Thinking of buying a 2005 prius, what should I look for when inspecting?
Discussion in 'Gen 2 Prius Main Forum' started by arewethereyet, Mar 4, 2012.
  1. arewethereyet
    arewethereyet Junior Member
    48
    Oregon
    If there is a previous thread that you can point me to, that would be great. If not, I'd appreciate suggestions.
    Is there any way to see if the HV (not sure if that is correct term) battery is okay?
    Anything else to look for beyond the normal used car items?
    Looking forward to being a prius owner
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    The gas mileage is almost always the most important clue as to the car's condition. If it is in the 40s then there probably is not anything significantly wrong. The HV battery is difficult to test without scan tools, and even then the results are sometimes difficult to interpret.
  3. uart
    uart Senior Member
    4,215
    1,200
    Australia
    I agree about the gas mileage being a good indicator. Unfortunately however the displayed MPG can sometimes be uncharacteristically low on a car that is for sale.
    When I got my 2005 a few years back I knew nothing at all about the Prius. I didn't even know how to access the displayed MPG on the multifunction display. As soon as I got it home and figured that part out I was a bit shocked to find it was only about 30 MPG (current tank average). Yeah I thought I'd bought a lemon.
    After driving it around for a while however I found I was getting 50+ MPG, and still to this day are getting great MPG. In hindsight I guess that the car had been filled at the dealers and only driven very short distances around the lot and short test drives. So the displayed MPG was absolutely not indicative of what the car could really get. Actually I'm kinda glad that I didn't know how to read the MPG back then because if I did then I probably wouldn't have bought this car, and would have missed a good deal because it's been totally faultless for 3 years now.
  4. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    So that's what a person needs to do, reset the trip meter on the Consumption page, and take a 10 mile out+back (20 miles total) drive. This has the added benefit of being an OBD II trip, so that if they are trying to conceal an emissions problem (P0420) it will likely pop a check engine light for it.
  5. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Great advice. :thumb:
    And don't necessarily be put off by a low current tank MPG reading before you drive it. :D
  6. Fouramphs
    Fouramphs Junior Member
    Orillia Ontario
    Its a real mess on my car..
    says 5.2 L per 100 klms./
    yea Im in Canada
  7. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    If buying from a private party, which should be the only way on a used car. Road test it, talk to the owner, see if what he says conforms to what you see and feel. There should be no major repairs!. Never a salvage vehicle. 12V battery good? A 10-20 mile suburbia or city drive will tell you if the HV Bat is charging and discharging normally.
  8. SteamPowered
    SteamPowered Junior Member
    39
    Arizona
    Maybe I'm stating the obvious but get a critical look at it from a Toyota dealer mechanic. They aren't perfect but doubtless they will point out several major repairs. You can then use the bill, which should be extremely high for the actual work, to hack down at the asking price.
    Also key is looking at the engine code history which the Tech will do, and looking at the service records for the car, which the dealer can pull up. Definitely look for things that might be a red flag.
    I would also check the rear struts to see how much fluid leakage there is. Leakage is sort of a qualitative thing, Somehow a Toyota mechanic missed this on my inspection but then two other mechanics definitely said the struts needed to be replaced.
    Also the original 12V battery often has problems. Get the tech to check the health of the battery under load. Also check the inverter pump, was this replaced? This seemed to be a major problem in gen 2 priuses. Mine was dealer replaced so I shouldn't have to worry about it.
    It took some finangling for me at the dealership to actually be there with my car when they inspected my car, which is good because I had to prod the tech to actually do the work I asked the service manager.
    BTW once you get your car, avoid if possible, doing any work at dealerships.
  9. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    In my experience, when buy used car, the first "thing" you should evaluate is the seller!
    Talk to him, and let him talk a lot. Keep your brain cool and rational. You will sense if he is honest. Let him drive the car, to see his driving style. Ask for records on maintenance. I bought one new car, and more than 12 used cars, and also helped my friends bought some. None of them are lemon, even GM and Chrysler.
