The triangle of death comes and goes and there is no DTC codes.
Discussion in 'Gen 2 Prius Main Forum' started by derekc, Apr 9, 2018.
  1. derekc
    derekc Junior Member
    40
    The triangle of death comes and goes and there is no DTC codes. Why? Oil level low? No, I intentionally filled it up to the up mark and it still does it.
    I even have a mini PC running techstream and connecting to a 4G hotspot so that I can remote control it to scan code the moment my wife tells me the triangle comes out. Still no code.
    What could be the causes of the triangle come and go without registering any codes?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Can you take a pic of Techstream and post it?
    If the red triangle is illuminated, there is a code;).
    Any drive ability issues that your wife has noticed?
    Keep us posted (y).
    jerrymildred and JC91006 like this.
  3. JC91006
    16,468
    8,383
    You should check your coolant level at the radiator.
    I see your maintenance light is on, how low was your level?
    Raytheeagle likes this.
  4. derekc
    40
    Maint Req'd Light is because of oil change due. I plan to do it soon.
    Oil level is good. Coolant level is good. Inverter coolant level is also good.
    IMG_20180409_195827583.jpg IMG_20180409_195745015.jpg IMG_20180409_195716986.jpg
    The triangle only comes and goes. It is no longer there when she called me (but she managed to take a pic of it and texted to me.) It came up when the car was parked and engine started. She never noticed any driving issue.
    Techstream screen capture is below. I don't have the "health check" button for some reason.
  5. JC91006
    16,468
    8,383
    A common issue is the inverter pump fails and the triangle comes on. But it would come on for an extended period until the car cools down. Doesn't come and go in a minute
  6. derekc
    40
    I see the fluid running when the engine was running. Inverter pump is fine.
    I know oil level would trigger some warning but never register any code. What else could?
  7. 2k1Toaster
    6,035
    3,854
    Rocky Mountains
    Kind of left field, but it could be your door switch. For example if you put the car in D or B and open your door you should get the triangle and an angry message on the MFD. If your door switch is marginal then as you drive it may be detecting the door as open and that's the triangle?
  8. derekc
    40
    Possible. I will check it out tomorrow. It is actually a very good hint.
  9. derekc
    40
    Nope, not the door switches. When any door is ajar, there is also another warning on the dashboard:
    So, it is still a mystery why the triangle light comes and goes. Anything suggestion is welcome.
  10. bisco
    48,934
    how many miles on her?
    i wonder if there could be a loose wire or corrosion causing a bad ground somewhere.
  11. derekc
    40
    155K.
    And the aux battery is ok. 13V.
  12. jerrymildred
    jerrymildred Senior Member
    11,491
    14,099
    Tampa, FL
    I haven't had my Techstream out for a while, so I'm rusty and might be off in left field (again), but the pictures look like they are just for the HV system and all the other systems are yellow (unknown). Aren't there other things that can bring up the big red triangle?
  13. derekc
    40
    These black market techstream (V12) is tricky. Currently I am missing the "Health check" button and every time I need to click on each "section" to pull codes. Here is the description of the same problem that I will need to work on:
    Techstream installation issues (incomplete functions)
    I did click on each "section" and there was no code at all.
  14. JC91006
    16,468
    8,383
    If you disconnected the 12v at any time, that would erase majority of the codes stored. So next time when the red triangle comes up, there would be a stored code somewhere.
  15. bisco
    48,934
    13v is not right for the 12v. measure it at the jump point in the morning before opening the drivers door.
    edthefox5 and Mendel Leisk like this.
  16. derekc
    40
    I actually did disconnect the 12V battery over the weekend when I islotated it for charging.
    The issue is the triangle comes and goes. When it is gone, codes are still store somewhere?
    I really need to reinstall my techstream correctly to get the healthcheck button. It is so time consuming to scan each "section".
  17. JC91006
    16,468
    8,383
    It would be stored under "history" and not "current"
  18. derekc
    40
    Ok. Understood. I will learn more about how to correctly use TechStream.
    Wife driving it now. I will do that this evening.
  19. Mendel Leisk
    38,198
    I know Owner's Manual says that, but I've never disconnected for charging, never any problems. We drive only every 2 or 3 days, and I use a fast connected smart charger, pretty much constantly on.
    Note, if you measured that 13.0 volts fresh after charging, it'll ready falsely high, due to surface charge (no clue other'n that). You would need to drive it and let sit overnight, check voltage the next morning.
    probably nothing to do with your warning light, just saying.
  20. dolj
    dolj Senior Member
    7,478
    3,761
    Wellington, New Zealand
    I notice that the headlight level sensor error icon is on the MFD. Have you checked that sensor and the attachment arm are in good condition? It is located at the rear attached to the suspension. Not sure which side. The left, maybe?
    strawbrad, Raytheeagle and JC91006 like this.
