Thinking of 2012 Prius v but need advice
Discussion in 'Prius v Main Forum' started by riche613, Nov 30, 2013.
  1. riche613
    riche613 New Member
    I currently have an '06 base Prius( my second Prius, had an '04 first) that I got in Feb 2012 at 62,000kms for $13,000 and lease it for $365/more with a buy out if $2200 Feb 2015. Its now almost at 150,000kms and my wife and I are thinking of upgrading to a v now that we have two kids.
    The thing I'm worried about is gas range. I currently fill at one bar for just under $40 CDN and get about 500kms(far less than when I got it for some reason). I know that the tank in the Prius V is the same size but am worried about how much more I will spend a month in gas. I drive about 110km a day 7 days a week.
    Just wondering what other people get out of their Prius V tanks for range and also is $19,000-$22,000 for a base 2012 v a good deal? I can finance it for $289/more for 84mo or $315/mo for 72.
    Any advice or tips would be a lot of help. Thanks.
    Galaxy Nexus ?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,601
    4,458
    Texas Hill Country
    You can get 450 miles range without trying hard. That's 724 km.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    Mine has varied a lot depending on conditions. You might want to assume 5mpg under what the hatchback would get. Keep in mind that ANY of the Gen-3 models can get you better MPG than you get with your Gen-2. My range has been 440-520 miles per fill. You can see anyone's records by following the Fuelly links in their signature.
  4. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I am of the 'just drive it' camp, and I get about 400 miles per fill up, and just over 40 MPG. If you need a station wagon, none is more frugal. If you don't need a station wagon, you can do 10 MPG better with a Liftback.
    ewxlt66 likes this.
  5. riche613
    riche613 New Member
    Wow! 400+miles? I get around 310 in my hatch and that's going 92km on the highway(100km limit) and using the tap and glide a bit but a lot of "ev" mode when you just every so slightly push the pedal. What am I doing wrong? Admittedly I only get my oil done every 10,000 kms and haven't gotten my tranny fluid changed yet but I just had my bearing redone a few months ago.
    My daily drive is 60-70% highway BTW the rest city
    Galaxy Nexus ?
  6. riche613
    riche613 New Member
    Now I'm really thinking about getting one if I can get almost 100+extra miles per tank compared to my '06
    Galaxy Nexus ?
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Compared to a Gen 2 the tank really is 11.9 and the gas gauge really works, so you can use more of the tank It gets about 5 MPG less than a Gen 2
  8. riche613
    riche613 New Member
    Its just so weird that I get half of what you guys say the V gets. I haven't gotten more than 350 miles out of a tank in almost 6months
    Galaxy Nexus ?
  9. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    350 is way more than half of 400.
    400 miles /10 gallons = 40 MPG
    350 miles / 7.8 gallons = 45 MPG
  10. riche613
    riche613 New Member
    Maybe my batteries are starting to die? I've had to get a boost about 4-5 times in the past two years.
    Galaxy Nexus ?
  11. riche613
    riche613 New Member
    Lmao haha sorry I'm thinking kms then converting to miles and not thinking right
    Galaxy Nexus ?
  12. riche613
    riche613 New Member
    7.8 gallons? You mean a full tank? I know my manual says the tank is 11.9 so I'm confused
    Galaxy Nexus ?
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  14. riche613
    riche613 New Member
    Does the Prius have a "normal" car battery for starting as well as the hybrid batteries? (About to check ur link now)
    Galaxy Nexus ?
  15. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    OK I switched my fuelly to use kms and liters. Here are the last 10 tanks:
    Code:
    Date	 kms  Litres  km/L Price
    11/26/13 616.4 38.48 16.0 0.827
    11/20/13 614.8 35.47 17.3 0.753
    11/12/13 675.9 38.49 17.6 0.745
    11/5/13 640.5 36.02 17.8 0.768
    11/2/13 638.9 37.88 16.9 0.827
    10/30/13 647.0 37.46 17.3 0.768
    10/25/13 680.8 39.10 17.4 0.779
    10/17/13 721.0 39.64 18.2 0.798
    10/12/13 614.8 34.50 17.8 0.819
    10/7/13 574.5 33.87 17.0 0.798
  16. mikefocke
    3,642
    1,628
    Sanford, NC
    I'm with Jimbo. Great wagon with mileage. There are better/bigger wagons. And better mileage cars. But I haven't been able to find a better combination of both utility and fuel use or I'd have bought something else.
    Wander over to fuelly.com and set the display to your preferred units. You'll get real world numbers and see just how good and bad fuel use can be for any car you might be interested in. You'll be amazed at the spread for the same car. Even conditions change things immensely. Then run a spreadsheet comparing your cost to buy or lease and the costs for fuel over whatever period you choose for your current car and any planned new one. I even set fuel to become more expensive in the out years.
    No matter the mileage, the cheapest car in the short term is the one you have now. But with the change in family, your needs can change. And that car is getting on.
    Only you can figure out what is most important to your situation when utility and finances intersect.
  17. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    It has some unique feature as it is inside the passenger compartment with your loved ones.
    It is AGM, so it has very little free battery acid. (good if there is a wreck)
    VRLA battery - Wikipedia, the free encyclopedia
    It is externally vented so neither Hydrogen gas nor Sulfuric acid mist build up pressure in the battery if things go wrong.
    Additionally it is sized small as it never starts the engine, and has odd posts more often found in Japan. (JIS vs SAE in the US)
  18. shawnpjh
    shawnpjh Junior Member
    2013 Prius v wagon
    My Prius V reports I have about a 450 mile range. But I'd recommend no one let their tank routinely go to Empty due to the trash that can accumulate over the years at the bottom of the gas tank. 450 miles is a non-issue. Most cars will be way less than that. If you really need more, Ford C-Max has a 600 mile range or 620 in the Energi model.
