Tilt sensor
Discussion in 'Gen 2 Prius Main Forum' started by lexidium, Feb 21, 2019.
  1. lexidium
    lexidium Active Member
    235
    109
    manchester
    Has anyone fitted a universal tilt sensor to the gen 2 car alarm? Any links appreciated.
    SFO likes this.
  2. dolj
    dolj Senior Member
    7,628
    3,849
    Wellington, New Zealand
    If you are hoping that this might thwart the cat thieves, it might be a fruitless exercise, as the thieves seem to have a way of disabling the theft deterrent alarm before they lift the car to hack out the cat.
    The cat guard (or garaging), might be the better way to go, if you think you're at risk.
  3. lexidium
    235
    109
    manchester
    There's no tilt alarm on the Prius so they don't need to disarm it and they don't try to open the doors.
    I think this is why a lot of them are being targeted.
    There are various Youtube vids showing alarms going off when cars are jacked up but no info on the prius.
  4. dolj
    dolj Senior Member
    7,628
    3,849
    And, yet there have been at least 2 reports from people that have had their cat stolen that the alarm is not working after the theft.
    SFO likes this.
  5. Devdas
    Devdas Member
    135
    169
    London
    ----UK----
    No tilt sensor in factory fitted alarm
    SFO likes this.
  6. GeorgeD486
    GeorgeD486 New Member
    Southern California
    I can confirm this after my cat was stolen from my 2009 Prius. My dash cam activated in parking mode as soon as they started jacking up the car. The alarm was armed (blinking) the entire time and never sounded.
  7. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Visited a shop recently to inquire about a tilt sensor, and was told that many owners find their horns no longer work after having the cat stolen. He mentioned some thieves will reach under the bumper and cut the horn wires before quickly tackling the job.
  8. QuinnyG19888
    QuinnyG19888 Junior Member
    Dublin
    Hi I recently had a tilt sensor and after market alarm fitted as two different places said tilt sensor wasn't compatible with the factory alarm.
  9. richard203
    richard203 Member
    205
    45
    SF
    was wondering any1 ever installed the tilt sensor themself? the shop quoted me $200 for everything.
  10. Victorio Mo
    Victorio Mo Member
    110
    29
    Folsom, California
    factory Alarm doesn't have tilt/shock sensor, Will wait till somebody will do it DYI and share. it works basically adding another loop switch to existing door open/close sensor which is just mechanical contact on wire pair. If you go with smart sensor (507M DEI Digital Tilt etc..) it's not that simple without good guide. Beside this wire you need to find always hot 12V and do some fuses.
    I have one guy who installed even simpler ball tilt sensor cutting in into existing wire pair coming from the door.. in this case you don't need any other connection, you just duplicating existing open door switch.
    #10 Victorio Mo, May 3, 2020
  11. richard203
    richard203 Member
    205
    45
    SF
    ya i was wondering do get the 507M tilt sensor but i dont know what wire to tap into thats the hard part. heres the link to the instruction to install the tilt sensor. the only part is where to tap those ground alarm wire to.
    https://www.installer.com/pdf/507m.pdf
    #11 richard203, May 3, 2020
    SFO likes this.
  12. ChapmanF
    15,445
    Conduit....
    Another and nssdiver like this.
  13. Victorio Mo
    Victorio Mo Member
    110
    29
    Folsom, California
    @chapman did you mean metal rod welded = Conduit ?
    @richard thanks for manual.
    Anybody knows where in Prius G2 all alarm brains located ?
    And in Armed state is door switch pair is connected or disconnected ?
    I meant like this one, it doesn't need to be connected to any power. Juts parallel connect it to do sensor. But need to check if factory door switch work on open/or close circuit .
    and buy one to work with 12V and probably .5A.
    it's nice project, I will go today to see how those factory knobs set, probably even replace one on the rear door with one of those below:
    DEI Directed Electronics 8623 Ball Bearing Mercury Tilt Switch Sensor for Alarm | eBay
    or even
    10pcs/lot SW 200D Vibration switch Ball switch Tilt switch Double bead Angle sensor|Sensors| - AliExpress
    Cutting horn require is different level of thief, so this still can help.
    #13 Victorio Mo, May 3, 2020
    SFO likes this.
  14. ChapmanF
    15,445
    I don't have a Gen 2 handy. Looking at my Gen 3, I can only imagine somebody poking cutters directly through the grille to cut the horn wires running vertically right behind it.
    I imagine it wouldn't take anything more elaborate than what we call Electrical Metallic Tubing, secured somehow at the top and bottom, to throw a wrench in that plan.
    But Gen 2 may be different.
  15. Victorio Mo
    Victorio Mo Member
    110
    29
    Folsom, California
    Thanks all, I started my project on Gen2 to see what will happened, Door switch is single wire device so it should work with Ground (-). In closed position ground = ON.
    I will just get rid of rear left switch and wire it with tilt sensor, I hope will find some for 12V, otherwise need relay.
    Duralast Door Jamb Switch SW3481
    SFO likes this.
  16. richard203
    richard203 Member
    205
    45
    SF
    so right now we got the following down. victoro you got a picture of the door switch to show its only one wire? if we got this down i might do it.
    red wire - 12v power source
    orange wire - door lock switch
    blue wire - how about this wire? iit need to wire to a trigger wire which is what? lol
  17. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Let me try and find the dealer gen3 tilt sensor installation guide.
  18. richard203
    richard203 Member
    205
    45
    SF
    any update on where to tap the tigger wire any1?
  19. The Lizard King
  20. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    PriusFruit likes this.
