timed charging
Discussion in 'Prime Main Forum (2017-2022)' started by eveyo, Feb 5, 2021.
  1. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    For the past two days when I tried to charge for a departure of 7am before work, it hasn't charged. I've never had this issue before. This morning when I connected it for charge now there was no issue. I've also double checked the settings so it had charged for departure 7am. Do you guys have any experience with this? Any advice?
  2. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Was it not charged at all or charged but not completed? The charging schedule can be interrupted by overriding it with the Charge Now session. I think if you do this before the scheduled time of charge, the next session will not start. There may be other reasons that the scheduled charge does not start such as power outage or unintended/intended power interruption by unplugging from the wall. Not exactly sure how the EVSE react in each case, but I have seen the warning on the dash with something like "Power was interrupted during charge"
  3. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    No charge happened. Just showed it was plugged in for x number of hours.
  4. road2cycle
    road2cycle Active Member
    168
    109
    Sonoma County, CA
    Is the Prime’s clock set correctly?
    Did you remember to press the lock button at the charging port? The first time I tried to charge my Prime based on the schedule, I’m pretty sure I forgot to press the lock button so it didn’t charge.
  5. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    The lock button makes no difference. I charged twice per day for 3 years using the schedule and never pressed it. Worked fine everytime.
    jerrymildred likes this.
  6. road2cycle
    168
    109
    Sonoma County, CA
    Good to know. I must have done something else wrong then.
  7. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    time checked prior to turning car off. auto lock has been set for a while.
    I plugged in for charge now today and it worked fine. I'm just hoping maybe now it will charged based on time the next time. It didn't work the past two times. Maybe doing a charge now will kind of reset it so a timed charge will work later
  8. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    It may sound dumb, but did you confirm the AM/PM for both the clock and timer are right? If one of them is set incorrectly, that would result in no charge in your scenario (assuming it was plugged in <12 hours before).
    Kinda like the first step in troubleshooting is to make sure your thing is plugged in... :confused:
    Just a thought... ;)
    jerrymildred and john1701a like this.
  9. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    yep checked that. Guess I will see tomorrow morning
  10. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,550
    720
    Another thing to watch out for is what days of the week the charge schedule is set to repeat. On my 2021, if I don't specifically specify which days of the week the schedule runs it won't run at all. Also, make sure the date and year is set correctly (so the car knows which day of the week today is).
