Throttle "Glide" postion button/mod
Discussion in 'Gen 2 Prius Accessories & Modifications' started by problemchild, Sep 19, 2008.
  1. problemchild
    problemchild New Member
    429
    37
    Is it possible to tap into the throttle to install an on/off button that would imitate the glide throttle position? Its difficult to stare at the mfd and move your size 14 dress shoe 1/1000th of an inch to attain glide 600 times per day.
    It would be much simpler to have an on/off button (you could even use the never used rear defrogger button) to accomplish this.
    And YES I know you find this question silly and cant comprehend why I would ask it. Its so simple for you to get into glide why am I having such a hard time with it. Please avoid the compulsive need to hijack this thread.
  2. Flying White Dutchman
    4,376
    313
    wy not switch to N you have instant glide
    or is it not good to switch like that when driving?
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    This has come up before and many of us would like to have something like it. The problem is that the throttle position isn't exactly the same under all conditions.
    That said, there probably is a sweet spot for most glides under 40mph and it would be great to have a button that 1) automatically put you there once you hit the button.
    2) disengaged upon hitting the throttle or brake. It doesn't seem that complicated to do on a by-wire vehicle like the prius for someone who knows how to build a circuit to do the job.
  4. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    What we want is a "hold throttle position" function of some type. Obviously we need to be able to instantly override with our foot, and that is a major issue in implementation for safety reasons.
    If we lift our foot completely off then we want to switch to regen. If we push deeper into it we want to proceed up the throttle range. The only way I can see to do this is by making the pedal "firmer" on either side of the set point so that it is less jittery to mild input changes. The problem with finding the magic spot now is that the tiniest bit of vibration/road surface aberration will shift you back and forth across it. If we could invoke this with a button on the shift selector/etc. and disable it the same way (and with any brake pedal input) then we might have a decent solution.
  5. dwreed3rd
    dwreed3rd New Member
    742
    Marietta, Ga
    I realize this won't work @ =<25mph and we're still on the "List", but I use the cruise control +/- on the steering wheel, for fine adjustments of the throttle, on our Avalon. I don't know if it's a small enough change on the Prius. It's ~1mph on the Avalon. I know it may sound crazy, but I have gotten used to using CC anytime I can keep it above the 25mph cutoff for extended periods, even in traffic. Once I get to desired speed I use the +/-, unless it's not quick enough, to adj speeds. The speed adjustments are much finer than I can make with the throttle and I do get improved gas mileage over using the throttle. It's really easy once you get comfortable with using the CC over the throttle. Just though I'd pass it on. Don't have our Prius yet, so I can't try it.
  6. miscrms
    miscrms Plug Envious Member
    2,079
    526
    Phoenix, AZ
    It should be possible. I believe the throttle control is just a variable resistor. By using a switch to either add the right amount of resistance in parallel or series, you should be able to get the 0 throttle position to have the right resistance for glide. The fail safe part of it would be a little trickier. There should be a way to have the brake light switch disengage the glide switch though.
    Rob
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I'm no expert, but what little I know may tide us over until the really smart
    posters come in.
    If I recall corectly, starting in 2006, the accelerator,"go pedal," has two
    outputs from Hall Effect sensors. In some way, the signals are compared to
    determine exactly where the pedal is in its full range of travel, and whether it
    is being depressed or eased off, and how fast that is occurring. I think it is
    uncertain if the zero state, no pedal depression, is zero output or some small
    reference values.
    In some off-forum exchanges I have had on this, it was stated that hacking the
    accelerator outputs would probably send the ECU(s) into an immediate state of
    panic.
    FWiW, I came to the belief that it would be far easier to use an external,
    mechanical arrangement to fiddle the pedal itself, not the outputs. I have been
    messing with a low pressure air arrangement with variable results for a few
    months now.
