Three month stay
Discussion in 'Gen 2 Prius Main Forum' started by combsad7, Jun 23, 2009.
  1. combsad7
    combsad7 Junior Member
    51
    Western Kentucky USA
    I have to leave my 2008 Prius for sure for two months maybe three months. I will put a 1.5 amp charger for the 12 volt battery but how long will the main battery last?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It's in the owners manual. As I recall it was 6 months min. It's -completely- disconnected, both sides, so only "self discharge" occurs.
    Make sure the charger you use is designed for this. Most will overcharge the battery. A "battery tender" won't. They are designed for motorcycle and other rec. vehicle batteries that you leave for 6 months at a time.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    To reiterate to the OP
    Make sure you are using a correct battery tender that is fully automatic, to keep a "float" charge on the battery. The better tenders also condition the battery, like this one:
    BatteryMINDer® Plus 12 Volt 1.33 Amp Charger-Maintainer-Conditioner (Desulfator) :: All :: Battery Chargers by BatteryMINDers.com
    Never, ever hook up a regular full time "trickle" charger. If left on for a week, certainly for months on end, they will destroy a battery
    I wouldn't worry about the NiMH traction battery. If it's in the low blue's on the display, there is a procedure known as "forced charge" that you can search here on the forum
  4. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    I have left my 2008 for over 3 months without a tender twice.
    Started right up both times when i returned home...
    No problem!!!!
  5. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    If you're worried about it, get the battery charged up before you head out.
    Forced charging is accomplished by shifting to D, holding the brake pedal firmly, and stomping the throttle. The ICE should kick in and charge. Don't let off the brake, lest the predictable result will occur.
  6. derh2o
    derh2o Junior Member
    34
    We left town for 2 months and the battery was dead. it was easy to jump start the battery. it has worked fine since.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Run a battery flat dead once, its life and capacity are diminished. Do it often enough, the battery is toast
