Thinking about buying a 2013 used Prius
Discussion in 'Dealers & Pricing' started by Richy2010, Jul 2, 2015.
  1. Richy2010
    Richy2010 New Member
    Oceanside, CA
    I currently have a 2011 Camry that I want to trade in for a Prius. I found a few 2013 Prius Two, not II since it is not a 2010, models for around $14~15k but they are not certified. I found some that are the same year with the same mileage(40-50k) but are certified but they are in the high $19k low $20k. Should I really purchase a certified one since it is a hybrid, or go with the non certified? What would you guys recommend? Thank you!
  2. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    I wouldn't get too hung up on certified cars. I've looked at some so-called certified cars before I bought mine and found that even routine maintenance wasn't done Sometimes. Dirty oil, low fluids, bad tires, Etc. just a thorough going over from front to back at your local Toyota dealership for other shop that specializes in hybrids should be enough. They'll be able to point out anything obvious out might need to be done. Good bargaining power. and don't be afraid to look at fleet vehicles. I actually got my 2013 from the local Hertz rental car lot. And I actually got mine at $13,000, certified with a one year or 12,000 mile warranty. So it pays to shop around.
  3. HybridBull
    HybridBull Junior Member
    Tampa
    You might be able to find a new 2015 in the low 20 range, with the incentives that Toyota has been offering lately.
  4. CardiffChris
    CardiffChris Member
    94
    63
    Cardiff by the Sea, California, USA
    2014 Prius Plug-in
    Wait for the 2016 Prius to hit the showrooms.
    Then go make your deal on a New 2015.
  5. FuelMiser
    FuelMiser Senior Member
    1,303
    890
    Monument, CO
    Since these cars are so reliable, I would not be concerned with CPO. We have bought three pre-owned, none certified and have had no issues.
  6. bisco
    49,693
    welcome! due diligence on the non certified, a $100. inspection at toyota, and you should be fine. all the best!(y)
