The seals between the engine and transaxle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by alexeft, Jul 10, 2014.
  1. alexeft
    alexeft Member
    142
    23
    Greece
    Hi all. Has anyone ever had, or have you ever heard of someone else having to replace the engine rear main seal and the transaxle input shaft seal because they were leaking? If yes, at what mileage?
    Thanks in advance!
  2. alexeft
    alexeft Member
    142
    23
    Greece
    No leaks??? :)
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Crankshaft seal leaks must be few and far between with the Gen 2.
  4. Mr.Electric
    Mr.Electric Member
    287
    103
    San Francisco
    That is a pretty common issue on non hybrids. I am not surprised to hear that one is leaking but I only wonder why rear main seal leaks are so rare on prius.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    No I don't ever remember in 8 years someone posting that.
    Especially anyone posting about servicing the trans. Lots of rr of used cvt's but never any parts replaced.
    You can be the first.
  6. alexeft
    alexeft Member
    142
    23
    Greece
    Be the first? No, thanks. I don't currently have a leak. I was thinking that perhaps I would replace them at some point as preventive maintenance but apparently, it's not needed.
  7. alexeft
    alexeft Member
    142
    23
    Greece
    Perhaps because there is no clutch to send its debris ripping the seals apart.
    Scallywag likes this.
  8. Patrick Wong
    18,200
    6,493
    If you already have removed the engine and transaxle for some other reason then it might make sense to replace the seals before reinstallation. Certainly there is no point in investing that labor effort for the sole purpose of replacing seals that have not failed.
    edthefox5 likes this.
