time for a traction battery rebuild
Discussion in 'Gen 2 Prius Technical Discussion' started by walleye seeker, Mar 7, 2013.
  1. walleye seeker
    walleye seeker Junior Member
    muskegon
    well after driving my daughters car today it is clear that a rebuild is in order. from what i can see my torque app shows block 11 suspect with voltage at time 1.5-2 volts less than the rest. Also noticed the battery charge meter is all over the place fully charged to near dead in 1/2 mile of driving. So here is my plan purchase 4 supermate dc6 chargers and do a balance charge 2 times on each of the 28 cells and then replace the bad ones.
    how long do you guys think the mighty prius will be down useing 4 chargers i will be leaving the pack in the car and outside here in michigan with temps in the mid 30s im thinking this will help with heat.
    any advice for a first time rebuilder and yes i know how to work with high voltage linesman gloves will be worn until the pack is rendered safe
    51,154
    what year is it? how many miles on her? what were the clues to the battery problem before you hooked up the scan gauge?
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    If you rebalance with two cycles (I did three cycles), it takes less than a day to do one module. Four modules at a time (keep the modules clamped in the battery, but rebalance ones that are separated to avoid overheating) so 28 modules takes a week. Add some time to balance and match up spare modules and equalize the voltage on all 28 modules and your job can be done in a week plus two weekends.
    Once one bus bar is removed the battery is safe (until you put the bus bar back on). Take your time and read: Setting Up Supermate DC6 | PriusChat and some other threads where Seilerts and I are helping others (especially Seilerts).
    I would use a large capacity 12v battery and a charger as the 12v power source as a power failure during the process loses the module rebalancing data (it happened once to me during the my efforts - I wasn't happy).
    JeffD
    [email protected] likes this.
  4. walleye seeker
    muskegon
    well i got the battery tore down today and had 8.4 volts on 27 batteries and 7.1 on 1 i think i have found my problem child now to remedy . i purchased 2 cells off ebay and purchased 4 supermatd dc6 chargers . hopefully will have this stuff by 3/13/13 so i can start my marathon battery balance
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Good deal walleye. Let us know how it goes.
  6. walleye seeker
    muskegon
    well i ordered all my parts yesterday here is a list
    1. ebay 2 cells $80
    2.Hobby Partz $138.49 4 supermate dc6 chargers
    3. ebay 12volt 5 amp power cord F1703 qty 4 $38.00 The f1703 is a compaq laptop computer part # this will make sure you get the right end on the cord to plug into the supermate dc6
    for those that dont know this the supermate dc6 does not come with a power source since they are designed for rc batteries guys hook the charger to there car battery with alligator clips for charging power in the field
    Hobby partz they were suppose to be free shipping on orders over a $100 but it charged me $18.94 in shipping so i made a claim ticket on there website and am waiting for a reply.
    Hopefully i dont need anything else and this only cost $260 bucks will see
  7. walleye seeker
    muskegon
    The car is a 2006 140000 miles i also have a 2005 with 225000 miles i have no idea if either one are original traction batterys but i beleive the 2006 is i saw no sign that it had ever been apart before
  8. usnavystgc
    3,159
    990
    Tucson, AZ
    $260 to fix your traction battery is very cheap.
  9. walleye seeker
    muskegon
    well i received all 4 of my chargers and there all hooked up im charging batteries 1-3 and 15-17 with the 4 supermate dc6 chargers here is what i set the specs to.
    1. discharge / charge 2 times
    2.discharge amps .07 and low voltage cut off at 6 volts
    3. charge at 5 amps with a full charge at 7500 mah
    4. charging sequence of battery 1-3 and 15-17 then 2-4 and 16-18 and so forth
    useing this method im charging 2 packs with 1 between them and then always keeping half the pack in between the other 2 chargers
    let the marathon begin official start time 1:30 pm eastern time .
    hopefully everything is as it should be
    please chime in if anything looks wrong with my plan.
    xs650, R-P and usnavystgc like this.
  10. walleye seeker
    muskegon
    ok the numbers are starting to roll in 1 by 1 here is where we are
    CELL#15
    DCHG #1 2769
    CHG #1 5607
    DCHG #2 4474
    CHG #2 6352
    CELL#17
    DCHG #1 2967
    CHG #1 5472
    DCHG #2 4431
    CHG #2 5963
    MORE TO COME
  11. walleye seeker
    muskegon
    and the next 2
    CELL#1
    DCHG #1 4004
    CHG #1 7212
    DCHG #2 5820
    CHG #2 7500
    CELL#3
    DCHG #1 3867
    CHG #1 6835
    DCHG #2 5491
    CHG #2 7436
    allready i can tell by the numbers that the outer most cells are in the best condition
  12. walleye seeker
    muskegon
    and the next 2
    CELL #18
    DCHG #1 2839
    CHG #1 5229
    DCHG #2 4025
    CHG #2 6097
    CELL #16
    DCHG #1 2897
    CHG #1 4995
    DCHG #2 4092
    CHG #2 5992
    MORE TO COME SOON
  13. walleye seeker
    muskegon
    and the next 2
    CELL #2
    DCHG #1 3995
    CHG #1 7222
    DCHG #2 5650
    CHG #2 7500
    CELL#4
    DCHG #1 3876
    CHG #1 6997
    DCHG #2 5850
    CHG #2 7443
    LOOKING GOOD SO FAR
  14. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Well doing Sir.
  15. walleye seeker
    muskegon
    well houston we have a problem with this cell
    CELL # 19
    DCHG #1 0374 HUH
    CHG #1 2714
    DCHG #2 1971
    CHG #2 3574
    I decided to run this cell again 2 more times on the dc6
    Cell#19 round 2
    DCHG #3 2412
    CHG #3 4311
    DCHG #4 3593
    CHG #4 5414
    The numbers are getting better each time but after 4 cycles have i reached my max . I am going to move on and come back to this cell later and run 1 more time on the dc6 im trying to get 6ooo or more on every cell. Before reassembly
  16. walleye seeker
    muskegon
    and some more
    Cell #18
    DCHG #1 2839
    CHG #1 5229
    DCHG #2 4025
    CHG #2 6097
    Cell #6
    DCHG #1 4594
    CHG #1 7010
    DCHG #2 5833
    CHG #2 7500
    Cell #8 EBAY replacement cell
    DCHG #1 2564
    CHG #1 7500
    DCHG #2 5418
    CHG #2 7500
    Should i run the cells that are around 6000 1 more time to try and get them closer to that 7500 mark???
  17. usnavystgc
    3,159
    990
    Tucson, AZ
    I would but, I know its a pain and time consuming. I always figure, do it once, do it right.
  18. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Module original rating is 6.5 AH (6500 mA-h) so don't expect a discharge rating of noticeably more than that. I used a three cycle rebalance protocol on my 2004 modules with good results.
    JeffD
  19. walleye seeker
    muskegon
    ok i managed to get all the individual cells charged and i beleive its time to balance out the voltage between the individual cells before reconnection.
    my plan is to use the supermate and discharge to 7.2 volts per pack and reconnect the bus bars when done. Does anyone have any input on the final voltage balance maybe a better way to do it.
    Thanks Kevin D
  20. jdenenberg
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It doesn't matter as long as all modules are at the same voltage. I try to use the highest voltage that all of them can be set at (the lowest of the rested module voltages) so that battery SOC starts out higher.
    JeffD
