Thinking about aftermarket wheels and tires...what do you think?
Discussion in 'Prime Accessories and Modifications' started by Dudley1030, Dec 28, 2017.
  1. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    #1 Dudley1030, Dec 28, 2017
    padroo and RuthlessTactics like this.
  2. RuthlessTactics
    RuthlessTactics Junior Member
    Chicagoland
    I like those rims. Did you buy them? Any change to your MPG?
  3. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    Heard you’ll need a tpms took to reset
  4. Mendel Leisk
    38,726
    If you transfer existing sensors over to new rims it's ok, no change?
  5. padroo
    padroo Senior Member
    2,763
    2,250
    I drove over to Tire Rack in South Bend Indiana in December and bought four of those same wheels. They are still in my garage and I am going to mount four new tires on them in the spring.
    I bought four programmable Autel MX-sensors and the tool to program them. Just waiting till spring. Fine minds run alike. lol
    I cloned my new TPMS sensors with the information from the originals so the car will not know the difference, at least that is my plan.
    Those wheels are drilled for two different stud spacing, I liked them because with the center caps everything is covered up and easy to keep clean.
    kevins007 likes this.
  6. Dudley1030
    200
    139
    Lawrence, KS
    I bought one. To try on the car and to use as a spare. I haven't had time to mount it yet and it's too cold! I went to Puerto Vallarta for a week!
    RuthlessTactics likes this.
  7. Dudley1030
    200
    139
    Lawrence, KS
    Yes i think it would work if you can transfer them to the new wheel. I like what the next post has about cloning the originals.
  8. Dudley1030
    200
    139
    Lawrence, KS
    I think I will look into the clones.
  9. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I like the design.
    Otherwise, FWIW, what are you trying to accomplish?
    In the first photo, those rims, maybe 15 inch, could be larger, maybe 17 if artistically one wishes to fill the wheel well better.
    Unsure about the 38 mm offset comment. Maybe you are referring to possibility that tire will hit the fender liner during turning or compression? I don't know.
    Larger diameter and or wider rims usually equate to a rougher ride.
    Tires - high mileage or race or all season with snow. Noting this website offer much research on road noise, MPG increases, brands etc.
    Lastly, be aware of the weight, tire and rim combined. IMO lighter is always best for any performance, yet rim damage from pot holes is always a possibility and be aware of long term availability of a replacement rim if needed.
  10. padroo
    2,763
    2,250
    That wheel without the center cap has 10 holes to fit two different bolt patterns. I liked the center caps because they hide all 10 bolt holes. They are impossible to clean. The center caps are aluminum not plastic.
  11. Mendel Leisk
    38,726
    One thing that bugs me about the rim in post #1 is the spindly spokes and big gaps: it will show the brakes a lot, and depending on your taste that's good or bad. I like the 2012 PIP (15") rims, they're a little busy, but overall like the look. Have a set, just trying to figure out what to do with them. Our OEM's are the 17", and I'm pretty much resigned to the PIP rims becoming the snow tire rim, when the current snow tires (on black steel Corolla rims) get too low.
    padroo likes this.
  12. padroo
    2,763
    2,250
    A lot of people like the open look of the wheel and then do the drilled and slotted rotors with an off color caliper cover. This is really popular today. You either like it or you hate it.
    If everything is rusty behind the wheel it's best not to draw attention to it. Lol
  13. Skapruisprime
    122
    49
    MA
    I will be looking to get a set of wheels (with snow tires). Let me know how this set goes if you get them, thanks
    Dudley1030 likes this.
