Time for a new Toyota Celica?
Discussion in 'Toyota Hybrids and EVs' started by drash, Dec 27, 2022.
  1. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    Spyder7 website reports that Toyota is considering bring back the Celica. For those unfamiliar (or don't remember) with the Celica, it was essentially Toyota's foray into a 2-door lift back to compete with the likes of the Mustang. The back seats were a joke but they were still there. Then they made it longer, front wheel drive and it got uglier (IMO) although the later GT restored its aura. Final model year was 2006. Now Toyota might reintroduce it with the 2023 Prius 2.0L hybrid setup.
    Partial translation:
    "Hammerhead" adopted, Toyota "GR Celica" electrified and released... Get the latest expected CG!
    The first generation "Celica" appeared in 1970, and in 2006, the final model, the seventh generation "T230", was discontinued. However, since Toyota continues to reapply for the "CELICA" trademark, expectations for its revival are increasing, and there are rumors that the successor model may be released under the "GR" brand.
    Digital artist Theottle provided the expected CG. The front end adopts a "hammerhead" design inspired by the new "Prius", the sides are equipped with a flowing coupe hood, the suspension is equipped with red brake calipers, and a set of large diameter aluminum wheels.
    At the rear, a distinctive trunk lid spoiler is installed, and the tail lights are connected by an LED light bar, which is now a mainstream design.
    Although the powertrain cannot be determined, the current leading candidate is the use of the new Prius plug-in hybrid system, which is equipped with a 2.0-liter in-line 4-cylinder gasoline engine and an electric motor with a maximum output of 163ps, with a maximum output of 223ps. It is to demonstrate. This setup is FWD, but there is a possibility of an AWD layout if the electric motor arrangement is changed, which is rumored for the GR Celica.
    The debut of the Celica successor model that is worrisome, but according to the latest information from the United States, it can be expected in the second half of 2024."
    Article:
    https://spyder7.com/article/2022/12/24/17117.html
    #1 drash, Dec 27, 2022
    ammdb likes this.
  2. Tideland Prius
    16,125
    There was that yellow car rendering a few years back of a new Celica, so it's been floated around for a while now. I think at one point, it was even suggested it would be a hydrogen hybrid. (which the Gen 5 will likely get, around mid-life)
  3. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    I would love to see Celica brought back. Not that I would buy it again, but it was my second car after scrapping my first-ever car, Chevy Vega. I bought it used, and I think it was a Gen1 ST coupe model but not sure. That was my last standard shift car, yep, over 40 years ago.
    drash likes this.
  4. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    Wow that must have been a heck of an upgrade from the Vega to the Celica! I had the sister car the Pontiac Astre which was a heck of a downgrade from the Buick Regal Turbo, but the insurance was much better.
    Salamander_King likes this.
  5. Salamander_King
    10,970
    8,853
    New England
    Yeah, fond memories of yesteryears. I definitely had fun in that car. I can't remember what I did with it though. I think I ended up giving it to my brother when I bought a brand-new Pathfinder (I believe it was also Gen1) some years later.
  6. drash
    drash Senior Member
    2,477
    1,252
    Upstate NY
    Yep seen a few rumors around even as late as May, before this rumor, of the Celica coming back. Toyota has refiled the copyright for the name in 2017 and again in 2021, so any time now??? ;) The car-moby.jp site had the expected powertrain to be the same as the GR Yaris, a 1.6L 3 cylinder Turbo.
    "Expected specs of GR Celica
    Assuming the Celica is revived, it is likely that the platform will adopt the same "GA-C" as the Corolla series, as I mentioned at the beginning.
    The powertrain is expected to be equipped with the same 1.6L 3-cylinder turbo "G16E-GTS" engine as GR Yaris and GR Corolla, combined with a 6-speed MT and sports 4WD system "GR-FOUR".
    Higher power performance than the GR Corolla is given, and expectations are rising that the maximum output will be close to 320PS and the maximum torque will be close to 400Nm."
    article:
    「トヨタの4WDスポーツ」はやっぱりコレ!8代目GRセリカは見た目“も”速そう | ページ 2 / 2 | MOBY [モビー]
    I believe now that the 2023 Prius and Crown have been released, they have a couple of hybrid powertrains they can choose from. Maybe they are reviving the Celica to gather all they learned from the BMW jointly developed GR Supra and the Subaru jointly developed GR86 to put their mark on a coupe with their own hybrid power plant. The questions is, which one? The NA 2.0L AWD hybrid power plant found in the 2023 Prius, which can almost beat the GR86 AT time of 6.9 secs or use Hybrid Max power plant found in the Crown, which can almost beat the 2.0L twin scroll turbo found in the GR Supra of 5.2 secs? An outlier would be the i-Force Max system which can drive the new 3 ton Tundra to GR86 MT time of 6.3 secs and it is RWD centric. Kinda doubt they'll be able to keep the weight under the original 1,390 kg (3,064 lbs) with either the Hybrid Max or i-Force Max.
    Tideland Prius likes this.
  7. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
    Mine was a first gen Celica Supra, had a lot of fun in that car! I think a new Celica is a great idea!
  8. Trollbait
    11,504
    I thought the Celica was only popular in the US. The tC being North America only sort of supports this.
    Someone here already called the new Prius a Celica replacement.
