Third brake light is not working
Discussion in 'Gen 2 Prius Technical Discussion' started by sammynaz, Dec 3, 2023.
  1. sammynaz
    sammynaz Junior Member
    Walnut CA
    Does anyone know a common problem with the wiring to the high middle brake light on a 2nd gen Prius ?
    The light works but it’s not getting 12 volts
    52,755
    not that i recall reading, is there a fuse?
  3. sammynaz
    Walnut CA
    One fuse for three brake lights and it’s good !
    52,755
    i would look around for a wiring schematic. check online, library, techinfo.toyota and etc.