  8. sandman
    sandman Member
    277
    32
    kentucky
    I wish there was a way to do a true glide from 50mph down to 40mph instead of the 40mph to 30mph. It sure would be much easier to do it all the time without impacting the flow of traffic...
  9. problemchild
    429
    37
    Genius!
    All you need is a small electric solenoid that pushes the pedal x/y inch forward to accomplish glide. This is great. Now what kind of solenoid would do the job?
  10. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    I know very little about electrical stuff, so I can't really help there.
    Nonrtheless, here are some general comments:
    The system has to deal with only a very small range of motion, in total less
    than 1/4 inch. Finding the right actuator -- stepping solenoid? -- is only half
    the battle. The input device must be highly sensitive to intended inputs, yet
    not be subject to spurious inputs from bumps and such. When I was thinking
    of an electrical solution, I decided a large rotary knob mounted in one of the
    cup holders in the center console would do the trick.
    But there is no need to restrict yourself to an electrical solution. A cable
    actuated arrangement could also work. There are all kinds of fittings and
    connectors available in bike shops.
    As other posters have pointed out, whatever approach is used, the system
    needs to return to zero whenever the gas or brake is used. This can be
    accomplished in a mechanical system by spring loading the input mechanism
    to go to zero -- think of the hand brakes on a bicycle.
    To be really useful, the system should convert relatively large inputs to small
    outputs. In my experience, 4 or 5:1 would be ideal.
    Unlike the direct approach of messing with the go-pedal electrical outputs, a
    mechanical solution accepts that there is many unknowns in how the ECU(s)
    handle the signals, including safety related overrides and cutouts. So, a
    mechanical solution is not a hack per se. I have come to think of it as a "finesse."
    Regardless of how it is actuated, a go-pedal finesse should do more than just lock
    in on the no-arrows glide state. In my experience, there is much to be gained if it
    also allows you to selectively slip into HV-assisted glide or regen at <42 MPH.
    Ultimately, it should also allow you to stay on the bubble when chasing the yellow
    arrow HV assist when in SHM. In this latter case, I suspect that having access to HV
    output via readings from ScanGauge, CanView, or the like is a near necessity.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    Use an idle solenoid from an early to mid 80s carburettor 6 or V8. That is early emission control running lean idle mixtures. These solenoids don't have enough power to open the throttle but once open they hold at a pre-determined setting. A circuit that switches the solenoid off when the brake is applies would be simple. I don't remember if it was Ford or GM had a 1/4 inch hex adjustment. You can still apply power for pulse then lift right off to glide, touch brake to switch off.
  12. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    Continuing the "Wouldn't it be great if..." approach, I wonder why the next version can't have a cruise control where you set two speeds, the minimum glide speed and maximum pulse speed desired so the computer can handle the glide pedal position, and maximize mileage through the most efficient pulse acceleration. You could set speeds close together for the sanity of following traffic, and spread the speeds when you're on your own.
    I am still trying to decide on the pulse part. I've used zero-arrow acceleration pedal pressure, and I've used my scangauge to do the long, slow IGN 14 acceleration, and I think the former is better.
    Surely the engineers can use software to take it out of our hands...er...foot and make the cruise efficient rather than the floor-it device that it is now.
  13. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    what about instead of messing with throttle , mess with the signal going to/from ECU, say theres a specific signal that comes from the ECu that tells the car to enter this glide mode, if you can replicate it then you will have glide.
  14. efusco
    19,891
    1,194
    Nixa, MO
    I agree, this seems to be a much cleaner and surer way to do it in a car like the Prius that uses a by-wire system. Have a chip that simulates XX% throttle when the button activates it. Mechanical solutions would seem prone to the need for frequent adjustment.
  15. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I have to agree with an earlier post, why not use neutral? It is essentially forced glide. I've been doing this for years.
