on the road, of course I could not avoid it as I was following a little close in heavy traffic (my bad). Anyway, the rubber broke one of the covers and it was hanging down from the car. Showed it to the stealer while I was there for a oil change. They simply tied it up with some wire ties, like what you use inside of computers. Solved the problem without having to remove or replace the crappy cover. And yes, they are expensive. I can't recall the price, but it was not cheap. Then again, are Toyota parts cheap to begin with ;)
    Ron (dorunron)
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Running without the crapflap underside plate will turn out to be very expensive. The plate protects the ac condenser (the one in front of the rad) from road damage and is easily damaged by debris and very expensive to replace.
  10. dorunron
    3,318
    1,103
    Houston, TX
    I second that as I am in the process of replacing the A/C condensor and it was earlier this year that I damaged our crapflap... The area where the condensor is leaking is in the same location where the crap flap was damaged. It would not surprise me if a piece of that rubber slapped the condensor when I ran over it.
    The cost of that condensor to be replaced from the stealer? $800.00
    Ron (dorunron)
