The Speedline 12 13 14 Toyota Prius V CREE LED Square Projector Fog Lights
Discussion in 'Prius v Accessories and Modifications' started by Air_Boss, Sep 7, 2014.
  1. Air_Boss
    Air_Boss Senior Member
    4,177
    1,171
    New Yawk
    • I installed The Speedline CREE LED Projector Fog Lights last weekend
    • Very nicely manufactured, direct plug and play, and functionally extremely slick.
    • The beam forming is razor sharp (and adjustable in vertical plane)
    • Color temperature matches OEM LED headlamps.
    • Now have a set of OEM fogs with H11 lamps available, if there is interest:
  2. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Very nice, I'd like to get a pair of those one day. :)
    Can you post a picture of the cutoff against a flat wall at some distance? Preferably with the lowbeams blocked?
    Thanks.
  3. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    What do you want for the old fogs?
  4. Air_Boss
    4,177
    1,171
    New Yawk
    $80 plus shipping
  5. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    any pictures available?
  6. Air_Boss
    4,177
    1,171
    New Yawk
  7. Air_Boss
    4,177
    1,171
    New Yawk
    The cut-off is razor sharp, but I'm still tuning them. To no one's surprise, I suppose, adjusting them with the car on ramps didn't quite cut it...
    I am still in process of rigging them to operate as DRLs (though aimed as fogs). Using a Philips DayLight4 LED driver module (hybrid revision 1.4) powered by the unnumbered open lug below the top-left "boxed" fuse #7 in the engine fusebox, triggered by fuse #28 (the OFF-intermediate-READY status issue resolved), grounded at the driver's headlamp mount to body strut. Final step is grafting the Philips DRL module power to the OEM fog harness.
    #7 Air_Boss, Sep 7, 2014
  8. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    I will take them when you are ready. Zip is 33772
  9. Air_Boss
    4,177
    1,171
    New Yawk
    They are ready. How would you like them shipped?
  10. Air_Boss
    4,177
    1,171
    New Yawk
    Looks like $12.65 Priority Mail Flat Rate Medium Box is the best value.
  11. xliderider
    8,140
    3,274
    Honolulu, HI
    Because the foglights are mounted low, and the cutoffs are so sharp, and stray light is minimized, they won't make the best drls.
    A better drl would be using the high beams at reduced power. Much wider visibility, and mounted higher up too.
    SCH-I535
  12. Air_Boss
    4,177
    1,171
    New Yawk
    True, which is why I am aiming them just above +/- level, which should be OK for forward conspicuity but not cause significant backscatter. They do have a nice broad pattern, BTW.
  13. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Best value is fine!
  14. Air_Boss
    4,177
    1,171
    New Yawk
    OK, how shall we settle?
    Just for the avoidance of doubt, just want to ensure you are aware that this is the lamp housings and Osram H11 lamps only, not the harness, relay, switch, etc.
  15. DaneH5
    DaneH5 Member
    464
    60
    Pinellas, Florida
    Yes, I understand.
    I could get a money order or some other method you like. How do you PM on this site? Not sure I have figured that part out here yet.
  16. Air_Boss
    4,177
    1,171
    New Yawk
    Just PM'd you. "Start a Conversation" is the link for a PM, in the userid box to the left, below userid.
  17. Air_Boss
    4,177
    1,171
    New Yawk
    The nabobery Speedline CREE square projector fog lamps are now available for sale, $80.00 shipped CONUS.
  18. Jarkko
    Jarkko Junior Member
    36
    Finland
    2012 Prius+ MPV
    Hi Air_boss,
    Thanks for sharing :)
    If you have a change to take a photo of the beam pattern against a wall it would be nice. With and without the LED low beams (for brightness reference).
    In ebay photos they look good, and they have E-markings (mandatory and enforced in annual inspection here in Northern Europe). Too pricey for me for now, but the price will come down :)
  19. Air_Boss
    4,177
    1,171
    New Yawk
    These were swapped out for a different combined DRL/fog setup which is now installed, so I can’t do the requested before/after, but here is an image from the speedline’s ad:
    https://images.app.goo.gl/YMrPnFcbC8ArF4uG7
  20. Air_Boss
    4,177
    1,171
    New Yawk
    And the CREE square projector LED fogs are SOLD!
    Thanks.
