Time to change air filter??
Discussion in 'Gen 2 Prius Main Forum' started by JW87, Aug 5, 2012.
  1. JW87
    JW87 New Member
    Michigan,United States
    Is it time to replace this air filter?
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    That is good shape in my opinion.They look like that in a couple days. Good for another year at least. Depends on the circulation as well. ;) H
  3. Patrick Wong
    18,200
    6,492
    Looks pretty good.
    Change the filter at 30K mile intervals or sooner - hold the filter up to the sun and if you cannot see light coming through, then change it.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    If you have access to compressed air, give it a light hosing off. If you ate too aggressive you will shred it, but your pic still indicates it has plenty of use left in it!
  5. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    That looks good. I replaced the filter after about 3.5 years on my 08.
  6. PriusCamper
    PriusCamper Senior Member
    12,056
    4,893
    Pacific Northwest, USA
    Use extra caution if you haven't replaced your air filters prior to Spring 2011 and you live on west coast of the US, or anywhere downwind of Fukishima...
    Air filters in the Seattle area did test positive for elevated levels of radioactive particles due to the initial pulse of material released into the atmosphere during the quadruple reactor meltdown in Japan.
    You really don't want to use compressed air on that kind of dust because it's more likely to get into your lungs.
    Of course if you have a K&N air filter you can use their liquid cleaning solution, which will ensure you sending hot particles down the drain rather than back into the atmosphere. (YET ANOTHER REASON TO USE K&N FILTERS)
    Here's a bit more info: Scientist Marco Kaltofen Presents Data Confirming Hot Particles | Fairewinds Energy Education
  7. JW87
    JW87 New Member
    Thanks for the help guys!
    PriusCamper likes this.
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I would like to see them put pressure sensors in air cleaners so that when the pressure drop across the element reached the design limit for that vehicle the driver would get a change air filter notification. An installed sensor should be well under $20 on the production line and the computing power and display capability is already in the car.
    Some absolutely horrid cruddy looking filter elements still have acceptable pressure drops, and some that don't look as bad should be replaced.
