Throttle jumpy when trying to maintain speed.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zoeboi954, Jul 21, 2025 at 10:26 PM.
  1. zoeboi954
    zoeboi954 Junior Member
    78
    22
    So when im driving to maintain a certain speed like for example trying to drive at 45mph the throttle input (mpg) start to become slightly jumpy. it would jump from about 40 mpg to 80mpg while I am keeping the same pressure on the gas pedal. You can feel the difference in acceleration when it happens..
    info about the car 2013 prius with an 2018 gen 4 engine euro/jdm version.
    Has anyone experienced this? how do I fix it?
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,629
    1,708
    Bay Area
    No check engine light?
    did it do that before?
    I wonder if it could be the engine swap parts that is affecting the engine signals. Your speed looks to be maintained besides the mpg gauge on the right.
  3. Grit
    Grit Senior Member
    6,463
    4,199
    Wilkes Land
    You should be blessed If car goes From 40 was To 80 mpgs
  4. ChapmanF
    17,411
    I find there are some combinations of road speed, grade, and so on, that end up being right close to the car's "should I use engine power for this or just battery?" decision threshold, and it'll go back and forth a bit. Car might just be doing what it does.
