Thinkdiag to program key
Discussion in 'Gen 3 Prius Main Forum' started by kolez2000, Feb 5, 2022.
  1. kolez2000
    kolez2000 Junior Member
    64
    West Africa
    Anyone use thinkdiag scanner to program car key. How do I go about it? No key available for the car as we speak, new keys will need to be bought.
    51,148
    never heard of it, and don't recall ever reading about it. tech stream is the only one i have read that works
    kolez2000 likes this.
  3. kolez2000
    64
    West Africa
    Thanks. That is the scanner I use to work on Prius and other cars I have worked on. From Benz, Lexus, dodge, getta, Hyundai, and many more....it also actuate.....I want to program key for a Prius next week, so I want to know if it can do the job. I can also work on the immobilizer
  4. PriusCamper
    PriusCamper Senior Member
    12,061
    4,894
    Pacific Northwest, USA
    Toyota Techstream on an old windows machine via a mini-VCI dongle will allow you to wipe and reseed electronic keys. Catch is it's a secure feature that only electronic locksmith's and dealerships can afford the monthly fee for. Alternatively there's a service in the EU that for ~$40 will do some math with your VIN# and give you the code to access the wipe and reseed function. If you google it you'll find plenty of threads on here about it.
  5. usafxai
    usafxai Junior Member
    San Angelo, Texas
    i-Tech
    devices other than Toyota TechStream + Mini VCI cable can also do the job
    you need to check whether your ThinkCar / ThinkDiag device has the feature to begin with
    the option is probably named "all keys lost"
    There are YT videos on how to perform the procedure
    SFO, kolez2000 and bisco like this.
