Time to replace 12v battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by twosinks, Jul 31, 2024.
Tags:
  1. twosinks
    twosinks New Member
    Georgia
    the 12v battery in my 2013 Prius reads 11.6 volts before startup and then once I turn the car on it jumps up to 14.3v is this normal? Or is it time to replace the 12v battery? I found this information in the diagonstic menu... I assume that the information provided is for the 12v battery, and not the Hybrid battery.
    There is no trouble turning the car on and there is no signs of a dying battery like dim interior lights nor an illuminated check battery light on the dashboard.
    #1 twosinks, Jul 31, 2024
  2. Brian1954
    Brian1954 Senior Member
    2,387
    959
    South Central PA, USA
    How old is the 12v battery?
    You could try using a battery charger and see how the battery responds before buying a new battery.
  3. Stevewoods
    Stevewoods Senior Member
    663
    1,199
    Seattle, WA
    How are you "reading the 12v number."
    Basically, if your battery is below 12.4 volts you are living on borrowed time.
    The battery needs to hold above 12.4 all by itself to be considered viable.
    #3 Stevewoods, Jul 31, 2024
    52,348
    if it's original, replace it with a new oem
    Stevewoods likes this.
  5. LeftyLucy
    LeftyLucy Junior Member
    Massachusetts, USA
    My 12v battery had similar symptoms to the o/p. Eventually, it could barely start the car after sitting overnight during the New England winter. By "barely" I mean that, after depressing the brake pedal, I would have to wait for the brake booster pump to finish doing its thing before trying to start the car.
    Being an experimental type and tired unmanaged lead acid batteries that are easily damaged by over discharge, I decided to go with an automotive 12.8V 50 Ah LiFePO4, currently selling on Amazon for $105:
    However, at the time (Jan '23) there was a catch: unless I went with expensive cold weather designed lithium-yttrium chemistry, lithium batteries could not be charged safely below freezing. While the battery above did have a battery management system (BMS) in place, sadly, mine does not prevent charging below freezing temperatures. Perhaps things have changed in the last 18 months.
    So, I made a small external circuit for the necessary protection. Battery discharging is always available by way of high current diodes like you would find in jump start battery packs. Once the Prius is powered up, a simple circuit becomes powered and enables charging only when the battery temperature is 5-30 degrees Celsius.
    10-30 degrees Celsius is considered optimal to reduce battery stress and extend lifetime. However, for my driving profile of mostly short trips, I suspected the battery wouldn't have time to warm up to 10 degrees C (50 degrees F), so I decided to compromise at 5 degrees C (41 degrees F) which often happens naturally during the winter day for my part of New England.
