Time Change
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Nov 2, 2019.
  1. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    Time to remember how to change the clock in the car. I knew I should have paid more attention in school.
    Also, had a strange experience this morning. I was in the bathroom brushing my teeth when I heard a car panic horn going off. At 1st I thought the neighbors car was causing the noise. I opened to door to the garage to see my Prime as the cause of it. The car was not locked. I did have the fob in my pocket so I hit unlock and the noise and flashing lights stopped. I hope that somehow I triggered it in my pocket while brushing my teeth. Never happened before. Might be left over ghosts from Halloween.
    EyePrime and Dael like this.
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    lol, pocket trigger...leaning up against sink/cabinet?
    have had it happen a few times
    You have your owners manual? check back contents and alphabetically search for "clock" or "settings"
    Should give you the rundown
    KCWhitney and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    That’s the subtle “hey you haven’t turned the engine on in a long time” warning :p.
    I’ll have to spin through the manual or try perusing the menus on the way to soccer this morning to get the clock right ;).
    The harder one to get is the RX450h. That has two, and one has the hands on it:cool:.
    That requires reading up again (y).
  4. Salamander_King
    Salamander_King Senior Member
    11,023
    8,963
    New England
    Reading from other threads, IIRC, there are two clocks to set on Prime. One on the MID and another on the Navi. I have changed the time on MID before, but never on Navi. Where does the Navi clock show up?
  5. huskers
    2,546
    2,487
    Nebraska
    Well, the Navi is right 6 months of the year. If it is this 6 months you are good to go.
    Raytheeagle likes this.
  6. Salamander_King
    11,023
    8,963
    New England
    Actually, I don't use Navi often enough to notice any difference. Does the time actually show up somewhere on the screen?
  7. Gokhan
    Gokhan Senior Member
    6,487
    2,594
    Paramount CA
    The main clock is very easy change -- simply use the arrow buttons on the steering wheel.
  8. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    If I recall, the Navi clock can be set to adjust automatically for daylight savings time.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    "the Navi clock can be set to adjust automatically for daylight savings time."
    And gets its time signal from GPS. The check boxes to switch these functions on are in the set up screen of the big screen.
    Marine Ray likes this.
  10. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
    I don't think the navigation system adjusts for daylight savings automatically. It receives the time from GPS, but I still had to go into the menu and toggle DST off.
    jerrymildred and brugan like this.
  11. Gokhan
    6,487
    2,594
    Paramount CA
    This sounds correct.
    Navigation clock: always automatic, no manual adjustment.
    Navigation time zone: can be done manually or automatically.
    Navigation DST: can only be done manually
    For navigation settings first press the Menu button, and then go through Settings -- General -- System Time.
    California was supposed to switch to permanent DST this year but it didn't happen. Hopefully it will happen next year. Everyone hates the clock change, and most people prefer permanent DST.
    Main clock: Select and adjust using the arrow/OK/back buttons on the steering wheel.
    #11 Gokhan, Nov 3, 2019
  12. Tideland Prius
    16,607
    I changed the MID clock after midnight so it rolled over to midnight twice.
    That meant this morning when I got in, the car thought it was Nov 4. When I changed the date, it wiped out the Daily Eco Diary. Sigh.
    huskers, Gokhan and Salamander_King like this.
  13. Gokhan
    6,487
    2,594
    Paramount CA
    This is actually very funny.
    I saw a comics joke a long time ago in which this funny character would wake up to the loud alarm ring of his bell clock at 2:00 AM. He would then complain why they were choosing the time to adjust the DST so inconveniently. I guess the joke is on us. ;)
    CraigCSJ and Tideland Prius like this.
  14. heh that feature is broken on my hybrid, 2 months later and I still have 7/8 of a tank. Maybe mine is more subtle than everyone else’s :ROFLMAO:
  15. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Depending on congressional approval and which state you are in, you may end up turning DST off and adjusting one timezone to the east. #DitchTheSwitch.
  16. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Right. Mine did not adjust. Is I just turned off DST on the navi display. Then changed the MID time with the steering wheel controls. And we really need to dump DST.
    Jon Cryer and Mendel Leisk like this.
  17. Salamander_King
    11,023
    8,963
    New England
    OK, for the first time in over two years, I have set the wintertime on my Navi. Now, where do I see the clock on the Navi???o_O
  18. Tideland Prius
    16,607
    Bottom left :LOL:
    But seriously, all you do is select DST on or off. Everything else is done automatically.
    jerrymildred likes this.
  19. Salamander_King
    11,023
    8,963
    New England
    Well, OK. :oops: But that's shown only on the set-up screen. What I meant to ask is, Is there anywhere on Navi screen I see the current time displayed while using it?
  20. jerrymildred
    11,517
    14,157
    Tampa, FL
    Whether you see it or use it or not, the charging schedule is using it. If you program it with enough time padding that an hour either way won't affect you, then I don't know of a reason why you'd bother with the DST setting. But for me, it's a pretty insignificant chore. Much easier than taking out the trash and quicker than brushing my teeth. :D
    Salamander_King likes this.
