Thoughts on 24 Prime XSE power liftgate kits
Discussion in 'Gen 5 Prius Accessories and Modifications' started by AddMoreGas, Mar 17, 2025.
  1. AddMoreGas
    AddMoreGas Junior Member
    78
    43
    57
    Dallas
    2024 Prius Prime
    XSE
    Hello, The only thing we really miss about previous car that we don't have in our new 24 Prime XSE is power liftgate. I see there is a kit available for ~$500 shipped on aliexpress as well as ebay:
    OEM Car Automatic Lifting kit Opening Trunk Intelligent Electric Tail Gate Lift Tailgate for Toyota Prius XW60 2023 2024 2025 - AliExpress
    Anyone have experience with something like this? I have installed similar kits in the past and not worried about the install itself, looking to see if anyone has real world feedback or experience with any prius kit.
    daisy555 and RandyPete like this.
  2. MSantos
    MSantos EcoAccelerometry
    585
    256
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Although my 2024 Prime has the factory power tailgate, I would certainly consider installing one if I had purchased one of the other two trim levels.
    Because I did a similar install on a 2018 Advanced and 2020 Prime LE, this would be something I would do without hesitation as long as its a kit from Autoease. Yes, their kits would perhaps be more expensive than the AliExpress example you offered, but I would trust their XW60 kit which in my opinion and experience, is likely to be as good and reliable as the ones I installed in my previous gen primes.
    Power Liftgate Retrofit – Autoease Technology
    In my view, if a kit like this can open a frozen hatch in -30 temperatures over multiple winters then its OK in my books.
    Cheers
    ms
  3. AddMoreGas
    78
    43
    57
    Dallas
    2024 Prius Prime
    XSE
    Thanks!! Exactly the kind of feedback I was hoping for.
    Question - did the auto ease kits come with the switchgear for the front dash? Does it replace any existing blanks or did you have to drill? I've installed a power frunk kit on a Tesla so I'm familiar enough to know replacing the lock mechanism is probably the most of the work involved. Is that true?
  4. MSantos
    585
    256
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    Yes indeed.
    It is full featured and usually comes with almost everything one needs.
    Specific to your questions:
    1. Illuminated surface "flush" mounted buttons for the dash. Requires drilling into a spot of your choice on the lower dash. Hole cutting drill bit included (20 mm).
    2. Illuminated surface "flush" mounted buttons for the tailgate. I chose to remove the right pocket handle and mounted it there with an aluminum plate covered with carbon fibre PPF.
    In fact, the factory power tailgate on the 2023-2025 Primes does NOT come with a foot proximity sensor, which this Autoease does. I miss that on the 2024, and adding it is definitely one of my summer projects.
    It may help to check on what other folks have done via some Youtube videos. You may also check this thread too:
    Aftermarket Power Hatch Kit - Installation Guide | PriusChat
    Cheers
    AddMoreGas likes this.
  5. Hammersmith
    Hammersmith Senior Member
    1,959
    1,964
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Might I suggest buying an OEM open hatch button for a LTD/XSE+ and trying to make that work instead of drilling into your dash to mount an aftermarket switch.
    Although the OEM switch is pretty expensive, so I can understand not taking the chance on one.
    84966-16020
    $102.86 MSRP
    $71.12 regular 31% discount
    $56.90 31%+20% sale
    $53.34 31%+25% Black Friday sale
    Switch, Power Back Door Control
    MSantos and AddMoreGas like this.
