The squeaky Console Compartment Door Hinge gets the grease?
Discussion in 'Gen 2 Prius Technical Discussion' started by jdtechtalk00, Jul 1, 2011.
  1. jdtechtalk00
    jdtechtalk00 New Member
    New York City, NY
    Happy Friday ladies and gents! ;)
    I hope that you guys are enjoying the beginning of an assuredly excellent Holiday weekend :) And now that I have you, I was wondering if anyone on this board has had the console compartment door hinge on their Prius make an annoying acute squeaky sound whilst opening and closing? I may be showing my anal-retentive colours here but nothing boils my oil more so then when some seemingly innocuous interior bit starts to make an irksome noise..
    If you don't know what part I'm talking about it's PNC #58907 in the diagram that I found on toyotpartseast.com:
    I'm now on a quest to quiet this vocal interior bit and would like to know if using WD40 or an equivalent product would suffice? Thanks in advance everyone! :cool:
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    A silicone based grease or oil would be better. WD-40 is mostly solvents with a small amount of oil and proprietary mystery ingredient(s). It's petroleum based solvents and oil aren't particularly good for plastics and it is a poor lubricant.
    If the squeak is metal on metal, then a drop or two of any oil would work. WD-40 would work too for metal on metal, but it's not as nearly as good a lube as regular old oil.
  3. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    I would recommend wax. Beeswax specifically. It will last the rest of the life of the car, won't stain anything, and won't weaken the plastic. Silicone oils may.
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    That is a piece of knowledge I did not posses. TY.
