Time for new tires
Discussion in 'Prime Main Forum (2017-2022)' started by Jnbrown, Feb 15, 2020.
  1. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    My 2017 Prime has 37K on it and tires might last another 5K.
    It came with Dunlop Enasave.
    I have not been unhappy with them, they perform ok and are reasonably quiet and comfortable.
    40K miles isn't bad for OEM tires.
    I am thinking of replacing with Continental PureContact Ecoplus.
    They got really high ratings on Tirerack.
    They are supposed to be LLR but not sure how good.
    I have Continental tires on my Sienna and they are working well.
    My Toyota dealer recommended Yokohama Avid Ascend LX, they seem to be fairly new and couldn't find many reviews. Any other tires I should consider?
    I never liked Michelin because IME they are expensive, loud and wear out fast.
    Thanks
  2. Salamander_King
    Salamander_King Senior Member
    11,019
    8,954
    New England
    #2 Salamander_King, Feb 15, 2020
  3. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    Thanks for the list.
    I spent some time reading reviews on Tirerack, especially the ones with a Prius.
    There are a lot complaints about noise for most of these tires.
    But for a given tire there are reviews that say it is quietest tire and others say it is the noisiest tire.
    Noise is one thing I don't tolerate from tires.
    Out of that list the Continental TrueContact Tour seems to have the best overall reviews / ratings so that would be my current choice. There are some complaints about MPG going down with these tires but increasing tire PSI helped with that. I am ok with a slight drop in MPG, hopefully it won't be too much.
    #3 Jnbrown, Feb 15, 2020
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    There are Many Many good choices...
    Here are two good choices:
    1) General AltiMAX RT 43 (Owned by Continental Tire) 195/65-15, T Rated, Very Light at 17.3 lbs, $81 each. This choice gets a slight nod towards comfort. 45 day test/trial, 75K Warranty.
    www.tirerack.com/tires/tires.jsp?tireMake=General&tireModel=AltiMAX+RT43+%28T-Speed+Rated%29&partnum=965TR5AMRT43&vehicleSearch=false&fromCompare1=yes
    2) Yokohama AVID Ascend GT, 195/65-15, H Rated, 20.5 lbs, $90 each. This choice gets a slight nod towards handling.
    30 day test/trial, 65K Warranty.
    www.tirerack.com/tires/tires.jsp?tireMake=Yokohama&tireModel=AVID+Ascend+GT&partnum=965HR5ASCGT&vehicleSearch=false&fromCompare1=yes
    Both are good in the rain.
    More fun info:
    Better Handling On A Budget ! | PriusChat
    Rob43
    #4 Rob43, Feb 15, 2020
  5. Jnbrown
    Jnbrown Member
    111
    85
    Encinitas, CA
    I had General Altimax on my old Camry and on my Sienna. They were good tires.
    I stopped using them I think because they wore out too quickly and they were getting hard to find at local shops and there were better options like Continental. Not sure how good the rolling resistance is.
    The Continental's on my Sienna are without a doubt the best tires it has had.
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    If they weren't the General AltiMAX RT43, then you can't compare.
    Sounds like you've made up your mind anyway for Continental's, certainly a reasonable choice.
    Rob43
  7. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    I’d try the non ev sporty Michelin’s they are extremely comfortable and yet still somehow can corner it’s literally the best of both worlds...
    iPhone ?
    benagi likes this.
  8. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    For the Prime that would probably be the Premier A/S. But they appear to be a bad value compared to the longer lasting Defender, unless they are really that much quieter.
  9. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    There is no industry standard to define low rolling resistance, and no common standard to test for that.
    Here is some info from a tire engineer: Barry's Tire Tech
    "Most rolling resistance is caused by internal friction of the rubber as the rubber moves through the footprint area. You can measure this in the form of heat generation, but that is difficult to accurately quantify this.
    "Since rolling resistance is caused mostly by internal friction of the tire, then there are a number of things that can be concluded:
    1) The more the tire deflects, the more the rolling resistance. This is more or less a "load vs inflation pressure" kind of thing.
    2) The more the material in a tire - especially in the tread area - the more the rolling resistance.
    This means that new tires are going to have more rolling resistance than otherwise identical, but worn out, tires. So when you buy a new set of tires, you should expect a loss in fuel economy.
