three little questions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AbuS3ood, Apr 25, 2010.
  1. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Hi All;
    1. I need to replace my front brakes for my 88k 06 prius, the dealer told me that i need to leave the car for 3 hours to replace the brakes :confused:,
    I used to do it my self for my prev car, does the prius need and thing special to replace the brakes than regular cars or its just replacing the pads with the new ones???
    2. i have recently made wheel rotation and switched the front with the rear, now i feel the the steering keeps dragging me to the left :-S its dragging slightly but my hand hurts when long distances, a friend told me that the mechanic might replaced the right one with the left one and i need to switch the two front wheel with each others, is that right??? I already check the pressure for each,
    3. is it mechanically safe to use N gear ? i often need to switch to neutron on my way back to home, if i used the N i rarely need to brake and the car keep slightly on 40 MPH till i get home, if i kept on D i'll need to press the gas pedal to keep my speed, is it healthy to switch between N and D rapidly?
  2. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    1. Just replacing brake pads like any other car.
    2. Are all wheel bolts torqued correctly? Is a front tire obviously worn heavily on one side? Have suspension checked and aligned if the easy things don't provide a quick answer.
    3. I'm not the expert. I do not see a problem but I'm curious as to why? Coasting might save a very small amount of energy but does the effort really justify the savings?
  3. Patrick Wong
    18,200
    6,492
    #1. The Prius friction brakes are of traditional design. However you should disconnect the 12V auxiliary battery before you start working on the front brakes. If you do not, then the caliper piston may come out of the caliper due to pressure from the brake pressure accumulator pump, or you will find it difficult to compress the piston into the caliper to make room for the new brake pads. Also, an error code in the skid control ECU will probably be logged if the 12V power is connected while you are working on the brakes.
    Do not allow air to enter the brake hydraulic system upstream of the wheel cylinders. If you do then you will need to ask for Toyota dealer assistance to purge air out of the system (as the Toyota diagnostic laptop is required to open and close the various solenoids in the brake system.)
    #2. You can try moving tires from side to side to see if that will help. Possibly your car needs a wheel alignment anyway. A correct wheel alignment will require the Toyota diagnostic laptop to perform VSC zero point system calibration after the steering wheel is centered by adjusting the tie rack ends.
    #3. It is not healthy to switch between N and D rapidly from the point of view of eventually wearing out the shift selector which costs ~US$300 here in the US, probably much more in your locale.
    As you continue to gain experience driving the Prius you may find that a very slight press of the accelerator pedal will allow you to coast, while the MFD shows you that your current mpg is 99 (which is evidence you are using no or very little gas.)
  4. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Thanks alot guys,Patrick Wong you just hit the point directly and your notes was valuable, but u know what? im sure that Toyota Only local dealer dont know anything extra than changing like any other car
    "If you do then you will need to ask for Toyota dealer assistance to purge air out of the system" they dont know anything about that things so i'll do it my self.
    about the N shift its noisy to press the gas pedal softly to reach the neutron but i'll manage to avoid using N.
  5. roderunner
    roderunner Junior Member
    new mexico
    Regarding question #2 - If you drive in the left lane of 2 or 3 lane highway - if you drive to the left of the crown you might notice slight pull to left - my 07 seems to be sensitive to this. Don't know if the steering can be adjusted for this.
    To Patrick Wong - The owners manual suggests using B for slight braking - will using B wear out the shift selector as you say using N will? Do you mean shifting rapidly or repeatedly?
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    B Mode is to be used on large downhills, when the HV battery may fully charge, leaving you with no regenerative braking. It is not needed in any other circumstance, and always gets worse gas mileage than slowing down in D.
    The first mention of B mode in my manual shows the car going downhill.
    "Avoid vehicle speed increases when driving downhill. If the vehicle speed is too fast in relation to the cruise control set speed, cancel the cruise control then shift the shift lever to “B” position to use engine braking to slow down." is the second mention
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hello Abu, I think we're losing you a little in translation, but as for point 3, no it doesn't really do any harm to switch back and forth between "D" and "N" at 40MPH. Some hpyer-milers do indeed practice this for maximum efficiency gliding on gentle inclines. Just be careful not to accidently shift into a "neutron star" by mistake, they're really heavy can smash you up pretty bad. :nerd:
  8. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Thx uart, im doing my best when writing because english is not my natural language :nerd:. thanks for you information, but about "neuron star" is that a joke ?! because i was lost in translation, did u miss an r ? :)
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Year that was supposed to be a "neutron star". :0
    Neutron is a sub-atomic partical, neutral is a position on the gear shift selector.
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    Yes, that was a joke. In the first post you used the word "neutron" when you meant to use the word "neutral."
    Tom
  11. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    i'll use the letter N next time
  12. patsparks
    10,664
    567
    Adelaide South Australia
    News flash!!
    Prius Chat has a fair share of smart Ar%ses!
    Count me as one of them.
  13. cnschult
    cnschult Active Member
    772
    97
    Michigan
    does anyone find it a little suspect that he needs new pads at 88K miles.
    my brake shop examined mine and said they would last at least 300K miles, I had them clean and adjust the rear brake drums which tend to squeek if you don't do this every 40K miles or so.
    I was warned that my front rotors were starting to rust from non use of the friction brakes. (yes I love to use regenerative braking) traditional cars have rotors outlasting the pads, but the prius is opposite, the pads outlast the rotors. To avoid this problem they told me to slam on the brakes every 10 to 14 days so that the friction pads can knock off any accumulated rust.
  14. AbuS3ood
    AbuS3ood Member
    113
    Jordan
    Good point cnschult, i had the same suspect but i have seen the pads my self, i have just imported the car from USA month ago and i dont know what the previous owner was doing, the car fax showed that he was a good owner and did all maintenance on time, i don't know what is the reason for changing the pads early ?!@#$%^
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    regarding the brakes... traditionally you bleed the system to release pressure. i wouldn't loosen anything.. simply use a 2x4 or a 4x4 piece of wood, prop the caliper against the shock housing, and lean into it.. the caliper will retract. pop the top off of the brake reservoir to make back pressure easier to deal with. slip the pads back on, and slide it back over the disk.
  16. Patrick Wong
    18,200
    6,492
    Or, use a C-clamp to compress the piston back into the caliper, making sure not to damage the caliper's polished surfaces.
