The two bendable connectors between hatch and body are called?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Behaines, Apr 8, 2019.
  1. Behaines
    Behaines Junior Member
    MD
    First I would like to thank the members here. I'm rebuilding a 2007 Prius with 152K. It had a lot of issues. Rear struts bad, module 28 in the pack was bad then balanced the pack, only one key so I did the dance, gummed hatch switch, coolant flow control valve, parasitic drain on the 12V, replaced passenger headlight assembly, both HID bulbs, both foglight assemblies, MFD, etc. Every issue a Gen 2 can have, this did. One issue is remaining. The dreaded water in the back. And nope, not a body frame crack issue, or under the black strip. No cracks found, but I did use silicone on everything just in case. The issue is with the 2 bendable rubber connectors from the body to the hatch. One carries windshield fluid, the other wiring. The previous owner ran a light bar through it.
    Would anyone know what they are called or a part number on them? ...And if a video exists showing their replacement? Windshield fluid line doesn't seem bad, I think I see the connector, but the wiring....that seems like another matter.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Had no luck searching an online parts manual.
    It might be quicker if you hit up the parts counter at the dealer and asked them, or show them a similar part on another nearby car.
  3. Behaines
    MD
    Thanks. I did the same. Search parts manuals for the 2007, or any Gen2 version of the car. Oh well, looks like a trip to the dealer. That's for the effort!
    B
  4. Elektroingenieur
    2,515
    3,277
    Three Touring
    For the grommet with the washer hose, see parts catalog Figure 85-04, Rear Washer. The grommet, which is shown directly in the illustration, not in the listing by part name code, has Toyota part number 82819-40750. The same figure shows the other hose parts, in case you need them.
    For the grommet with wiring, see image 8 in parts catalog Figure 82-02, Wiring & Clamp. The grommet is sold as part of the No. 1 Back Door Wire [Harness], part number 82184-47060.
    In one eBay listing for the wire harness, the seller included a photo of the grommet itself, which is marked with part number 82819-47050, the same as the one for the washer hose.
    Behaines and SFO like this.
  5. Behaines
    MD
    OK, so
    82184-47060
    and
    82819-47050
    (I tried to put links directly to Parts toyota and toyota parts deal, but I'm under the 4 post limit.)
    AWESOME!
    Thank you very much!
    Now I can finish up the combination meter replacement and then get the grommets wind wiring replaced! I might get this thing on the road by July! :)
    Elektroingenieur likes this.
