Time to replace battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by wesayso, Jan 24, 2019.
  1. wesayso
    wesayso Member
    385
    35
    Hampton, VA
    Well, my Prius will be 8 years old in March. I still have the original 12 volt battery. Is it time to replace it? How many years is everyone typically getting?
  2. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    8 years? I would have changed it 3 years ago.
    In short, yes.
    How cold does it get in your neck of the woods?
    jerrymildred and Mendel Leisk like this.
  3. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    448
    186
    Indiana
    2022 Prius Prime
    yes, replace it. better to give up another 6-8 months or a year of use than to be stranded with a dead battery.
    Mine is 4+ years and I was nervous going into this winter. Its def getting replaced in the spring.
    tweedle99 likes this.
  4. Grit
    Grit Senior Member
    6,139
    4,053
    Wilkes Land
    Leave it, Mother Nature can always defer on accepting another battery that’s yet dead in her landfill.
    And then for bragging rights on PC also, that you can still crank the original 12v batt after 8 years :cool:
    RMB likes this.
  5. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I just did our '08 for the 1st time (10 yrs). I maybe should have done it 2 years ago, as occasionally (3 times) I need to jump start it. The car is a lot happier now.
    RMB and bisco like this.
  6. bisco
    49,371
    mine is 7, still showing 12.6 volts
    RMB likes this.
  7. bat4255
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Ours did too when I checked it, but it would randomly become dead.
  8. bisco
    49,371
    that's odd, no capacity for the constant drain maybe
  9. schja01
    1,744
    1,162
    Chicagoland
    2018 Prius
    Maybe a Prius battery lasts longer because it doesn’t need to supply high cranking amps as those in conventional cars do?
    wesayso and RMB like this.