  16. efusco
    19,891
    1,194
    Nixa, MO
    It is, but doesn't allow as instinctive braking w/ regen or for you to quickly accelerate out...you have to remember to first shift back to D THEN brake or then accel. I use it too...it does work and most times I don't forget to go back into drive. But occ. there are situations where I need to brake more abruptly and don't get all the way into D before I touch the brakes and I lose a lot of regen.
  17. atroader
    atroader Engineer
    39
    Atlanta, GA
    Has anyone hacked the software of the main engine computer yet for a Gen II prius?
    Attaining a wider glide pedal range could easily be done by making the pedal output less sensitive for a small range then more sensitive for acceleration towards the rest of the range. All one would have to do is reprogram the calibration equations between the throttle position sensor voltage and the throttle-plate actuator position.
    I have not dug any deeper into the prius' controllers, but this is a logical controls solution.
    A second alternative (already mentioned?) is to use a non-linear pot for the tps sensor (not really available).
    Final alternative (as mentioned) is to use circuit to remap the position to tps sensor voltage, or use a small digital micro-controller.
    Two important things to know when designing this circuit:
    -- the resolution of the analog-to-digital conversion of the pedal position (tps sensor) (prob 4096 bits / 5 volts)
    -- the total voltage range of the tps sensor (prob 0-5) and the voltage output from the sensor at the edges of glide mode (has anyone datalogged this?)
    You could probably build it w/ a small microcontroller for $50, but I must warn that this is adding a less reliable element in single-redundancy to an extremely reliable drive system, and could at a worst case result in a dead throttle when you need it or a wide open throttle when you dont want it!!!
    So- I must recommend the computer hack as the only safe solution (and I dont think we're getting the prius source-code anytime soon!) But- this is a very easy change for Toyota Engineers to consider! Are you listening?!
    A final thought- if you redesign the pedal linkage/ cam for the throttle pot, if there is one, then you could change the position-to-voltage curve there. After looking- unless you open up the integrated pedal-pot assembly, this is not possible, and probably not possible on the throttlebody actuator assembly either.
  18. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    In this discussion of a possible go-pedal finesse there are clearly two
    alternaives; hacking the electrical signals, or a mechanical approach.
    As to the electrical possibilities, it looks like there are more questions and
    uncertainties than workable ideas. At this point in time it comes down to
    speculation, and a suggestion that it might be doable at some time in the
    unspecified future... well, maybe... but first we have to crack the codes...
    This sounds too much like wishful thinking, chasing butterflies.
    On the other hand, you can create an inexpensive, reliable, and safe
    mechanical system right now -- or at least in the near future.
    The mechanical "problem" can be deconstructed into four parts:
    1. How do you create the manual input? Three possibilities; you squeeze,
    twist ,or move something.
    2, How do you get the signal from the input device to the go-pedal? Four
    possibilities: rods and levers, an encased cable, pneumatics/hydraulics,
    electrical wires.
    3. How do you move the go-pedal? Now this requires some creativity,
    mostly in finding how and where to anchor the arm, cable end, actuator, or
    solenoid that will push or pull on the go-pedal.
    4. Whatever the arrangement, it should be easily/quickly demountable.
    I guess the real question is, How bad do you want it? You can wait until
    somebody, somewhere out in the ether figures out an electrical solution.
    But when it arrives, you can bet there will be a massive hew and cry about
    reliability, safety on public roads, anti-social behavior, liability, and possible
    warranty issues.
    Or you can start thinking about, and then creating, a simple mechanical
    solution. With diligence and even some luck, the result could be super
    simple -- elegant even -- fail-safe, and easy to use.
  19. dwreed3rd
    742
    Marietta, Ga
    What about a back door approach through the CC?
  20. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    I find that each and everytime I use neutral, for gliding, I get considerably worse mileage. I intermix D,B and neutral to keep the charge at about 4 bars. Why this should be is very puzzling, as the mileage improvement should boost to 60- 70mpg. The only thing I can figure is " The engine is running"!!!! This has been concluded by some of our Techies before. The Prius has its own logic, don't fight it.