    3) The tread compound - and the amount of internal resistance it has to movement - is going to have an effect on rolling resistance.
    There are three properties that can be traded off with one another - Tread wear, Traction, and Rolling Resistance. You can maximize one of these properties, but it has to come at the sacrifice of at least one of the others.
    This means that tires with good traction compounds have either sacrificed treadwear or rolling resistance (or both). This also means that tires with high UTQG treadwear ratings have sacrificed traction or rolling resistance."
    (Emphasis mine)
    The excellent Michelin Defender is optimized for long tread life. The excellent Michelin Premier is optimized for high traction. The choice is yours.
    My choice of tires for our Prime is the Bridgestone DriveGuard Run-Flat tires. Not the quietest, not the best traction, not the lowest rolling resistance. Said to be able to run 50 miles at 50 mph without air (then the tire is junk). Again, the choice is yours.
    m8547 likes this.
  10. Salamander_King
    11,019
    8,954
    New England
    Instead of buying a new set of tires for my 2017 PRIME, I traded it in for 2020 PRIME. The new car came with OEM Bridgestone Ecopia 422 Plus. Not the tires I would have bought for my PRIME if I had a choice, but they should give me at least 40K miles of very good mpg.
    Tips likes this.
  11. eskudo12791
    eskudo12791 Junior Member
    22
    Virginia Beach
    I opted for a set of Goodyear Assurance WeatherReady tires. Might not be the most quiet, but I wasn't enjoying the rain handling of OEM. With a goodyear credit card they came out to $357
    Tips likes this.
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,153
    Tampa, FL
    I have around 16,000 miles now on my Yokohama Avid Ascend GTs. Still 9/32" of tread. They started with 12/32. Reasonably quiet. Spectacular rain performance. I didn't have the OEM Toyo Nanos for long (used car) but it seems like I was getting considerable better miles per kWh back then. But gas mileage when in HV mode is terrific, so maybe that's my imagination.
  13. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    Just bought a set of the Yokahama GTs. I only have a few short drives on the tires (mainly highway). Call me crazy, but I like the Dunlop Enasaves that I had in the car before better. They seemed quieter, had a better road feel, and the mileage was better.
  14. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    The Enasaves are surprisingly good for OEM tires. Not super long lasting, but efficient, quiet, and have adequate grip. Not that I've used anything else on this car besides snow tires.
    New tires will tend to be a little worse than worn tires for efficiency, cornering feel, and maybe dry grip, because they have taller tread blocks.
    jerrymildred likes this.
  15. litesong
    litesong Active Member
    371
    122
    Everett, WA
    I had OE Dunlop SPs a decade & half ago. Ran quiet, smooth, good traction dry or wet. With the anti-skid brakes, they really dug into snow, even softer ice. Lasted 53,000 miles & still had tread above the bars. Very pleased with those OE tires.
  16. jerrymildred
    11,517
    14,153
    Tampa, FL
    I ran Dunlops on my last motorcycle. I liked how they handled and wore. I'm not a racer, so they were fine for me. The Yokohma Avid GTs I've had on my Prime since May have been great, especially in the rain. I can't compare to the Dunlops you had, but compared to my oem Toyo Nanos, they were a big upgrade. You might get your mileage back once they break in as @m8547 mentioned. My Yokohamas, over about 18,000 miles have worn down from 12/32" to 9/32".
    #16 jerrymildred, Mar 19, 2020
  17. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    I think the Dunflops start at 8/32, but it looks like there are a couple versions out there there.
  18. jerrymildred
    11,517
    14,153
    Tampa, FL
    I was referring to the Yokohamas with the tread depth. Thanks for mentioning that in time for me to go back and edit it for clarity.
    My Toyos were down to 5/32" after 24,803 miles and we were headed out for a 6,000 mile trip that would take us over the Colorado Rockies in May, so I didn't think it was very smart to trust them that far.
  19. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    Right. My point was the yokohamas come with a lot more tread to start with, compared to the Dunflops. So that could explain some of the difference. Sorry if that wasn't clear.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Report back after you have driven roughly 1000 miles on various roads & different environments, especially multiple rain events.
    Rob43
