Thin sheet metal and powerful carwash dryers do not mix
Discussion in 'Prius c Main Forum' started by crebble, Nov 30, 2012.
  1. crebble
    crebble Member
    176
    47
    Shohola PA
    My C was covered with road salt and it was 30F so I took it to a local brushless to get a wash. I paid for the "extra" service with undercarriage wash and dry. In the drying cycle as the high pressure air went behind the sunroof I heard a loud pop as the roof dented in! Never had that happen before. It popped itself back and I can't find any creases but I won't be doing that again!
  2. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    Yikes! That's yet another reason not to drive the car through the Grind-O-Wash. Good to hear it didn't cause any noticeable damage.
    RocMills likes this.
  3. karabits
    karabits Member
    51
    Minneapolis
    I've taken my c through 2 car washes and that same thing happened to me both times as well. I don't have the sunroof, but I guess you having less sheet metal up there doesn't make a difference. There wasn't any damage to the roof on mine either. I'll have to try to remember not to take it through the car wash again, though.
  4. RocMills
    RocMills Active Member
    789
    276
    Las Vegas, Nevada
    I've got my eye on a place across town that is supposed to do a complete interior and exterior cleaning and detailing with no nasty machines involved. Entu is quite dirty, but with winter setting in I'm not sure I want to spend the money.
  5. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    Hm. I never have had any issues at my normal touchless carwash. Then again, I don't have the sunroof. I've had four different cars through it with no issues.
  6. MNBud
    MNBud Junior Member
    48
    suberb of Minneapolis MN.
    I have only washed my Prius by hand so far but you folks really have me nervous, have any other folks experienced this? I had no problem going out on a limb with a new model but this isn't exactly one of the issues I was hoping to hear about.
  7. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    I haven't used a touchless wash (yeah, yeah), but the drying portion of my car wash hasn't done anything like that. I do not have a sunroof. The little front windshield wiper does move around a bit and make me nervous, though.
  8. WiscPriusc
    WiscPriusc Member
    63
    37
    Wisconsin
    I have been through the touchless about 3 times now. Haven't had an issue, but perhaps the dryer fan speed is lower than some on the market?
  9. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Speaks more to poor construction on the Prius C as it's not an issue with other cars or other Prius.
  10. CMJAnew
    CMJAnew Junior Member
    87
    17
    Ah, another advantage to being CHEAP. I, when not washing at home, use the manual/wand washes in the area.
  11. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I've taken mine to a brush-less car wash multiple times no issues what so ever with the air dryer. I try not to use those brushes I think they cause scratches on the paints surface. So the other day I took it to a regular and used the nozzle only. If weather permits I just hand wash it.
  12. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I normally go to a self-service place - I have no idea if you guys have an equivalent - and basically just go around with the high pressure hose through its various settings. I don't use the "foam brush" stage which is basically a broom with suds coming out of it. When done, I chamois it down. This is normally enough as I do it quite regularly.
    Occasionally I'll wash it by hand in the wash bay here at home with sponge and bucket etc. I do it in sections and must be a perfectionist because it takes me foooooooorever*. Like every car I've handwashed since my mother had a 1996 Camry, the roof is not built solid like a tank. If you are putting a moderate amount of pressure on it, there is give in it. I don't have a sunroof, but it seems normal to me for a modern car.
    * Admittedly the last time I handwashed it was because I was asked to fill in at the last moment as a wedding car, so I did want it utterly spotless.
  13. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    I've been taking my C2 through the touchless wash at my local gas station since I bought it in April and I've never had any issues using the "blow dry". And I always use the dry cycle, and I don't have a sunroof.
  14. CAlbertson
    CAlbertson Member
    99
    24
    I bet this was caused by thermal expansion of the sheet steel. Your 30F roof was changed to 120F roof and in the process got slightly larger until it cooled off
  15. shuiwm
    shuiwm Junior Member
    New York, NY
    have my C4 wash last night, no problem on the blow dry, I do have a moon roof though
