The right tire pressure on 17" Rims
Discussion in 'Gen 3 Prius Fuel Economy' started by PutPutMobile, Jul 17, 2017.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    Hello. I don't if it's just my wheels or just me. But I want to know the right tire pressure to save as much gas as possible..
    I have size Redline 17" rims. and tire size is 215/50/17 +24 offset..
    I usually get about 42 mpg on the meter.. but I think I can get more than that..
    Need some advice. Thanks.
  2. Mendel Leisk
    38,727
    Not 215/45R17? What tires?
    Ours are Michelin Pilot HX MXM4 (whew), I've settled on 36 psi all 'round. Still pretty firm, turns you into a bobble head on every speed bump.
    Lifetime average currently is 4.9 litre per 100 km (48 mpg US)
    I wouldn't buy them again though: ours day GreenX, but the new ones don't??
    Might go with Primacy MXM4.
    PutPutMobile likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,300
    887
    Monument, CO
    The more psi (up to max rating on the tire), the better for mpg, but you have to balance that with ride quality. At higher psi, you might begin losing your fillings due to the harsh ride. In fact, I had to trade my 2013 Persona with OEM 17's due to the overly harsh ride, even at moderate psi. Now, I'm happy to report that the Gen 4 Touring models are much more pleasurable on their OEM 17's.
  4. PutPutMobile
    292
    518
    Buena Park, CA
    It's an non brand tires. Jinyu tires. Came with the rims. So 36 psi are good then. I'll check my tire pressure and change it to 36 to see the difference. The tires are halfway and I don't wanna waste it. Gonna get new tires probably the end of this year. Thanks for your input
  5. PutPutMobile
    292
    518
    Buena Park, CA
    My friends a mechanic. And he says the more psi near top range, the more I lose mpg on these 17's. I'll play around with the psi after every gas fill up. Thanks.
  6. Mendel Leisk
    38,727
    I doubt you'll lose mpg with higher pressures, but I think the improvements are a bit overblown. Especially with lower orofile 17's, the ride gets really harsh, the higher you go. I've gone down to 32, and up to 40: the first few pounds of raise is most significant, from there on up I saw little improvement.
  7. DavidA
    2,328
    1,812
    Chicago western burbs
    I never saw the point of making the already harsh ride of 17's even harsher still by hiking the tire pressures. Did that for almost a year. OEM tires lasted to only 30K miles. Backed them back down to 35/36 psi and enjoyed a better driving experience. Mileage isn't everything.
    Mendel Leisk and KennyGS like this.
  8. Mendel Leisk
    38,727
    Keep in mind too: if the ride is really jarring, it's might be reducing the lifespan of shocks and wheel bearings.
  9. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,318
    Central Virginia
    I personally set the right tire pressure to be the same as the left tire pressure...
    RMB and Mendel Leisk like this.
  10. DavidA
    2,328
    1,812
    This is smart. To not do that would wear out one side of the car more, and the the other side of the car less. You want to wear out both sides, less, like you are doing.
    I also use a very custom gaseous mix of 78% nitrogen, 21% oxygen and 1% argon and other trace elements. I know I'm right, but the tire dealers tell me that 100% nitrogen is a much better choice for the $10 they want to charge me.
  11. Mendel Leisk
    38,727
    Yeah, and why should I need to rotate tires: they get plenty of that, every time I drive!
    RMB and Prodigyplace like this.
  12. PutPutMobile
    292
    518
    Buena Park, CA
    Awesome.. Thanks guys.. I'll put that in mind..
