There is a ticking sound from the engine, loses power
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius2006GuitarGuy, May 16, 2025.
  1. Prius2006GuitarGuy
    Prius2006GuitarGuy Junior Member
    Sweden
    Hey!
    I was talking to anotehr Prius owner about my problems and he started talking about his problems, I thought I would post it here to help him out a bit.
    He has a 2007, with a new hybrid battery.
    But after he got it back from the shop, (he tells me) "There is a ticking sound from the engine compartment. The car loses power when you apply full throttle."
    I told him I'll ask you guys as I trust you guys more than the local mechanics here :)
    Any idea what the problem/s could be?
  2. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    It would be much better for your friend to create an account and create threads and add posts. When the information is going through a third person (you), things get lost in translation.
  3. Leadfoot J. McCoalroller
    7,825
    7,291
    Pennsylvania
    2018 Prius c
    I'll guess clogged catalyst with a little of the exhaust being forced to escape elsewhere
    ...and that really is a guess, so don't give it much weight.
  4. pasadena_commut
    pasadena_commut Senior Member
    2,215
    661
    Southern California
    Why was it in the shop?
    I agree, have your friend post here directly.
    Brian1954 likes this.
  5. Prius2006GuitarGuy
    Sweden
    My friend is on the older side, while most in Sweden speak English the older folk are kind of shy... and don't write in English.
    Car was in the shop to change the battery.
  6. Brian1954
    1,699
    663
    Which battery? The hybrid battery or the 12v battery.
  7. Prius2006GuitarGuy
    Sweden
    Hybrid
  8. pasadena_commut
    2,215
    661
    Southern California
    To do that they would have disconnected the 12V battery. Car loses all its settings and all of its tuning information. May run a bit rough until it relearns. I'm not sure how long that takes, couple of hundred miles? Somebody else here will know.
    That said, the "car loses power when you apply full power" isn't something I experienced after changing my car's HV pack. Nor were there any ticking noises.
    Did your friend get a new battery or a rebuilt one? The latter, at least in the USA, are very hit and miss.
    Since his problem seems to have become your problem, attach a competent scanner to his car and check for codes. Also check for the module voltages. The App "Dr. Prius" will provide a nice graphic of those voltages. Finally, open up the hood, get the car running, and see if you can localize where the ticking sound is coming from. It might not be the engine at all. The ABS makes noise, as do some of the pumps and valves. If you can hear the sound he is referring to make a short recording and post it here.
  9. Prius2006GuitarGuy
    Sweden
    Thanks! Will do!
